Alpine SPS-406 4x6" Coaxial 2-Way Speaker Set
Product Information
Overview
* • Great sounding upgrade speakers at competitive price points
* • Perfect for OEM upgrade, with many sizes to choose from to suit almost any vehicle. New cosmetics look good in your car, and fit easily in your stock
* • Improve the output and sound quality of your vehicle with these highly efficient speaker choices
* • High efficiency design runs easily off of factory or built-in head unit power for an easy system upgrade
The perfect sound solution upgrade. Introducing the 2008 Type-S speaker line up, with multiple size options to fit almost any vehicle. If you want to add incredible sounding Alpine speakers to your system, this is the way to go. This latest offering from the popular Type-S family of speakers is a best bet upgrade, and still budget-friendly.
Assorted Sizes, Versatile Upgrade
With seven models in the Type-S line-up, you’ll find a speaker size to fit your car’s needs – and easily install into your stock speaker locations. A shallow mounting design allows for easy installation in a wide range of door panels giving you a perfect fit. Their high-efficiency design can run off of the built-in amplifier power from the factory or Alpine head unit, resulting in an easy system improvement for any vehicle.
Packing a Punch
Turn up the volume. These speakers deliver amazing lows, mids, and highs. Become a believer once you hear the difference between stock and Alpine sound quality. Upgrade your system and see what you’ve been missing.
Silk Dome Swivel Tweeters
The Type-S coaxial speakers use a soft dome silk tweeter for excellent high frequency sound reproduction. The tweeters can swivel up to 10 degrees so you can adjust for the optimum listening position.
firemerc99's Reviews
Price: $1.00 Pros: much better sound than the stock speakers Cons: a little harder to install, but worth it. Recommended? Yes
Comments: these were a little harder to install than the rear. Had to do a little cutting of the speaker box, but once installed, they were perfect. It even gave me a chance to install accent lights behind the speaker grills
jbozz17's Reviews
Price: $120.00 Pros: Excelent sound quality Cons: None Recommended? Yes
Comments: These speakers are a high quality speaker and great sound
jerseyjeep22's Reviews
Price: $75.00 Pros: Great Sound Cons: none Recommended? Yes
Comments: Definitly a great buy for the money. I got two 4x6's to replace the factory speakers in the dash and they made a huge difference in sound quality. Only problem was the universal mounting brackets i had to buy were a bit tricky to install. Other than that no problems, great product.
rocknjeep's Reviews
Price: $90.00 Pros: They get the job done. Cons: can't think of any Recommended? Yes
Comments: Great upgrade to the stock speakers. They really deliver sound clearly. Had they made a type R in this size I would have gotten them but the S isn't bad either. They sound great and take the high volume. Alpine rules.
