Firestick firefly 4' antenna Reviews, Ratings, Specs & Prices
Review Categories
Armor
  Bumpers
  Differential Guards
  Rocker Guards
  Roll Cages
  Skid Plates
Audio, CB, & Electrical
  Audio Players
  Batteries
  CB & Ham Radios
  GPS
  Speakers
Axles
  Axle Shafts
  Brakes
  Gears
  Hubs
  Lockers
  Steering
Body
  Body Lifts
  Consoles, Security & Storage
  Exterior Accessories
  Fender Flares
  Lighting, Lenses & Bulbs
  Roof Racks & Cargo Areas
  Tops
Engine
  Alternators
  Carburetors
  Chips
  Exhaust
  Headers
  Induction
  Internal Parts
  Motor Mounts
  Starters
  Throttle Body
Interior
  Gauges
  Misc
  Seats
Recovery
  Winch Cable and Hooks
  Winches
Suspension
  Complete Lift Kits
  Control Arms
  Shocks
  Springs
  Steering Stabilizers
  Track Bars
Tires & Wheels
  Tires
  Wheels
Transfer Case
  SYE Kits
  Transfer Cases
Transmissions
  Transmissions
Previous Product CB & Ham Radios Next Product
Rating:
Product Information
MSRP: $50.00
Average Price: $22.57
Manufacturer: Firestick
Recommended?
Yes: 29 / No: 0
BRIEF:
Lightweight, Easy-tune 'bare-hands tunable tip', High-performance coil design, Flexible fiberglass tube
DETAIL:
The "FL" Series antennas are the performance leader of lightweight top-loaded CB antennas. Each is approximately 40% lighter than the equivalent length Firestik II antenna. From the perspective of mount stress, the lighter materials and reduced wind drag of the "FL" antennas reduces stress by more than 60%. A 4-foot FireFly will easily perform on a mount that is designed for antennas 3-foot or less. At the top of every "FL" antenna you will find our patented tunable-tip. Besides making tuning a snap, the design broadens the antennas bandwidth and increases its power handling capabilities. All "FL" antennas are compatible with autos, trucks, vans, motorcycles and ATV's in a single antenna configuration when metallic ground plane is available. Or, they may be used in dual (co-phased) configuration on any vehicle made from any type of material. Like all CB antennas, the "FL" antennas should be fine-tuned (SWR) in their final mounting location. If you have ever tuned a non-tunable tip antenna, you will have a real appreciation for the "FL" antennas. In short, tuning is as easy as popping off the tip and turning the adjustment screw up or down as needed. All "FL" antennas exceed the requirements of any CB radio, new or old. Aside from the hi-performance loading coil that maximizes the transmit/receive functions of your CB, these top-loaded antennas will also receive the NOAA emergency weather alert and national weather broadcasts for radios with those features.
All "FL" antennas are 100% American made with 100% American materials. To maintain a balance between flexibility and ruggedness, we use a custom blended, glass fiber reinforced tube. Each is wound with double insulated copper wire to prevent the oxidation and shorted windings often found on non-Firestik antennas. The tunable tip mechanism is made from rust-proof brass and has a rubber o-ring to hold the adjuster in place after tuning. Our 3/8"-24 threaded base will fit all Firestik mounts and accessories. Each antenna is covered with a static reducing, water-tight sleeve containing UV and pigment stabilizers. For peek performance we recommend that you use one of our Fire-Flex or RoadPal coaxial cables with these antennas.
All "FL" series antennas are factory bench tested for resonant frequency and overall quality. They are available in black, red or white with a black tip.
None
Page 2 of 2 1 2
jackbauersmom
jackbauersmom's Reviews
09-07-2008, 08:59 PM
Price: $18.00
Recommended? Yes
Comments: have the 3' one. nice lightweight antenna mounted with teraflex driver side tailight mount.
erichapman
erichapman's Reviews
07-28-2008, 09:34 PM
Price: $30.00
Recommended? Yes
Comments: looks cool, but poor signal.
might just need dialed in better, even though they claim no dialing in is necessary.
Keith
Admin
Keith's Reviews
07-19-2008, 03:47 AM
Price: $20.00
Recommended? Yes
Comments: Excellent product hands down. I don't know of a better antenna on the market.
lutzke21
lutzke21's Reviews
07-16-2008, 12:23 PM
Price: $19.99
Recommended? Yes
Comments: Always have used Firestik, though I am positive there are better brands out there. Completely tunable.
KUK9
KUK9's Reviews
07-13-2008, 08:34 PM
Price: $20.00
Recommended? Yes
Comments: Great antenna, with easy adjustments to tune the SWR. Mounted easily with a quick disconnect, and has held up to many a tree branch.
Poobah
Poobah's Reviews
07-09-2008, 06:56 PM
Price: $15.00
Recommended? Yes
Comments: Actually - it is spelled Firestik. I have the 3' antenna - works like a charm.
batjeep13
batjeep13's Reviews
06-13-2008, 10:24 PM
Price: $20.00
Recommended? Yes
Comments: The antenna works good and looks great on the jeep. It is mounted to the rear bumper.
TJRubicon06
TJRubicon06's Reviews
06-09-2008, 08:56 PM
Price: $20.00
Recommended? Yes
Comments: Great antenna, gets great receptions, cheap, looks good. Tunable tip is nice.
Redskybri
Redskybri's Reviews
05-19-2008, 01:32 PM
Price: $12.99
Recommended? Yes
Comments: Awsome antenna. Easy to tune. No problems. Also have the wrangler hood mount by firstick. Easy to install!!
Page 2 of 2 1 2
ThreadForumRepliesLast Post
Radio Shack 102" SS Whip Antenna CB & Ham Radios 6 09-28-2015 09:36 AM
Firestik Firefly 4' CB & Ham Radios 16 01-05-2014 02:40 AM
Cool Tech LLC Ultra Mount CB antenna system CB & Ham Radios 1 05-16-2008 08:26 PM
