Optima Red Top Reviews, Ratings, Specs & Prices
Review Categories
Armor
  Bumpers
  Differential Guards
  Rocker Guards
  Roll Cages
  Skid Plates
Audio, CB, & Electrical
  Audio Players
  Batteries
  CB & Ham Radios
  GPS
  Speakers
Axles
  Axle Shafts
  Brakes
  Gears
  Hubs
  Lockers
  Steering
Body
  Body Lifts
  Consoles, Security & Storage
  Exterior Accessories
  Fender Flares
  Lighting, Lenses & Bulbs
  Roof Racks & Cargo Areas
  Tops
Engine
  Alternators
  Carburetors
  Chips
  Exhaust
  Headers
  Induction
  Internal Parts
  Motor Mounts
  Starters
  Throttle Body
Interior
  Gauges
  Misc
  Seats
Recovery
  Winch Cable and Hooks
  Winches
Suspension
  Complete Lift Kits
  Control Arms
  Shocks
  Springs
  Steering Stabilizers
  Track Bars
Tires & Wheels
  Tires
  Wheels
Transfer Case
  SYE Kits
  Transfer Cases
Transmissions
  Transmissions
Batteries Next Product
Optima Red Top
Rating:
Product Information
MSRP: $280.00
Average Price: $155.40
Manufacturer: Optima
Recommended?
Yes: 130 / No: 3
Lasts up to 2 times longer than other batteries.
More power in the initial 1, 3, 5, and 10 seconds of the starting process than comparably rated conventional lead acid batteries.
Constant performance quality keeping your battery running at the same level even as it's being discharged.
Ideal for seasonal use, fully charged, it can sit unused for up to 12 months at room temperature (or below) and still start a car.
15 times more resistant to vibration than other batteries.
Nonspillable and can mount in almost any position.
None
Page 4 of 7 1 2 3 4 5 6 7 > Last
Lucky99
Lucky99's Reviews
09-27-2009, 10:28 AM
Price: $167.14
Pros: easy to install...
Cons: none yet...
Recommended? Yes
Comments: So far so good, it came with alot of different adapters for various applications, found the right 1 and saved the rest for when & if I ever relocate the battery.
Deezelweazel
Deezelweazel's Reviews
09-05-2009, 02:29 PM
Price: $110.00
Pros: extremely good cold starting behaviour
Cons: only a few sizes
Recommended? Yes
Comments: The Red Top is now the second Optima battery. The first one is eight years old and still in service in the daily used commuter car. I needed a battery capable to deliver enough current to heat the glow plugs and crank the starter. To start the engine you only need to try once. The Red Top delivers an unbelievable amount of power even in the cold.
The capacity is a little bit small to power accessories like the aux engine and cab heater which consumes a lot of amps, but I can add a second battery anytime, if feel the need to do.
The dual posts allow a very clear connection of all accessories.
Top brand!
omegacab
omegacab's Reviews
07-06-2009, 08:08 PM
Price: $160.00
Pros: reliable runs my off road lights
Cons: none yet optima has never failed me
Recommended? Yes
Comments: currently have the red top have 6 off road lights it can run 4 at one time with no problems. also runs my winch fine. would definatly recommend these batteries to anyone that plans on running any lights of winch
tx_medic
tx_medic's Reviews
06-05-2009, 06:49 PM
Price: $179.00
Pros: 1000 CCA
Cons: none yet
Recommended? Yes
Comments: I have two of these batteries, one came to me for free with a trade on some non-jeep related stuff. I'll be very happy once I get the two of them wired up. Have to build a tray first!
On the one that is hooked up, I haven't had a problem yet.
PoopFaceKillah
PoopFaceKillah's Reviews
06-03-2009, 06:30 PM
Price: $160.00
Pros: great battery, high CCA and CA. starts the Jeep and wont leak
Cons: $$$
Recommended? Yes
Comments: Spiral core technology with leak proof case sounds good to me. I was in the market for a new battery and decided to do it right rather that cheaply.
MatthewCase
MatthewCase's Reviews
05-26-2009, 04:06 PM
Price: $150.00
Pros: Great CCA especially for ND winters
Cons: none
Recommended? Yes
Comments: Great Battery
IDArmyTJ
IDArmyTJ's Reviews
05-19-2009, 12:37 AM
Price: $165.00
Pros: Withstands potholes and vibrations from bad roads.
Cons: If it dies, needs high amp recharge or it will take forever (some think it is bad at that point).
Recommended? Yes
Comments: I live in pothole, ID. My old battery started leaking in less than 3 years cause of all the pot holes and bad roads. I'm told that this is a higher cold crank amps than factory. I have not had any problems so far, and it seems to crank right over.
1996BlackXJ
1996BlackXJ's Reviews
05-10-2009, 08:51 PM
Price: $140.00
Pros: 800 cold cranking amps
Cons: Doesn't fit exactly in the stock tray but it still fits fine.
Recommended? Yes
Comments: I haven't had it long but I will update when I get more use out of it.
Bought it at Sam's Club for $140 which is $20 cheaper than online, so if you shop at Sam's Club, buy it there.
laxin4life23
laxin4life23's Reviews
03-24-2009, 08:47 PM
Optima Red Top
Recommended? Yes
Comments: Great so far, have had no problems. Thinking about getting another to put on the ride somewhere.
LostJeeper
LostJeeper's Reviews
02-22-2009, 09:23 AM
Optima Red Top
Price: $99.99
Recommended? Yes
Comments: I love this batterie When my altenotor died in my jeep I was able to make the 2 hour drive home recharge it and was been working ever since
tupton
tupton's Reviews
02-10-2009, 10:12 PM
Optima Red Top
Price: $130.00
Recommended? Yes
Comments: My optima has been great so far. No problems. Handles all my electrical with no issue.
87blackjeep
87blackjeep's Reviews
01-30-2009, 10:31 PM
Optima Red Top
Price: $120.00
Recommended? Yes
Comments: best battery bar none have them in my boat in my other vehichles none better
jjmiller81
jjmiller81's Reviews
01-21-2009, 04:40 PM
Optima Red Top
Price: $100.00
Recommended? Yes
Comments: very good in cold
Steve2237
Steve2237's Reviews
01-21-2009, 11:47 AM
Optima Red Top
Price: $100.00
Recommended? Yes
Comments: 3 years old, great product, always starts............................................ .................................................. .................................................. ..................................
Flynraider
Flynraider's Reviews
01-17-2009, 09:09 AM
Optima Red Top
Price: $100.00
Recommended? Yes
Comments: What can i say, Optima is the best! My heep has a short that causes it to run batteries down while sitting, but a few minutes on the charger and this baby is as good as new!
JerseyWJ
JerseyWJ's Reviews
01-13-2009, 09:46 AM
Optima Red Top
Price: $80.00
Recommended? Yes
Comments: It's good
Jumphog
Jumphog's Reviews
01-01-2009, 10:53 AM
Optima Red Top
Price: $140.00
Recommended? Yes
Comments: Great battery! I especially like the twin terminals as I can hook up my starter (lower terminals), and my winch (upper terminals). I think it or a yellow top are perfect Jeep batteries, especially if you have a winch.
country_boy454
country_boy454's Reviews
12-28-2008, 10:06 AM
Optima Red Top
Price: $100.00
Recommended? Yes
Comments: Great battery for cold weather starting. Also good if you accidentally leave your dome light on all night long then come outside in the morning to go to work and notice it and are like ****. Get in and vehicle starts right up!
Lambo3244
Lambo3244's Reviews
12-23-2008, 02:07 AM
Optima Red Top
Price: $150.00
Recommended? Yes
Comments: I needed a battery that wouldn't let me down even if I was winching with all my lights on. It has done a great job holding up everything my jeep needs. Get a red top!
h0tr0d
h0tr0d's Reviews
12-05-2008, 02:18 PM
Optima Red Top
Price: $200.00
Recommended? Yes
Comments: Great product. No problems. Just what you need for an off road vehicle. I would buy one again
ThreadForumRepliesLast Post
Optima Yellow Top Batteries 131 04-27-2016 08:34 AM
Optima Blue Top Batteries 21 01-27-2012 10:59 AM
