ICOM 2200H Reviews, Ratings, Specs & Prices
Review Categories
Armor
  Bumpers
  Differential Guards
  Rocker Guards
  Roll Cages
  Skid Plates
Audio, CB, & Electrical
  Audio Players
  Batteries
  CB & Ham Radios
  GPS
  Speakers
Axles
  Axle Shafts
  Brakes
  Gears
  Hubs
  Lockers
  Steering
Body
  Body Lifts
  Consoles, Security & Storage
  Exterior Accessories
  Fender Flares
  Lighting, Lenses & Bulbs
  Roof Racks & Cargo Areas
  Tops
Engine
  Alternators
  Carburetors
  Chips
  Exhaust
  Headers
  Induction
  Internal Parts
  Motor Mounts
  Starters
  Throttle Body
Interior
  Gauges
  Misc
  Seats
Recovery
  Winch Cable and Hooks
  Winches
Suspension
  Complete Lift Kits
  Control Arms
  Shocks
  Springs
  Steering Stabilizers
  Track Bars
Tires & Wheels
  Tires
  Wheels
Transfer Case
  SYE Kits
  Transfer Cases
Transmissions
  Transmissions
Previous Product CB & Ham Radios Next Product
ICOM 2200H
Rating:
Product Information
MSRP: $20.00
Average Price: $123.00
Manufacturer: ICOM
Recommended?
Yes: 4 / No: 0
2 Meter Ham rig
None
Kiwi
Kiwi's Reviews
11-09-2010, 02:32 PM
Price: $150.00
Pros: Durable
Cons: LCD screen hard to read when slightly off-center
Recommended? Yes
Comments: Had it mounted in rig for 3 years, seems to handle lots of dust just fine. Don't like the remote mike so much.
Kits
Kits's Reviews
09-30-2010, 07:13 PM
Price: $199.00
Pros: 65 watts easy install
Cons: none
Recommended? Yes
Comments: Don't know why more people don't use VHF or 2metre, way better range than a CB and you also have the use of repeater stations if needed.
Install was maybe 10mins but I already had a antenna wired up for my IC-V82 hand held so it was an easy switch.
CB's have thier place in this world but reality is VHF is just way better. Up here in Canada the range of a CB in the mountains is very very limited but with a VHF we can transmit farther with the aid of repeater stations the range is really unlimited. I also run with a CB only for the simple fact that up here ya gotta have a license to run a VHF and most folks are to lazy to get one.
Also when buying an antenna don't scimp, drop some coin on a good one and you'll have no regrets.
timc
timc's Reviews
01-03-2009, 06:21 PM
ICOM 2200H
Price: $20.00
Recommended? Yes
Comments: Finals blow easy on these, but it's an easy fix without swapping the final PA module!
ScotZ
American to the Bone
ScotZ's Reviews
08-02-2008, 12:20 AM
ICOM 2200H
Recommended? Yes
Comments: The Icom IC-2200H 2 meter FM mobile features a rugged design and an easy-to-read alphanumeric display. The large informative LCD may be set to green or amber. The receiver covers 118-174 MHz and the transmitter delivers 65, 25, 10 or 5 watts of output. The improved receive IMD helps provide protection from excessively strong signals such as pager signals. And the squelch attenuator (approx 10 dB) allows you to reduce interference from strong nearby signals. A winning combination for receive performance. The front panel has an oversized tuning dial is easy to grab while on the move and the large 4-level backlit display clearly provides key information at a glance. Memory channels can be assigned names for easy recognition and easy access. The 2200H supports three different scan modes: Full Scan, Memory Scan, Programmed Scan and four scan resume conditions. Other features include: 207 memories, alphanumeric notes, 3-way priority watch and independently programmable Rx/Tx and tone squelch. The 2200H is also one of the first mobiles to be GPS NMEA compatible (GPS not supplied). There is an external speaker jack on the rear panel. The IC-2200H is built rugged and has a convenient front mounted mic jack. The supplied HM-133V remote control mic controls everything in the palm of your hand. ICOM's exclusive Hot Keys lets you program the features that you use the most. The bigger backlit keys allow you to operate in low light conditions. Requires 13.8 VDC at 15 amps. A mobile mounting bracket, power cord and mic hanger are also supplied. Size: 5.5 x 1.6 x 5.9 inches 2 Lbs. 10 oz. (140x40x146mm 1.25 kg). Click here for specifications.
ThreadForumRepliesLast Post
ICOM 2100H CB & Ham Radios 5 03-12-2014 08:07 PM
ICOM IC-7000 CB & Ham Radios 8 01-17-2014 10:43 PM
icom 208H CB & Ham Radios 2 06-05-2012 03:44 PM
Icom IC-706MkIIG CB & Ham Radios 3 04-17-2010 11:56 AM
ICOM IC-2820 CB & Ham Radios 0 09-21-2008 10:20 PM
