Go Back JeepForum.com > Reviews > Audio, CB, & Electrical > CB & HAM Radios > Midland Radio 75-822
Midland Radio 75-822 Reviews, Ratings, Specs & Prices
Review Categories
Armor
  Bumpers
  Differential Guards
  Rocker Guards
  Roll Cages
  Skid Plates
  Audio Players
  Batteries
  CB & HAM Radios
  GPS
  Speakers
Axles
  Axle Shafts
  Brakes
  Gears
  Hubs
  Lockers
  Steering
Body
  Body Lifts
  Consoles, Security & Storage
  Exterior Accessories
  Fender Flares
  Lighting, Lenses & Bulbs
  Roof Racks & Cargo Areas
  Tops
Engine
  Alternators
  Carburetors
  Chips
  Exhaust
  Headers
  Induction
  Internal Parts
  Motor Mounts
  Starters
  Throttle Body
Interior
  Gauges
  Misc
  Seats
Recovery
  Winch Cable and Hooks
  Winches
Suspension
  Complete Lift Kits
  Control Arms
  Shocks
  Springs
  Steering Stabilizers
  Track Bars
Tires & Wheels
  Tires
  Wheels
Transfer Case
  SYE Kits
  Transfer Cases
Transmissions
  Transmissions
Previous Product CB & HAM Radios Next Product
Rating:
Product Information
MSRP: $1,000.00
Average Price: $88.66
Manufacturer: Midland Radio
Recommended?
Yes: 39 / No: 2
* 40 Channels
* Large LCD Readout
* Built in 10 Channel Weather
* Instant access to 5 user selectable channels
* Instant access to emergency channel 9
* Keypad lock
* High/Low power setting
* Removable battery case
* Includes 18-821 Mobile Adaptor
Page 1 of 3 1 2 3 > Last »
fl_gator_chi
fl_gator_chi's Reviews
06-27-2011, 08:37 PM
Price: $75.00
Pros: Compact size
Cons: Mount clip is not standard
Recommended? Yes
Comments: Nice hybrid portable/auto unit. Experience has been limited to use on trails, however has functioned up to expectation.
dougmorgan99
dougmorgan99's Reviews
09-18-2010, 09:16 PM
Price: $79.00
Pros: Compact and easy to use. Can be converted to handheld in a snap!
Cons: Light doesn't stay on when in vehicle mode. Wish it had a spot on the back to add a standard CB mic mount.
Recommended? Yes
Comments: All in all a sound design and doesnt take up too much room when installed. I love the fact that when I go camping I can convert the CB to portable walkie talkie style to monitor NOAA Weather radio.
theSovereign
theSovereign's Reviews
06-23-2010, 02:49 PM
Price: $95.00
Pros: Versatility of mobile using 12v cable and external antenna in-vehicle, as well as portable using rubber ducky antenna and either alkaline or rechargeable battery pack. 10 NOAA Weather Channels. Frequency display by holding down the "F"unction button for 3 seconds. Older models capable of extra channel mods.
Cons: Radios manufactured after April 2010 are no longer capable of the channel mods, but still a good radio for what it is. Comes with a belt clip instead of a standard microphone clip.
Recommended? Yes
Comments: All-in-all I'm very happy with this CB.
I was looking for something that could be used both inside and outside the vehicle, and also had NOAA weather channels (after getting stuck in a rare Oklahoma blizzard I decided this was a must-have). In any case, this was the radio that fit the bill.
So far I've gotten ~0.7 miles range on a peaked & tuned radio using the rubber ducky antenna and the alkaline battery pack, which is actually farther range than I expected. I am still trying to determine maximum range using an external Hustler HQ27 antenna.
I removed the belt clip and modified an old cell phone holder clip to make the radio work attach to a standard CB clip.
JeepAngel34
JeepAngel34's Reviews
04-12-2010, 04:05 PM
Price: $40.00
Pros: handheld no mount necessary
Cons: none yet
Recommended? Yes
Comments: I have not used this product much yet but am looking forward to it. I will update this review once I know more about the product.
TJRUSSELL
TJRUSSELL's Reviews
09-23-2009, 09:35 PM
Price: $90.00
Pros: small and powerfull
Cons: speaker is not so loud
Recommended? Yes
Comments: mounted to the dash with a mic clip and takes up little to no space hooked up to a ext 102" antenna
Ibjeepr
Ibjeepr's Reviews
07-28-2009, 05:05 PM
Price: $100.00
Pros: Small, plugs into cigarette light and external antenna to be mobile or uses rubber duck and batterys to be hand held.
Cons: Back light doesn't stay on if wanted.
Recommended? Yes
Comments: Excellent CB for the purpose I bought it. I wanted something that didn't require a permanent mounting job. This was the perfect solution. I brought an external antenna to the jamboree in case the rubber duck didn't cut it, never needed it. I plugged the CB into the cigarette lighter, plugged the spkr jack into the Aux input of the radio and clipped the CB to the passanger side visor. Worked perfect at the jeep jamboree! Our convoy was short so I may have needed the magnetic external antenna if the line of jeeps was longer but i had no problems and assume the line could have been a lot longer befor there were.
PastorSteve
PastorSteve's Reviews
07-02-2009, 09:30 PM
Price: $100.00
Pros: Great versatile CB that allows me to go from vehicle mounted to portable instantly.
Cons: none.
Recommended? Yes
Comments: This is a great product. Great versatile CB that allows me to go from vehicle mounted to portable instantly.
yoda13
Force Wheeler
yoda13's Reviews
04-02-2009, 02:09 PM
Price: $82.04
Recommended? Yes
Comments: If you add an outside antenna, then the radio is quite good, and you can take it out of the Jeep and make it portable if you hike or whatever, anyway, I am pleased...
bctj
bctj's Reviews
03-06-2009, 05:19 PM
Price: $50.00
Recommended? Yes
Comments: Cheap. short range. Worth the small investment. I wouldnt recommend if your looking for high performance
the_clem87
the_clem87's Reviews
12-29-2008, 11:59 AM
Price: $110.00
Recommended? Yes
Comments: Decent little radio... Volume and Squelch controls only. Nice and compact, bolted to drivers side of transmission tunnel
ckhanna71
ckhanna71's Reviews
12-22-2008, 11:43 AM
Price: $100.00
Recommended? Yes
Comments: Pretty decent CB, Just alittle small and underpowered on range. Small and compact and fits in under the dash nice.
CAwranglertj
CAwranglertj's Reviews
12-03-2008, 10:41 AM
Price: $30.00
Recommended? Yes
Comments: Great little unit, bought an aftermarket antenna mount which installs next to the spare tire.
ZektheJeep
ZektheJeep's Reviews
10-21-2008, 09:09 PM
Price: $200.00
Recommended? Yes
Comments: Old 1970's model I still have. Hey it still works after all these years!It still produces over 5watts and using a Fire-stick for an antenna, I have great communication abiltiy with my group
Hockey1
Hockey1's Reviews
10-13-2008, 08:02 PM
Price: $40.00
Recommended? Yes
Comments: For as inexpensive as it is, it sounds great. I have another one in my WJ. And I am very pleased with its performance.
scotiez
Jeep Addict
scotiez's Reviews
10-11-2008, 11:22 PM
Price: $50.00
Recommended? Yes
Comments: Great CB radio. There isn't much room to mount a cb in a wrangler so the Midland handheld with vehical adaptor works great for this.
Socaljeep1
Socaljeep1's Reviews
07-02-2008, 10:21 PM
Recommended? No
Comments: I'm a trucker so of course I'm used to big CB's. This one is fair. mostly it fits in the overhead console.
kfbagt
kfbagt's Reviews
05-19-2008, 11:01 AM
Price: $39.00
Recommended? Yes
Comments: A great radio for the money. Not too many features but for $39 you cant beat the price. No problems so far.
HotSauceJunky
Junior Member
HotSauceJunky's Reviews
05-02-2008, 10:01 AM
Price: $28.00
Recommended? Yes
Comments: Great radio for the price. Works great and has all the bells and whistles and cheap enough that I don't have to worry about it getting stolen.
bestia88
bestia88's Reviews
04-27-2008, 07:49 PM
Price: $30.00
Recommended? Yes
Comments: I love it!
CJHVN
CJHVN's Reviews
04-24-2008, 08:47 PM
Price: $50.00
Recommended? Yes
Comments: Good
ThreadForumRepliesLast Post
Midland Radio 1001Z CB & HAM Radios 19 09-09-2011 03:49 PM
Midland Radio 79-290 CB & HAM Radios 4 11-24-2009 11:28 AM
Midland Radio 13-510 CB & HAM Radios 2 03-10-2009 06:26 PM
Midland 77-805 CB & HAM Radios 1 06-20-2008 12:30 PM
Midland 75-785 Batteries 0 04-24-2008 03:07 PM
Glock Forum
