Midland Radio 75-822 Reviews, Ratings, Specs & Prices
Review Categories
Armor
  Bumpers
  Differential Guards
  Rocker Guards
  Roll Cages
  Skid Plates
Audio, CB, & Electrical
  Audio Players
  Batteries
  CB & Ham Radios
  GPS
  Speakers
Axles
  Axle Shafts
  Brakes
  Gears
  Hubs
  Lockers
  Steering
Body
  Body Lifts
  Consoles, Security & Storage
  Exterior Accessories
  Fender Flares
  Lighting, Lenses & Bulbs
  Roof Racks & Cargo Areas
  Tops
Engine
  Alternators
  Carburetors
  Chips
  Exhaust
  Headers
  Induction
  Internal Parts
  Motor Mounts
  Starters
  Throttle Body
Interior
  Gauges
  Misc
  Seats
Recovery
  Winch Cable and Hooks
  Winches
Suspension
  Complete Lift Kits
  Control Arms
  Shocks
  Springs
  Steering Stabilizers
  Track Bars
Tires & Wheels
  Tires
  Wheels
Transfer Case
  SYE Kits
  Transfer Cases
Transmissions
  Transmissions
Previous Product CB & Ham Radios Next Product
Rating:
Product Information
MSRP: $1,000.00
Average Price: $83.61
Manufacturer: Midland Radio
Recommended?
Yes: 52 / No: 2
* 40 Channels
* Large LCD Readout
* Built in 10 Channel Weather
* Instant access to 5 user selectable channels
* Instant access to emergency channel 9
* Keypad lock
* High/Low power setting
* Removable battery case
* Includes 18-821 Mobile Adaptor
None
Page 3 of 3 1 2 3
JeepMammouth
JeepMammouth's Reviews
03-29-2008, 05:51 PM
Price: $75.00
Recommended? Yes
Comments: Nice kit
Jameslol
Jameslol's Reviews
03-28-2008, 11:41 PM
Price: $50.00
Recommended? Yes
Comments: Pretty good cb, small size great sound, picks up pretty good distances with a 4ft
antenna, the pa speaker tends to get knocked out by careless guests is the only problem and the mounting screws are a little lame but still work.
Virginia_LJ
Virginia_LJ's Reviews
03-28-2008, 05:22 PM
Price: $15.00
Recommended? Yes
Comments: Nice CB
Luckyduck
Luckyduck's Reviews
03-21-2008, 05:17 PM
Recommended? Yes
Comments: Kind of old but it works
xjmudbuggy
Newbie
xjmudbuggy's Reviews
03-17-2008, 06:08 PM
Recommended? No
Comments: I don't really have the midland - I have a Radio Crap Unit that I traded a used blender for. Its a piece of junk but does the job.
flyerboy1522
flyerboy1522's Reviews
03-16-2008, 09:56 PM
Price: $25.00
Recommended? Yes
Comments: Ok for a cheap CB I am going to go with a better one though with more options
Clevs
Clevs's Reviews
03-13-2008, 07:55 PM
Recommended? Yes
Comments: Works great when driving with buddies.
Uhvnutn
Uhvnutn's Reviews
03-06-2008, 11:11 PM
Price: $15.00
Recommended? Yes
Comments: It works!
jboom
jboom's Reviews
03-04-2008, 08:50 PM
Recommended? Yes
Comments: good
GodsRollerskate
GodsRollerskate's Reviews
02-28-2008, 03:12 PM
Price: $35.00
Recommended? Yes
Comments: It has the nice PA output....pretty nice I must say.
Munsined
Munsined's Reviews
02-26-2008, 12:37 PM
Price: $100.00
Recommended? Yes
Comments: Minimual space and easy to operate. Would be nice if it stayed lit
Sahara88
Sahara88's Reviews
02-25-2008, 11:46 PM
Price: $22.00
Recommended? Yes
Comments: Bought it used, works well.
Sairys
Sairys's Reviews
08-31-2007, 06:20 AM
Price: $96.38
Pros: Can be used with rubber ducky for short range. Compact and easy to hide in glovebox.
Cons: Some keys are hard to reach and require shifting the unit in your hand while the other is trying to keep the car on the road.
Recommended? Yes
Comments: I picked up this unit because I wanted to be able to stash it in my glove box when I leave the jeep. I was considering the cobra but this one was at wallmart and I figured that if I didn't like it, i could return it.
Needless to say, the cig plug leaves for a lot of noise, and the rubber ducky that comes with it has a very short range. That didn't matter to me since I planned on adding a full size antenna anyway.
After some tinkering, I finally got it set up and "debugged" (user error when installing the antenna). I tested it out on a 9 hour drive from Houghton, MI to Detroit. My experience was pretty good. The speaker on the handset was adequate as long as the top is up or at lower speeds with the top down, but that's understandable. An external speaker would possibly fix this, but I think it's good enough as it stands (at least for me, for now) As I mentioned before, I still have some power noise to filter out and try to get my SWR a bit closer to 1 (or 1.5 for that matter), which added to not being able to hear people talk too well. That said, a good portion of the conversations came clear, and had no problem with not being able to hold up a chat.
So back to what i wanted and what I got. I wanted a radio I can stash away easily, and this is it. I knew ahead of time that I would wire in a bigger antenna and wasn't planning on using this as a pocket radio that I'll run on batt power and the rubber duck. If that's what you're looking for then you'll have to ask someone else. I suspect that with a cleaner power source this radio would be as good as the dash (or wherever) mounted boxes. The weather radio is nifty, but I usually check the forecast online before I make a trip so I don't really use it unless I'm dying to hear a human voice. The scan is works well and the quick 9/19 button works well as in a good position.
The downsides that i've noted were only those of other button placement. The "light" button for the display is just out of the reach of the index finger and thumb, so it requires some manhandling to use. The memory keys are a similar problem. The need to press the F button first makes it odd, but i'm sure with time I'll get used to it. Oh, also the light on the display turns off too fast. It would be nice to be able to keep it on (unless I didn't figure out how to do THAT yet )
So all in all, performance wise I don't really see any issues as long as you do have a real antenna mounted. It's great for space and the cables are yours to run so you can make it as clean or messy as you want. Volume is acceptable but it all depends on the reception you get, which I wouldn't blame the unit for. I would recommend it for anyone that just wants a convenient CB. It's on the more expensive side compared to the 30 dollar ones available, but keep it hidden and it won't get stolen or attract thieves.
P.S. Sorry if i was redundant here, but I still haven't slept after my trip
Page 3 of 3 1 2 3
ThreadForumRepliesLast Post
Midland Radio 1001Z CB & Ham Radios 45 05-16-2014 12:52 AM
Midland 77-805 CB & Ham Radios 2 03-09-2014 09:10 PM
Midland Radio 13-510 CB & Ham Radios 3 01-13-2013 05:15 PM
Midland Radio 79-290 CB & Ham Radios 4 11-24-2009 10:28 AM
Midland 75-785 Batteries 0 04-24-2008 02:07 PM
