Go Back JeepForum.com > Reviews > Audio, CB, & Electrical > Speakers > Alpine - SWR-T10 Type R
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineGenRight Offroad at CCOR! 706-207-4140Ring & Pinion's, Lockers, 4340 Axles, Install Kits, Ba
Alpine - SWR-T10 Type R Reviews, Ratings, Specs & Prices
Review Categories
Armor
  Bumpers
  Differential Guards
  Rocker Guards
  Roll Cages
  Skid Plates
  Audio Players
  Batteries
  CB & HAM Radios
  GPS
  Speakers
Axles
  Axle Shafts
  Brakes
  Gears
  Hubs
  Lockers
  Steering
Body
  Body Lifts
  Consoles, Security & Storage
  Exterior Accessories
  Fender Flares
  Lighting, Lenses & Bulbs
  Roof Racks & Cargo Areas
  Tops
Engine
  Alternators
  Carburetors
  Chips
  Exhaust
  Headers
  Induction
  Internal Parts
  Motor Mounts
  Starters
  Throttle Body
Interior
  Gauges
  Misc
  Seats
Recovery
  Winch Cable and Hooks
  Winches
Suspension
  Complete Lift Kits
  Control Arms
  Shocks
  Springs
  Steering Stabilizers
  Track Bars
Tires & Wheels
  Tires
  Wheels
Transfer Case
  SYE Kits
  Transfer Cases
Transmissions
  Transmissions
Previous Product Speakers
Rating: None
Product Information
MSRP: $650.00
Average Price: $320.00
Manufacturer: Alpine
Recommended?
Yes: 1 / No: 0
Company Website: http://www.alpine-usa.com
SWR-T10 10" Thin Subwoofer (4Ω)
Features and Specification
Power HandlingCEA-2031 Power Rating: 600W
Power Range: 300 - 600 Watts
RMS Power Handling: 600W
Peak Power Handling: 1800W
DimensionsMounting Depth: 82 mm (3.25'')
Mounting Diameter: 231 mm (9.1'')
Displacement: 0.07 cu. ft (Front Mount)
Added Volume: 0.04 cu. ft. (Reverse Mount, Magnet Out)
GeneralFrequency Response: 28Hz - 200Hz
FEATURES
DiaphramMaterial: Aluminum
Design: Structural Parabolic w/ Force Transfer Assembly
SurroundMaterial: Injected Molded Santoprene
Design: FEA-Optimized High Amplitude Mutli-Roll (H.A.M.R.) (Patent Pending)
SpiderMaterial: Thermoplastic Elastomer (TPE)
Design: Co-Molded Regressive w/ Integrated Tinsel Leads
Voice CoilMaterial: 220C Edge-Wound Copper Ribbon Wire
Design: Oversized 100mm (4'') Underhung Voice Coil
Motor StructurePole Geometry: FEA-Optimized Dual Compound Radius Curve w/ Pass Through Gap Design (Patent #6,639,993, 2 Patents Pending)
Configuration: Radial Vented VC Heat Sink & Shorting Sleeve w/ Airflow Management System (Patent 7,634,101)
FrameMaterial: Cast Aluminum
Design: Direct-Couple Shorting Sleeve/Heatsink and Frame Design
TerminalsLayout: One Side
Design: Heavy Duty Gold-Plated Insert Block Terminals
Tinsel LeadsDesign: Woven Spider Integration Design
GasketDesign: Concealed Mount Gasket System (US Patent #7,760,900)
None
bbusch
bbusch's Reviews
02-19-2013, 09:33 PM
Price: $320.00
Pros: Only 3.25" in depth, proven design that performs as advertised
Cons: none
Recommended? Yes
Comments: Great compact sub allowing Wrangler owners options for mounting in tighter configurations. I mounted my SWR T10 subwoofer in a Sierra Mountain Enterprise Slimline Subwoofer Console and am very impressed with the all around performance the sub puts out with only .43 cuft, even low end bass is there which is surprising out of a thin/slim sub.
Jeep Parts at Andy's
