Go Back JeepForum.com > Reviews > Audio, CB, & Electrical > Speakers > Polk Audio MMC 525 Polk Momo
Rock Krawler Suspension's for BLOW OUT prices!!!Great deals on Mickey Thompson Tires @ Jeephut.comRCV Heavy Duty Axle Shafts Now Shipping at Baseline4x4.com
Polk Audio MMC 525 Polk Momo Reviews, Ratings, Specs & Prices
Review Categories
Armor
  Bumpers
  Differential Guards
  Rocker Guards
  Roll Cages
  Skid Plates
  Audio Players
  Batteries
  CB & HAM Radios
  GPS
  Speakers
Axles
  Axle Shafts
  Brakes
  Gears
  Hubs
  Lockers
  Steering
Body
  Body Lifts
  Consoles, Security & Storage
  Exterior Accessories
  Fender Flares
  Lighting, Lenses & Bulbs
  Roof Racks & Cargo Areas
  Tops
Engine
  Alternators
  Carburetors
  Chips
  Exhaust
  Headers
  Induction
  Internal Parts
  Motor Mounts
  Starters
  Throttle Body
Interior
  Gauges
  Misc
  Seats
Recovery
  Winch Cable and Hooks
  Winches
Suspension
  Complete Lift Kits
  Control Arms
  Shocks
  Springs
  Steering Stabilizers
  Track Bars
Tires & Wheels
  Tires
  Wheels
Transfer Case
  SYE Kits
  Transfer Cases
Transmissions
  Transmissions
Previous Product Speakers Next Product
Rating:
Product Information
MSRP: $100.00
Average Price: $110.78
Manufacturer: Polk Audio
Recommended?
Yes: 9 / No: 1
Polk Audio engineers the MMC Series speakers for championship performance — legendary Italian design firm MOMO makes them look great! These upper-echelon coaxial speakers deliver component speaker sound quality in an easy-to-install, stylish package.
The Polk/MOMO MMC525 5-1/4" speaker features a lacquered carbon-fiber woofer that provides the ideal balance of low weight and high rigidity. The woofer's Kapton voice coil former and flat Nomex spider contribute to high power handling capability. An airtight rubber surround stands up to humidity and heat for long-term reliability. The smooth-sounding 1" silk/polymer dome tweeter swivels up to 15° for direct, detailed imaging.
Uruloki
Uruloki's Reviews
07-22-2011, 05:50 PM
Price: $180.00
Pros: Power handling. Style. Installation and instructions.
Cons: Bass. Crossover size. Crossover terminals. No inline crossover (Need the crossover box)
Recommended? Yes
Comments: POLK MM5251 component set. Slightly different than the MMC 525!!!
They are 5.25" woofers... so don't expect to rock your neighbors. Expect nice, mid level punch.
In hindsight I would buy the MM6501 set instead and buy a spacer ring or the 6x9 component set.
Regardless because my plans were to have woofers in the rear doors, I opted for these for more mids and highs up front and bass from the back.
The crossover is a little large, but that means it's a little beefy on the electronic side (I hope). I just laid them under the rear seat where the old factory amp was.
For integration into a factory Infinity system I would not recommend these unless you plan on drilling into your door panels. The tweeters are not rated for being supplied power without the freq. cutout from the crossover. So you'd have to get a set of 2.5s for the dash.
This is because the stock amp splits the front signal into 4 channels vice 2 and sends respective freq(s) on to the speakers. Perhaps an email to Polk could tell you if you can run the speakers off the factory amp without the crossover...
I rated 5 stars for the product. Though I would like to make it 3.5 of 5 for installation and use in a WJ.
99SprintST
99SprintST's Reviews
11-16-2010, 04:07 PM
Price: $120.00
Pros: Marine grade, weather resistant
Cons: none
Recommended? Yes
Comments: Used with adapter plates in the front and in the soundbar in the rear. Price was per pair. Great sound when coupled to a 200W amp. Have been running these for 2 years without issue and would buy Polks again without reservations. Purchased mine from Crutchfield for a great price which included wiring harness/adapters.
Demp
Demp's Reviews
04-09-2010, 11:33 PM
Price: $68.00
Pros: Carbon fiber Cone, Marine grade, Excellent response.
Cons: Required a customized bracket to fit the front 4x6 slot, not difficult
Recommended? Yes
Comments: Located in the front 4x6 brackets with customized brackets to hold them. The set includes a crossover that is fairly small and easily installed in the dash behind the speaker. Running these at ~75W RMS, easily loud enough to hear over road noise with the top and doors off.
blackdragonfish
blackdragonfish's Reviews
07-11-2009, 12:22 AM
Price: $139.99
Pros: Water resistant Easy To Install Each Speaker comes with its own individual Amplifier and Tweeter
Cons: Not water proof
Recommended? Yes
Comments: These puppies just slide on in to your where your old speakers in your soundbar are. They come with individual amplifiers which (I don't recommend doing this) I just toss into the soundbar its self. Important keep the original screws speakers do not come with any. The speakers also have tweeters that sit in the middle of the speaker. These are adjustable however i have gone off roading far to many times with the top down and sand has gotten in to mine so they no longer move.
enebo
enebo's Reviews
02-14-2009, 06:50 AM
Recommended? Yes
Comments: Sound awesome, Fit a little funny on the back hatch. the top portion is a little to deep for it to fit the hatch without modification but you cant tell with the interior panel covering them.
Almost need rear tweeters now though.
raheafner
raheafner's Reviews
01-05-2009, 05:36 AM
Price: $89.00
Recommended? Yes
Comments: Excellent speakers. Marine capabilities. Installed in rollbar pods. Adjustable tweeters. Great mids. Sounds great with factory subwoofer. Ebay baby...
Bad_Dog
Bad_Dog's Reviews
09-18-2008, 11:29 AM
Price: $100.00
Recommended? Yes
Comments: VERY clean sound! I'm an audiophile, so I really wanted good speakers for the fronts. A pain to install, but that's not the fault of the speaker. Obviously, no low end, but very clean highs and good mids.
Chewie4299
Chewie4299's Reviews
08-10-2008, 08:07 PM
Price: $100.00
Recommended? Yes
Comments: Nothing to compare it to in the Jeep but they are a great speaker for the money.
Sterner09
Sterner09's Reviews
07-19-2008, 03:29 PM
Price: $100.00
Recommended? No
Comments: I bought these with thinking they would be the best thing out there, boy was i mistaken i honestly believe the stock speakers are better then these.
RobFromRI
RobFromRI's Reviews
07-13-2008, 02:37 PM
Price: $99.99
Recommended? Yes
Comments: Polk Audio engineers the MMC Series speakers for championship performance — legendary Italian design firm MOMO makes them look great! These upper-echelon coaxial speakers deliver component speaker sound quality in an easy-to-install, stylish package.
ThreadForumRepliesLast Post
polk audio db525....5-1/4 Speakers 25 01-26-2011 11:42 AM
Polk Audio - db521 5 1/4" Car Audio Speaker Speakers 1 02-03-2010 08:32 PM
Polk Audio DB650DB Speakers 4 02-26-2009 08:44 PM
Polk Audio DB5250 Speakers 6 02-15-2009 10:57 PM
Polk Audio MMC460 Speakers 6 08-10-2008 08:08 PM
Glock Forum
