Go Back JeepForum.com > Reviews > Audio, CB, & Electrical > CB & HAM Radios > Firestick firefly 4' antenna
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineGR8TOPS Introduces the Exogate HD Tire Carrier4.25" 97-06 Jeep TJ Wrangler Lift Kit - NO SYE Needed
Firestick firefly 4' antenna Reviews, Ratings, Specs & Prices
Review Categories
Armor
  Bumpers
  Differential Guards
  Rocker Guards
  Roll Cages
  Skid Plates
  Audio Players
  Batteries
  CB & HAM Radios
  GPS
  Speakers
Axles
  Axle Shafts
  Brakes
  Gears
  Hubs
  Lockers
  Steering
Body
  Body Lifts
  Consoles, Security & Storage
  Exterior Accessories
  Fender Flares
  Lighting, Lenses & Bulbs
  Roof Racks & Cargo Areas
  Tops
Engine
  Alternators
  Carburetors
  Chips
  Exhaust
  Headers
  Induction
  Internal Parts
  Motor Mounts
  Starters
  Throttle Body
Interior
  Gauges
  Misc
  Seats
Recovery
  Winch Cable and Hooks
  Winches
Suspension
  Complete Lift Kits
  Control Arms
  Shocks
  Springs
  Steering Stabilizers
  Track Bars
Tires & Wheels
  Tires
  Wheels
Transfer Case
  SYE Kits
  Transfer Cases
Transmissions
  Transmissions
Previous Product CB & HAM Radios Next Product
Rating:
Product Information
MSRP: $50.00
Average Price: $22.73
Manufacturer: Firestick
Recommended?
Yes: 27 / No: 0
BRIEF:
Lightweight, Easy-tune 'bare-hands tunable tip', High-performance coil design, Flexible fiberglass tube
DETAIL:
The "FL" Series antennas are the performance leader of lightweight top-loaded CB antennas. Each is approximately 40% lighter than the equivalent length Firestik II antenna. From the perspective of mount stress, the lighter materials and reduced wind drag of the "FL" antennas reduces stress by more than 60%. A 4-foot FireFly will easily perform on a mount that is designed for antennas 3-foot or less. At the top of every "FL" antenna you will find our patented tunable-tip. Besides making tuning a snap, the design broadens the antennas bandwidth and increases its power handling capabilities. All "FL" antennas are compatible with autos, trucks, vans, motorcycles and ATV's in a single antenna configuration when metallic ground plane is available. Or, they may be used in dual (co-phased) configuration on any vehicle made from any type of material. Like all CB antennas, the "FL" antennas should be fine-tuned (SWR) in their final mounting location. If you have ever tuned a non-tunable tip antenna, you will have a real appreciation for the "FL" antennas. In short, tuning is as easy as popping off the tip and turning the adjustment screw up or down as needed. All "FL" antennas exceed the requirements of any CB radio, new or old. Aside from the hi-performance loading coil that maximizes the transmit/receive functions of your CB, these top-loaded antennas will also receive the NOAA emergency weather alert and national weather broadcasts for radios with those features.
All "FL" antennas are 100% American made with 100% American materials. To maintain a balance between flexibility and ruggedness, we use a custom blended, glass fiber reinforced tube. Each is wound with double insulated copper wire to prevent the oxidation and shorted windings often found on non-Firestik antennas. The tunable tip mechanism is made from rust-proof brass and has a rubber o-ring to hold the adjuster in place after tuning. Our 3/8"-24 threaded base will fit all Firestik mounts and accessories. Each antenna is covered with a static reducing, water-tight sleeve containing UV and pigment stabilizers. For peek performance we recommend that you use one of our Fire-Flex or RoadPal coaxial cables with these antennas.
All "FL" series antennas are factory bench tested for resonant frequency and overall quality. They are available in black, red or white with a black tip.
Page 1 of 2 1 2 > Last »
Scooter_Trash
Scooter_Trash's Reviews
01-18-2011, 10:17 PM
Price: $15.00
Pros: Easy to tune
Cons: None
Recommended? Yes
Comments: Great reception and transmission once it's tuned. I had to ground my tailgate to get a better SWR reading.
clety
clety's Reviews
01-15-2010, 07:48 PM
Price: $50.00
Pros: good
Cons: noisy clinking against the truck.
Recommended? Yes
Comments: ]]]]]]]]]]]]]]]]]]]]]]]]]]]]]]]]]]]]]]]]]]]]]]]]]]]]]]]]]]]]]]]]].]]]]]]
jeepinmichguy_
Resident *** Hole
jeepinmichguy_'s Reviews
01-15-2010, 08:44 AM
Price: $40.00
Pros: tunable
Cons: none
Recommended? Yes
Comments: This is the perfect size if you are monting to a bumper, it sticks up above the jeep about 1 inch. The tunable tip is great and it gets good range.
buckethead860
buckethead860's Reviews
10-30-2009, 02:01 PM
Price: $20.00
Pros: Works good, monting braket 13.99 works great too.
Cons:
Recommended? Yes
Comments: I bought this because it came with a mounting bracket ithat mounted in back of driver side brakelight. works good, worth the money.
BigDogTJ
bás thar easonóir
BigDogTJ's Reviews
10-29-2009, 06:17 PM
Price: $25.00
Pros: Really strong, vinyl coating has lasted outdoors for over two years.
Cons: Kind of think for running on a trail, no flex, have to add springs.
Recommended? Yes
Comments: Great antenna. Doesn't stick up too much and looks great mounted on the rear of my TJ. A must have add-on is a set of springs for where the antenna is grounded so they will bend against brush and strong wind resistance.
kadetklapp
kadetklapp's Reviews
05-27-2009, 04:01 PM
Price: $19.00
Pros: Good stick
Cons: Needs trimmed
Recommended? Yes
Comments: Good trail antenna
Mayfair_Jeeper
Jack *** of All Trades
Mayfair_Jeeper's Reviews
04-01-2009, 02:10 PM
Price: $24.00
Recommended? Yes
Comments: Great Reception. easy to tune. Mounted it to my spare tire mount. I do not recommend this mounting if you have a hard top. Makes it a pain to open and close the rear window
Grizz91YJ
Grizz91YJ's Reviews
03-27-2009, 03:32 PM
Recommended? Yes
Comments: got a bunch of these laying around hold up to abuse better than a wilson. Perfect for a trail rider even got them on my four wheelers
Libtekguy
Libtekguy's Reviews
02-22-2009, 10:30 AM
Price: $25.00
Recommended? Yes
Comments: Bad *** and very durable antenna. I used the Terraflex taillight bracket to mount it up. It's tunable feature (no cutting) is what sold me.
GoldenEagle06
GoldenEagle06's Reviews
01-19-2009, 10:18 AM
Price: $15.00
Recommended? Yes
Comments: Its a great antenna when tuned correct. I was able to pick up an untuned whip some five miles away. I use it alot on road trips its helped me avoid many accidents and backups.
ScottHarr_TJ
ScottHarr_TJ's Reviews
12-29-2008, 11:55 PM
Price: $20.00
Recommended? Yes
Comments: i like the antenna alot. the only thing i dont like is how the antenna always smacks low hanging stuff. but thats with any antenna. this one is great and it gets good reception.
3S00W
3S00W's Reviews
12-29-2008, 09:45 AM
Price: $25.00
Recommended? Yes
Comments: I had originally and 8' whip but got this and it has definitely made a HUGE improvement on my radio. Also looks way better too.
JohnnyEpic
JohnnyEpic's Reviews
11-20-2008, 10:07 PM
Price: $15.00
Recommended? Yes
Comments: This is a very strong yet flexible antenna. I have it coupled with a spring and haven't had any problems with it yet. I get really good reception and it was very cheap at a truck stop in Springfield, MO.
ajbjeeper28
ajbjeeper28's Reviews
11-13-2008, 10:46 PM
Price: $50.00
Recommended? Yes
Comments: i have two of these antennas on my jeep now, i love how clear the single is with a fire stick, and i don't have to worry about branches breaking my antenna
hokies98zj
hokies98zj's Reviews
10-27-2008, 11:12 AM
Price: $18.00
Recommended? Yes
Comments: got the firestick firefly 4' antenna to go with my midland 1001z cb radio.works great.easy to tune(top loaded) and helps me get good reception and broadcasting out.
Hockey1
Hockey1's Reviews
10-13-2008, 08:00 PM
Price: $25.00
Recommended? Yes
Comments: I just recently installed it. I havent had a chance to use it yet. But I do like the options you have in mounting locations.
OffroadAlex
OffroadAlex's Reviews
09-21-2008, 09:25 PM
Price: $14.00
Recommended? Yes
Comments: Sweet antenna, looks awesome and it works. Great for the price their really cheap, I need another because either someone ripped it off or it got ripped off from driving.
Red_
Red_'s Reviews
09-14-2008, 03:46 PM
Price: $15.00
Recommended? Yes
Comments: Been bashed to hell and back, has yet to break. Should have gone with a 2' one and mounted it higher
jackbauersmom
jackbauersmom's Reviews
09-07-2008, 07:59 PM
Price: $18.00
Recommended? Yes
Comments: have the 3' one. nice lightweight antenna mounted with teraflex driver side tailight mount.
erichapman
erichapman's Reviews
07-28-2008, 08:34 PM
Price: $30.00
Recommended? Yes
Comments: looks cool, but poor signal.
might just need dialed in better, even though they claim no dialing in is necessary.
ThreadForumRepliesLast Post
Firestik Firefly 4' CB & HAM Radios 7 08-03-2009 09:17 PM
Radio Shack 102" SS Whip Antenna CB & HAM Radios 3 01-24-2009 03:28 AM
Cool Tech LLC Ultra Mount CB antenna system CB & HAM Radios 1 05-16-2008 09:26 PM
Glock Forum
