Deka - Intimidator Reviews, Ratings, Specs & Prices
Review Categories
Armor
  Bumpers
  Differential Guards
  Rocker Guards
  Roll Cages
  Skid Plates
Audio, CB, & Electrical
  Audio Players
  Batteries
  CB & Ham Radios
  GPS
  Speakers
Axles
  Axle Shafts
  Brakes
  Gears
  Hubs
  Lockers
  Steering
Body
  Body Lifts
  Consoles, Security & Storage
  Exterior Accessories
  Fender Flares
  Lighting, Lenses & Bulbs
  Roof Racks & Cargo Areas
  Tops
Engine
  Alternators
  Carburetors
  Chips
  Exhaust
  Headers
  Induction
  Internal Parts
  Motor Mounts
  Starters
  Throttle Body
Interior
  Gauges
  Misc
  Seats
Recovery
  Winch Cable and Hooks
  Winches
Suspension
  Complete Lift Kits
  Control Arms
  Shocks
  Springs
  Steering Stabilizers
  Track Bars
Tires & Wheels
  Tires
  Wheels
Transfer Case
  SYE Kits
  Transfer Cases
Transmissions
  Transmissions
Previous Product Batteries Next Product
Deka - Intimidator
Rating:
Product Information
MSRP: $195.00
Average Price: $175.00
Manufacturer: Deka
Recommended?
Yes: 1 / No: 0
Company Website: http://www.eastpenn-deka.com
Deka Intimidator
9A78
The Deka Intimidator's tight-pack plate and separator absorbed glass mat construction provides added power for resistance against hard-hitting stereo systems, competitive racing or off-road wear and tear vibration. Along with a more efficient design, the Deka Intimidator has the same case/cover configuration used by original equipment manufacturers for an easier fit into more applications. No elaborate marketing gimmicks or hold-down retrofits, just decades of experience to provide a better fit, more power and long life.
Features:
100% Maintenance-free eliminates need to check fluid levels
Electrolyte absorbed by micro-porous glass separators eliminates acid spills and terminal corrosion
Tightly "Packed" construction and calcium reinforced grids provide greater resistance to shock and vibration
Provides plenty of starting power at lower temperatures
True maintenance-free performance means longer life with hassle-free service
Superb dual purpose design delivers excellent starting and accessory power, perfect for auxiliary lighting, car audio and video
Highly porous separators lowers resistance and increases power
Specifications:
Group Size: 78
Warranty: 72 Month
Chemistry: AGM
Cold Cranking Amps: 785
Cranking Amps: 970
Reserve Capacity: 120
Amp Hour Rate: 55
Weight: 42.5 lbs
Dimensions: 10.75"x7"x8"
Length: 10.75"
Width: 6 7/8"
Height: 8"
None
VanBCguy
VanBCguy's Reviews
10-24-2009, 02:01 PM
Price: $175.00
Pros: Same technology as the old Optima and the Odyssey/Sears Diehard Platinum but far cheaper (in Canada at least).
Cons: None
Recommended? Yes
Comments: High CC, Reserve, same technology as all the other leading batteries of this technology but far cheaper and well made. Uses side to side, top to bottom space for the packs instead of wasting space like the Optima. Same as the Odyssey/Sears Diehard Platinum, but those weren't available in Canada. This was cheaper too. I can't say enough good things about it.
Made by East Penn but not branded as such so the price stays low because of no advertising. Definitely the last battery type I buy.
Dec. 1st/2013
New Jeep, high power draw, new Deka and no issues. Wonderful as usual.
