Cobra 75 WX ST Reviews, Ratings, Specs & Prices
Review Categories
Armor
  Bumpers
  Differential Guards
  Rocker Guards
  Roll Cages
  Skid Plates
Audio, CB, & Electrical
  Audio Players
  Batteries
  CB & Ham Radios
  GPS
  Speakers
Axles
  Axle Shafts
  Brakes
  Gears
  Hubs
  Lockers
  Steering
Body
  Body Lifts
  Consoles, Security & Storage
  Exterior Accessories
  Fender Flares
  Lighting, Lenses & Bulbs
  Roof Racks & Cargo Areas
  Tops
Engine
  Alternators
  Carburetors
  Chips
  Exhaust
  Headers
  Induction
  Internal Parts
  Motor Mounts
  Starters
  Throttle Body
Interior
  Gauges
  Misc
  Seats
Recovery
  Winch Cable and Hooks
  Winches
Suspension
  Complete Lift Kits
  Control Arms
  Shocks
  Springs
  Steering Stabilizers
  Track Bars
Tires & Wheels
  Tires
  Wheels
Transfer Case
  SYE Kits
  Transfer Cases
Transmissions
  Transmissions
Previous Product CB & Ham Radios Next Product
Cobra 75 WX ST
Rating:
Product Information
MSRP: $500.00
Average Price: $97.74
Manufacturer: Cobra
Recommended?
Yes: 345 / No: 5
40 channels, remote mount, Soundtracker, 10 NOAA weather channels, Dual Watch
SoundTracker®: The first patented technology that dramatically improves the transmission and reception of CB radio signals. The result is a cleaner, clearer sounding CB with more "powerful" transmissions and less static or noise on reception
40 CB & 10 Weather Channels: 10 Weather Channels. Complete access to all 40 Citizen Band Radio channels. 10 National Weather Channels (7 NOAA and 3 International) provide full coverage to keep you informed of weather conditions anywhere you go
Remote Mount System: Remote installation box installs out of sight under your dash and the quick disconnect allows removal of the handpiece for security or use in other vehicles.
Dual Watch and Full Channel Scan: Dual Watch allows simultaneous monitoring of any two preselected channels. Full Channel Scan allows you to scan all 40 channels
Instant Channel 19: Instant access to information Channel 19 with a single switch of a button.
Full-Featured LCD Display Panel: All the information you need is provided from this LCD display panel. Choose normal CB channel readout or five digit frequency display.
None
Page 2 of 18 1 2 3 4 5 6 7 8 9 10 11 12 13 > Last »
Jack0369
Jack0369's Reviews
07-10-2014, 04:42 PM
Price: $99.00
Pros: Small, everything is in your hand
Cons: I can't think of any
Recommended? Yes
Comments: It is easy to use, and is compact. It saves room in your jeep but does not sacrifice quality. I used a spring and a Firestik four foot antenna. Must buy a SWR meter to properly tune it.
JeepStangGuy
JeepStangGuy's Reviews
07-02-2014, 07:06 PM
Price: $1.00
Pros: 1
Cons: 1
Recommended? Yes
Comments: a
Zeppelin
Zeppelin's Reviews
05-16-2014, 05:24 PM
Price: $80.00
Pros: Remote Mount
Cons: Coil cord a little short
Recommended? No
Comments: I have had this CB for about 10 years. Recently I had one of the wires at the connector break and it needed to be re-soldered. Easy fix though. Still working great.
JKCA
JKCA's Reviews
05-12-2014, 12:33 PM
Price: $140.00
Pros: can easily disconnect so it doesn't get stolen, easy to use
Cons: none
Recommended? Yes
Comments: easy to use, sound clarity and quick disconnect feature.
Goldenfinger
Goldenfinger's Reviews
04-07-2014, 11:38 PM
Price: $130.00
Pros: Small & compact installation
Cons: None so far.
Recommended? Yes
Comments: Great product for adding a CB to your WJ. The main module can be easily installed inside of the WJ console allowing for easy routing of all cables and the ability to run the CB cable up from beside your seat. Signal is strong and clear.
jpnut
jpnut's Reviews
04-02-2014, 12:33 AM
Price: $99.99
Pros: fits in the limited space of a Jeep
Cons: limited range with Wilson 4 ft top loaded antenna.
Recommended? Yes
Comments: Gets the job done for trail communications. I am thinking about getting a handheld HAM radio for greater distances.
waldo177
waldo177's Reviews
03-27-2014, 04:21 PM
Price: $125.00
Pros: Small and easy to use
Cons: None
Recommended? Yes
Comments: Like the ease of install hardest part was figuring out where I wanted to put it. Lots of options as small as it is
aquezada
aquezada's Reviews
03-23-2014, 11:21 PM
Price: $75.00
Pros: Small and easy to hide.
Cons: Feels cheap.
Recommended? Yes
Comments: Handset feels a bit cheap. Cable started to crack at some points from the sun exposure I suppose. For the price, i would look for something louder.
Jeebus2000
Jeebus2000's Reviews
03-06-2014, 04:08 PM
Price: $90.00
Pros: Compact, Inexpensive, all in one, Makes for clean installation
Cons: None yet
Recommended? Yes
Comments: For a low footprint/low impact and clean installation, this is the CB for you. Recommend installing the power box under the dash or seat and run a cord extension to the radio cord escutcheon. Using dual antennas for my application, transmitting perfectly. Love it.
dcgibbons
dcgibbons's Reviews
02-03-2014, 05:27 PM
Price: $92.90
Pros: small, easy to install, and easy to use
Cons: low power, mediocre sound quality
Recommended? Yes
Comments: The handheld mic contains most of the CB unit, and is effectively the same size as most mics. The remainder of the radio is a very small unit that fits easily behind or underneath the glove box.
wkldr
wkldr's Reviews
02-03-2014, 04:55 PM
Price: $85.00
Pros: Nice clean installation options
Cons: Not the easiest thing in the world to install
Recommended? Yes
Comments: Nice product. Provides clean installation for my space challenged WK. Good reception.
akinshake
akinshake's Reviews
01-31-2014, 04:03 PM
Price: $92.90
Pros: Slim, convenient
Cons: none yet
Recommended? Yes
Comments: I can't really attest to the efficiency of my setup because I am having trouble tuning it. but I love the simplicity and size of it. can really mount it anywhere. And its a Cobra.
jkruegel
jkruegel's Reviews
01-19-2014, 10:44 PM
Price: $198.00
Pros: easy install, easy to remove mic for loss prevention, can add power unit to other vehicles and move CB from one to another
Cons: Mic is a bit heavy.
Recommended? Yes
Comments: Installed unit in just a few hours including the antenna and external speaker. I like the feature of being able to remove the mic for security. The external speaker is loud enough to hear while driving with the doors off. The base unit is very compact and easy to mount out of sight.
Nik-Nak
Nik-Nak's Reviews
12-06-2013, 01:12 PM
Price: $120.00
Pros: Compact, easy to install
Cons: none
Recommended? Yes
Comments: If you are considering a CB for trail use this is the one! Perfect for communication between you and the people you are on the trail with! My jeep is a daily driver and I did not want some ugly CB mounted to my ceiling like a trucker or mounted on the dash or under the seat. The compact design allows you to mount this under the dash taking up very little room. After instalation all you will see is the cord going to the mic from under your dash! Highly recomend this CB!
ZERO30
ZERO30's Reviews
12-02-2013, 04:57 PM
Price: $100.00
Pros: Compact, looks factory installed. loud. NOAA Weather radio
Cons: none
Recommended? Yes
Comments: It hides so well and works so great. can be mounted with only zip ties. It's awesome. Hides right behind the glove box.
Moparich
Moparich's Reviews
12-01-2013, 11:11 PM
Price: $100.00
Pros: works for me when trailing
Cons: not sure of any
Recommended? Yes
Comments: works well for me. i havent had any issues with this cb. i bought it in a kit with a firestick antenna. i havent even tuned it. not sure if it needs it
TJchet
TJchet's Reviews
10-16-2013, 12:27 AM
Price: $65.00
Pros: Easy to mount and doesn't take up much space.
Cons: None yet!
Recommended? Yes
Comments: I bought this from a member on the forum and am very happy with it so far. Main use will be while trail riding with my Jeep club I recently joined. It is a requirement to have a radio to be a member and figured this one would work perfectly!
LVrescue
LVrescue's Reviews
10-13-2013, 10:30 AM
Price: $99.00
Pros: price, small, good for off-roading, and traveling
Cons: limited capabilities
Recommended? Yes
Comments: installed with molded side mount antenna at the license plate. receiver is behind glove box and easy to access if needed.
tyler_lapointe
tyler_lapointe's Reviews
09-25-2013, 10:27 AM
Price: $230.00
Pros: No Box Unit, all functions on hand held
Cons: None
Recommended? Yes
Comments: Best CB to get, has no bulky box. Couldn't be happier with this selection.
cbworld
cbworld's Reviews
09-11-2013, 05:34 PM
Price: $93.00
Pros: Small size Easy to install Controls are accessible
Cons: Low power out of the box
Recommended? Yes
Comments: I am surprised there aren't more CB's like this one on the market anymore. When you don't have a lot of space, an all in the handset unit like this is the perfect solution. The only down side is the power output. Manufacturers typically have the power on their radios set below the FCC allowed 4 watts to avoid fines, but the Cobra 75WXST is notoriously under powered out of the box. I've seen them as low as 2 watts! If you get a good peak and tune done on the radio they perform well, though.
ThreadForumRepliesLast Post
Cobra 29 LTD BT CB & Ham Radios 43 06-10-2015 07:55 PM
cobra cobra CB & Ham Radios 21 01-07-2015 08:58 AM
Cobra HH 38 WX ST C CB & Ham Radios 5 02-12-2014 05:16 PM
Cobra 23 Plus CB & Ham Radios 2 12-23-2013 04:53 PM
Cobra 19-rv GPS 0 10-21-2008 08:41 PM
