bajafreak's Reviews
02-10-2011, 09:12 PM |
Price: $50.00 Pros: Hmm... Cons: Too many Recommended? No
Comments: To Whom May Fall Victim:
****WARNING****
These things are so bad I do not know where to begin. Well, just to show that I am not just biased because of the horrible experience that I have had with these cheap pieces of garbage, I guess I'll start with the only good things about them. The billet aluminum 1.5" spacer body is pretty nice and sturdy, and they are very cheap. If you paid more than $40.00 a pair, you got ripped.
Now then, I put them on with no real big problems. That is other than the fact that the well hole that holds the lug nuts to mount the spacers to the wheels are very small. You really have to use a very thin walled socket to get them on. And, forget about using any regular sized lug nuts there. The supremely cheap lug nuts that came with the spacers are the only ones I can see fitting in those tiny wells.
Then, after just one tire rotation, I noticed the immeasurably cheap lug bolts on the spacers stripping out. Then I noticed that the imbeciles that made these spacers had used the wrong size of lug bolt. The threads on the lug bolts do not even go all the way to the bottom, or to the base (body) of the spacer. So, when you put lug nuts on these spacer lug bolts with thinner steal rims, the spacer lug bolts (which are the wrong size for the spacer) strip out the first quarter of an inch of your lug nuts. Then, your lug nuts, in turn, strip out the spacer lug bolts, when you remove them. It's like some kind of horrible chain reaction of destruction caused by extremely cheap manufacturing and little, or no, quality checks. They really are horribly manufactured. I cannot see that anything was measured, or checked for proper fit by the manufacturer prior to mass marketing.
Thank you Rough Country for costing me hours of bolt replacement. Luckily my Gorilla Stainless Steel Lug Nuts are backed by a lifetime warranty against anything stripping them out. Even your trashy, wrong sized wheel spacer lug bolts.
Sincerely,
bajafreak
