Rugged Ridge tow hooks
Rating: |
Product Information
| MSRP: |
$89.00 |
| Average Price: |
$41.84 |
| Manufacturer: |
Rugged Ridge |
| Recommended? |
marzcap328's Reviews
Price: $25.00 Pros: Very strong, works exactly as wanted Cons: Tow hooks fade and retainer clips rust Recommended? Yes
Comments: They do their job, but after a week the paint on the hook itself faded, and the clips began to rust. Paint them, then install.
Jeeeper4life's Reviews
Price: $12.50 Pros: Thick steel, three mounting holes, hardware included Cons: None Recommended? Yes
Comments: Solid chunk of steel, comes with grade 8 hardware, I chose not to install the clip that holds strap on the hook as I have it in an upwards mounting position. Basically it holds the strap on the hook when not under tension. Three holes are in the mount, it gives you flexibility in locating it on your rig.
unlimited94's Reviews
Price: $90.00 Pros: Good mounting point in case there's nowhere to pull from the back. Cons: Don't connect both hooks together in the middle with a brace. Recommended? Yes
Comments: Good for the price. Not the strongest setup, but much better than nothing.
7urtle's Reviews
Price: $79.99 Pros: beefy Cons: came with grade 5 bolts Recommended? Yes
Comments: easy to install.beefy and strengthens the frame up
not-a-6's Reviews
Price: $19.95 Pros: cheap cost, come in very handy when wheeling with other vehicles Cons: no torque specs for the bolts Recommended? Yes
Comments: simple easy upgrade to help you get pulled out of the mud
cf7710's Reviews
Price: $29.95 Pros: great product Cons: none Recommended? Yes
Comments: These tow hooks are heavy duty and easy to install to front factory locations.
SolidBrass's Reviews
Price: $35.00 Pros: Match OEM hooks but stronger. DOES NOT stick out past bumper. Cons: strap rated higher that hooks.. do keep your head low. Recommended? Yes
Comments: Match OEM hooks but stronger. DOES NOT stick out past bumper.
bpeterson's Reviews
03-14-2009, 10:47 AM |
Price: $20.00 Recommended? Yes
Comments: work like a charm and looked good for about 2 months until the Illinois winter in the salt belt rusted them out
rc_007's Reviews
02-20-2009, 03:29 PM |
Price: $17.00 Recommended? Yes
Comments: very strong. although the included safety clips rusted out immedietaly .
indredsnake99's Reviews
02-14-2009, 07:26 PM |
Price: $89.00 Recommended? Yes
Comments: great quality kit. bolts rusted in two days the only thing i have seen that i dont like. brackets are storng accidently ran one over and nothing
