Notices
Quadratec (supplier unnamed) exclusive - Subwoofer, replacement for Wrangler center console Reviews, Ratings, Specs & Prices
Review Categories
Armor
  Bumpers
  Differential Guards
  Rocker Guards
  Roll Cages
  Skid Plates
Audio, CB, & Electrical
  Audio Players
  Batteries
  CB & Ham Radios
  GPS
  Speakers
Axles
  Axle Shafts
  Brakes
  Gears
  Hubs
  Lockers
  Steering
Body
  Body Lifts
  Consoles, Security & Storage
  Exterior Accessories
  Fender Flares
  Lighting, Lenses & Bulbs
  Roof Racks & Cargo Areas
  Tops
Engine
  Alternators
  Carburetors
  Chips
  Exhaust
  Headers
  Induction
  Internal Parts
  Motor Mounts
  Starters
  Throttle Body
Interior
  Gauges
  Misc
  Seats
Recovery
  Winch Cable and Hooks
  Winches
Suspension
  Complete Lift Kits
  Control Arms
  Shocks
  Springs
  Steering Stabilizers
  Track Bars
Tires & Wheels
  Tires
  Wheels
Transfer Case
  SYE Kits
  Transfer Cases
Transmissions
  Transmissions
Previous Product Speakers Next Product
Rating:
Product Information
MSRP: $89.99
Average Price: $105.60
Manufacturer: Quadratec (supplier unnamed) exclusive
Recommended?
Yes: 4 / No: 1
Company Website: http://www.quadratec.com
http://www.quadratec.com/products/14133_1001.htm
This is an exact fit, exact spec aftermarket speaker for the Jeep Wrangler center console subwoofer that is fitted in the subwoofer amp box inside the console.
I just installed a new subwoofer speaker from quadratec last weekend. it's a perfect match and fit, in the space as well as wiring.
quadratec has an exclusive on the speaker. i don't recall the brand name on the speaker magnet, if there was one.
Quadratec part number 14133.1001 $89.99.
it's worth it. swaping the speaker out of the subwoofer unit took about 20minutes... the speaker swap took about 5 minutes. no cutting, grinding, jury rigging wiring, swearing and sweating.
The speaker is made of much better weather resistant and long lasting material. wire connections are exactly the same as the original.
and it sounds great.
don't mess with buying a new speaker unit from the dealer or another supplier. 2 reasons:
1) I paid $$$ for a whole new OEM boom box assembly, the week before Quadratec released their new speaker product. the electrical connector of the new subwoofer unit may be different. My Sahara connector has a connector with about 16 or 18 pins in it. I paid a high price for an OEM Jeep subwoofer box unit ( a week before quadratec came out with the new speaker) and the plug on it did NOT match my Jeep wiring!!!! It only had about 8 pins in the connector.
2) old OEM parts are going to be OLD and the same lousy material as the original speaker. I doubt any new old stock replacement from Jeep will last long.
Only one comment on the product. Don't push too hard fitting your box wires onto the spade connectors on the speaker. They are a bit thin and if you fit the connectors too tightly and push too hard, the connectors can bend. start with a looser fit and tighten them up so they slide on tight but not excesively.
my old speaker was SHOT. it was separated all the way around to the speaker mount. No wonder it sounded like "crud".
by the way, to take out your center console you will only need a 13mm socket and a T30 torx.. The 13mm socket works on the front cup holder bolt
None
Bootch
Bootch's Reviews
08-10-2015, 02:03 PM
Price: $90.00
Pros: Excellent Sound (for what it is and the box it's in). Easy replacement of stock POS speaker.
Cons: None - if you want louder better sounding bass you'll need to have a custom box and larger sub.
Recommended? Yes
Comments: I do most of my audio shopping on Crutchfield but couldn't find a sub that would fit in the stock center console. When I bought my TJ used last year the sub was blown of course. I didn't want a "high schooler" bass system but I do enjoy having a little bump and this speaker from Quadratec does the trick. It can get loud and it pretty responsive when listening to rock or whatever. Direct replacement is a piece of cake. Tricky thing is getting the wire harness unplugged when removing the center console. After that you're off to the races!
UptownTJ
UptownTJ's Reviews
04-06-2014, 09:25 AM
Price: $89.00
Pros: Stock fit
Cons: Not huge improvement
Recommended? No
Comments: spent $89 on a marginal improvement
KGsTJ
KGsTJ's Reviews
11-12-2012, 12:05 PM
Price: $100.00
Pros: no hassle swap sounds awesome
Cons: none
Recommended? Yes
Comments: Replaced all speakers with Quadratec's exclusive replacements and added the super tweeters....... Stock radio and this Jeep rocks!
http://www.quadratec.com/showcases/q...o_electronics/
KGsTJ
KGsTJ's Reviews
11-12-2012, 11:59 AM
Price: $100.00
Pros: sounds awesome no hassle swap out
Cons: none
Recommended? Yes
Comments: I started out by replacing the sub speaker and ended up replacing sound bar and dash speakers along with adding the super tweeters. All are made for Quadratec by Kicker. This upgrade is well worth it.....the stock speakers are junk. Make sure you do the tweeter upgrade....brings the whole thing to life. Also kept the stock radio in the jeep.
gary01
gary01's Reviews
11-18-2011, 02:09 PM
Price: $149.00
Pros: Great fit
Cons: just have to run wire.
Recommended? Yes
Comments: Bought this with out the amp/speaker and got those at partsexpress. saved a few $'s and got to pick a better speaker. Product fits great and is just what is needed to fill in the lowend on your dash/bar speakers. You will not thump down the road with a 8" speaker but it blends very well with the dash speakers making them sound like 6x9's and not 4x6's.
ThreadForumRepliesLast Post
Kicker 6.5" Subwoofer CompVT 08CVT652 Speakers 14 04-27-2016 08:38 AM
JL Audio 10W7 Subwoofer Speakers 8 09-10-2012 10:00 AM
Pioneer 12" 800W Subwoofer Speakers 3 12-13-2010 11:10 AM
Pioneer 12" 1000W subwoofer Speakers 6 01-31-2010 03:33 PM
Fusion NV 12" HD Subwoofer Speakers 1 06-29-2008 10:44 AM
