Astatic D104-M6B Reviews, Ratings, Specs & Prices
Review Categories
Armor
  Bumpers
  Differential Guards
  Rocker Guards
  Roll Cages
  Skid Plates
Audio, CB, & Electrical
  Audio Players
  Batteries
  CB & Ham Radios
  GPS
  Speakers
Axles
  Axle Shafts
  Brakes
  Gears
  Hubs
  Lockers
  Steering
Body
  Body Lifts
  Consoles, Security & Storage
  Exterior Accessories
  Fender Flares
  Lighting, Lenses & Bulbs
  Roof Racks & Cargo Areas
  Tops
Engine
  Alternators
  Carburetors
  Chips
  Exhaust
  Headers
  Induction
  Internal Parts
  Motor Mounts
  Starters
  Throttle Body
Interior
  Gauges
  Misc
  Seats
Recovery
  Winch Cable and Hooks
  Winches
Suspension
  Complete Lift Kits
  Control Arms
  Shocks
  Springs
  Steering Stabilizers
  Track Bars
Tires & Wheels
  Tires
  Wheels
Transfer Case
  SYE Kits
  Transfer Cases
Transmissions
  Transmissions
Previous Product CB & Ham Radios Next Product
Astatic D104-M6B
Rating:
Product Information
MSRP: $60.00
Average Price: $50.00
Manufacturer: Astatic
Recommended?
Yes: 2 / No: 1
The D104-M6 series microphones are quality performance field effect amplified “power” microphones for amateur, citizen band, mobile, aircraft, marine applications. The housing of the D104-M6B is molded black ABS with a chrome plated grille screen (pictured at right). The housing of the D104-M6C is molded black ABS, the front half is chrome plated and the grille screen is chrome plated.
An output impedance compatible with the inputs of almost all commercial transceivers and externally adjustable high gain amplifier ensures desired modulation level. The D104-M6 has an easily accessible control for volume so that the correct modulation level can be set for each operators voice. The D104-M6 preamplifier is powered by a readily available, easily replaced, 9 volt battery. The D104-M6 has a six wire coil cord which allows for relay, electronic or virtually any type hookup with almost any transceiver. The audio line is open during receive.
None
ctak24
ctak24's Reviews
10-09-2012, 02:36 PM
Price: $50.00
Pros: loud, feels solid, durable cord
Cons: quality
Recommended? No
Comments: good mic if you're looking for something loud. sounds a bit tinny but not too bad. quality has gone to **** ever since barjan bought them out. PTT button is sticky out the box on every single one i've bought. the switch will die on you too quickly. but if you're on the market for something loud, the d104 handheld got that covered.
anymhz
anymhz's Reviews
02-03-2011, 10:10 AM
Price: $39.99
Pros: Loud mic, uses 9 volt battery or can be modified to run off the radio's internal power.
Cons: NONE.!
Recommended? Yes
Comments: $39.99+tax at the CB Shop - Hwy95&FM93 Temple, TX 76502
Loud mic, uses 9 volt battery or can be modified to run off the radio's internal power. I use mine on my base it is powered by the radio, so i never need a battery. Also making one to be setup for the new IC-7000 icom's..
DontScarePete
DontScarePete's Reviews
07-16-2008, 11:07 PM
Astatic D104-M6B
Price: $60.00
Recommended? Yes
Comments: Great mic. It's amped so it's perfect for jeeps which are inherently noisy when at any speed above 15mph. Very durable.
