Product Information
These cable assemblies are made from our top-quality RG-58A/U, Fire-Flex coaxial cable. They are to be used on any single antenna installation. This includes CB, scanner, 2-meter, and 10 meter. Main features of our Fire-Flex coax are:
Stranded center conductor to maximize flexibility and prevent untimely breakage.
Shielding coverage that averages 95% to protect against RF leaks and interferrence.
Polyvinyl center insulation for ruggedness and longivity.
Performance that exceeds mil-spec requirements for 50 ohm RG-58A/U coax.
The mount end termination on these cables is our exclusive Fire-Ring. You won't find a more trouble free, low-profile connection anywhere. All of the coax connections are internally soldered and protected from the elements. This termination is designed to fit any 1/2" (13mm) hole. It also has a built in nylon shoulder washer to keep it centered and short free.
Price | $20.99 |
Manufacturer | Firestik |
Company website | http://www.firestik.com/CatalogFrame.htm |
