Go Back JeepForum.com > Reviews > Recovery > Winch Cable and Hooks > Masterpull Synthetic Winch Line
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineBLOWOUT SALE -- SYE Slip Yoke Eliminator Kits, NP231 TransNEW BOLT-ON Dash CB Mount 97-06 TJ Wranglers
Masterpull Synthetic Winch Line Reviews, Ratings, Specs & Prices
Review Categories
Armor
  Bumpers
  Differential Guards
  Rocker Guards
  Roll Cages
  Skid Plates
Audio, CB, & Electrical
  Audio Players
  Batteries
  CB & HAM Radios
  GPS
  Speakers
Axles
  Axle Shafts
  Brakes
  Gears
  Hubs
  Lockers
  Steering
Body
  Body Lifts
  Consoles, Security & Storage
  Exterior Accessories
  Fender Flares
  Lighting, Lenses & Bulbs
  Roof Racks & Cargo Areas
  Tops
Engine
  Alternators
  Carburetors
  Chips
  Exhaust
  Headers
  Induction
  Internal Parts
  Motor Mounts
  Starters
  Throttle Body
Interior
  Gauges
  Misc
  Seats
Recovery
  Winches
Suspension
  Complete Lift Kits
  Control Arms
  Shocks
  Springs
  Steering Stabilizers
  Track Bars
Tires & Wheels
  Tires
  Wheels
Transfer Case
  SYE Kits
  Transfer Cases
Transmissions
  Transmissions
Winch Cable and Hooks Next Product
Rating:
Product Information
MSRP: $349.00
Average Price: $238.00
Manufacturer: Masterpull
Recommended?
Yes: 12 / No: 0
Masterpull synthetic winch rope is made using the world's strongest synthetic rope, DYNEX™. The M-P winch rope is only a fraction of the weight of a wire cable, and impressively up to 45% stronger than same size wire cable. Also, M-P winch rope is safer, lighter and easier to handle than the wire cable. And unlike wire cable, M-P winch rope has minimal snapback if the rope breaks. Due to the ropes light weight, M-P winch rope handles easily and even floats on water. This makes the M-P winch rope a great rope for rescues in water, on steep hills or in mountains, where weight really matters. More advantages include no curls, kinks, wire splinters or sore fingers.
B_faster
B_faster's Reviews
12-15-2009, 07:29 AM
Price: $550.00
Pros: Lighter and Stronger
Cons: None
Recommended? Yes
Comments: Cant wait to pull with it. Much safer than wire, Lighter and stronger.
meek61480
meek61480's Reviews
03-19-2009, 09:39 PM
Price: $349.00
Recommended? Yes
Comments: best i haver ever seen. he is here in bellingham wa and he personaly installed the line. he even threw in a few d rings. i got to grey. it holds 21k lbs!!! enyone with cable line needs to give these guys a call and get the best there is, and thats masterpull all the way.
acrijos
acrijos's Reviews
11-14-2008, 01:54 PM
Recommended? Yes
Comments: It greatly reduced weight on the front. It is also easier to handle and it has allowed me to increase the lenght that I carry in my winch.
Loctup
Loctup's Reviews
11-02-2008, 11:21 AM
Price: $175.00
Recommended? Yes
Comments: Completely destroyed my stock winch cable on it's first real test. It held, and got me out, but was so birdcaged and kinked as to be unable to respool completely. Replaced with Amsteel Blue. No worries.
Jason, aka: Jeepin.com
Vendor
Jason, aka: Jeepin.com's Reviews
06-02-2008, 10:26 AM
Price: $280.00
Recommended? Yes
Comments: Switched both our Jeeps to rope about 5 years ago and would never run steel cable again. So much easier and safer to use and handle.
sierraclimber1
sierraclimber1's Reviews
04-29-2008, 09:43 PM
Recommended? Yes
Comments: killer line that even floats. Got a thimble and rollers too. 30 percent stronger than steel.
goce61
goce61's Reviews
04-27-2008, 09:42 AM
Price: $200.00
Recommended? Yes
Comments: nice to use
bobby john'son_asd-d!
bobby john'son_asd-d!'s Reviews
04-11-2008, 04:04 PM
Price: $100.00
Recommended? Yes
Comments: Works wonderful!
kieth
kieth's Reviews
02-16-2008, 08:51 PM
Price: $50.00
Recommended? Yes
Comments: Has worked out well!
fried_gold
fried_gold's Reviews
08-06-2006, 02:59 PM
Recommended? Yes
Comments: That's interesting. If you do the math, it would take nearly a sixteenth of an inch to add 3500 lbs of strength, making their rope close enough to 7/16 that they would have to label it as such or people wouldn't be able to fit it on their winch.
I couldn't find my electronic calipers but I measured mine with slide calipers and it's dead on 3/8. Since rope isn't exactly a solid object, I wasn't sure how accurate that was so I put two pennies on each side and measured the rope then subtracted the width of pennies and still came up with 3/8.
I suspect it may be a little bit larger, but a little bit stronger as well. At any rate, I don't trust anyone's rope measuring (mine especially) or rating system enough to say for sure.
mrblaine
Brake Wizard
mrblaine's Reviews
08-06-2006, 09:07 AM
Recommended? Yes
Comments: As a clarification on the strength ratings, if you have a way to measure the diameter exactly, you will find that the diameter of the MP is a European standard and is slightly larger than other manufacturer's offerings in the diameter classification.
Not a reason not to buy, but it's a cute marketing trick that works pretty well.
I think it's similar to the difference between 10mm and 3/8's. 10mm is .393 in diameter and 3/8's is .375. That's .018 difference and when you're dealing with fibers with that much strength, a few of them will make a huge difference in the overall strength rating.
fried_gold
08-03-2006, 05:28 PM
Price: $200.00
Pros: Strength, durability, safety, price
Cons: None
Recommended? Yes
Comments: After winching for a while with wire cable and battling kinks and coils, I decided that was for suckers and went shopping for a good synthetic line. Truth be told, I almost chose Masterpull because it came in a nice dull silver color instead of the brighter green and blue coloring that most synthetic lines sport, but what actually sold me on Masterpull was that their basic 3/8 winch line is rated at 23,500 lbs while most other brands are rated at 20,000 lbs (give or take a few hundred). You can buy stronger synthetic line, but it is more expensive and I wasn't interested in spending 300 more dollars for a couple thousand extra pounds of rating. At the time, Masterpull had the strongest basic line I could find, and probably still does.
I've been very pleased with the line. It's pulled me out of many stuck situations and is orders of magnitude easier to use than steel cable. If someone is helping rig my line for a pull, I feel a lot better knowing all the dangers that go with steel cable are no longer present.
ThreadForumRepliesLast Post
SmittyBilt XRC 8 Winch Winches 209 11-12-2011 06:01 PM
Viking Offroad 3/8" x 80' Trail line w/tube thimble eye & Excel hook Winch Cable and Hooks 4 12-31-2010 06:44 AM
Viking Offroad 3/8" X 100' Viking Fire Line with Winch Safety Thimble Winch Cable and Hooks 10 07-11-2009 01:27 PM
Gorilla Winch 12,000lb Winches 5 05-16-2009 12:29 PM
Bulldog Winch 12k Winches 1 04-12-2008 12:39 PM
Glock Forum
