Yaesu - Vx-8 Reviews, Ratings, Specs & Prices
Review Categories
Armor
  Bumpers
  Differential Guards
  Rocker Guards
  Roll Cages
  Skid Plates
Audio, CB, & Electrical
  Audio Players
  Batteries
  CB & Ham Radios
  GPS
  Speakers
Axles
  Axle Shafts
  Brakes
  Gears
  Hubs
  Lockers
  Steering
Body
  Body Lifts
  Consoles, Security & Storage
  Exterior Accessories
  Fender Flares
  Lighting, Lenses & Bulbs
  Roof Racks & Cargo Areas
  Tops
Engine
  Alternators
  Carburetors
  Chips
  Exhaust
  Headers
  Induction
  Internal Parts
  Motor Mounts
  Starters
  Throttle Body
Interior
  Gauges
  Misc
  Seats
Recovery
  Winch Cable and Hooks
  Winches
Suspension
  Complete Lift Kits
  Control Arms
  Shocks
  Springs
  Steering Stabilizers
  Track Bars
Tires & Wheels
  Tires
  Wheels
Transfer Case
  SYE Kits
  Transfer Cases
Transmissions
  Transmissions
Previous Product CB & Ham Radios Next Product
Yaesu - Vx-8
Rating:
Product Information
MSRP: $400.00
Average Price: $273.67
Manufacturer: Yaesu
Recommended?
Yes: 3 / No: 0
Company Website: http://www.yaesu.com
The Yaesu VX-8R HT provides a full 5 watts FM on 50/144/430 MHz plus 1.5 watts on 222 MHz. It supports Bluetooth® hands-free operation with the optional BU-1 and BH-1 or BH-2 accessories. There is also an optional GPS unit and antenna with loads of features. This radio supports APRS 1200/9600 bps data communication (B band only). Like the VX7R, the VX8R is submersible and meets IPX57 specifications (3 feet for minimum of 30 minutes). A powerful 7.4 V 1100 mAh Lithium Ion battery is included. This HT is small, intuitive to operate only 2.36 x 3.74 x 0.92 inches (thinner than VX-7R). It supports simultaneous independent 2-signal dual receive function with both V + V or U + U. It has weather band receive with Weather Alert. A barometric sensor is included. You can even operate Amateur radio while receiving FM broadcasts! The receive coverage is wider than VX-7R, with an independent AM/FM broadcast receiver circuit. The dot matrix LCD display provides Memory tag up to a maximum of 16 characters. You even get a high-resolution Spectrum Analyzer with ±60 channels indication with wave monitoring of received/modulated signal! And DCS and CTCSS encode and decode is standard.
None
bigblueishness
bigblueishness's Reviews
05-05-2010, 12:19 AM
Price: $1.00
Pros: 1
Cons: 1
Recommended? Yes
Comments: 11
darg
darg's Reviews
01-13-2010, 08:33 PM
Price: $450.00
Pros: Extreme versatile and small HT unit. Good power output and it has everything you need to be uptodate in regard to HAM and the Technician class license.
Cons: not for large hands.
Recommended? Yes
Comments: This baby can do everything you can do as a licensed Technician HAM for reasonable price. I would call it the IPhone for HAMs :-) Coupled with a good triple-band external antenna you get a nice range in and out, the rubber ducky is OK but there are better out for hiking applications. I still need the GPS antenna but that comes next times.
CrazyCooter
CrazyCooter's Reviews
11-19-2009, 11:43 PM
Price: $370.00
Pros: Lots of features. Dual VFO's rock! APRS built in, just add GPS antenna. Plenty of characters to name your memory presets for easy finding later. Everything is menu driven, so it is easy once you get familiar with the terms.
Cons: Takes a bit to learn and get used to. Costs a too much to have bouncing around in a Jeep off road.
Recommended? Yes
Comments: I bought this HT as a newly licensed HAM. I like to make sure I grow into a radio instead of grow out of one. This VX8R fits the bill! Does almost anything anyone could want from an HT and more! Dual VFO's allow you to monitor two freq's at the same time. Takes a little time to get used to, but once you get the hang of the lingo and menus, you will be a pro. Does 144/70/6 bands full 5w power and 1.25cm 1.5w. OE battery is a little small. I couldn't get a full 8hr day out of it. The larger battery gts 12 hrs easy.
I would recomend this radio to anyone who is a gadget geek like me. If you want simple and economical.....go for the ft60r.
73's
Tony
KI6WAO
ThreadForumRepliesLast Post
Yaesu FT 857D CB & Ham Radios 13 09-28-2016 01:51 PM
Yaesu FT-7100 CB & Ham Radios 3 02-03-2014 07:00 PM
Yaesu FT7800R CB & Ham Radios 13 11-03-2013 12:27 AM
Yaesu - Vx-6r CB & Ham Radios 2 04-22-2011 08:26 AM
Yaesu FT-1802M CB & Ham Radios 5 06-01-2010 11:52 AM
