Warn X8000i
Rating: |
Product Information
| MSRP: |
$800.00 |
| Average Price: |
$348,302.17 |
| Manufacturer: |
Warn |
| Recommended? |
Warn X8000i, 8000 lb winch with integrated solenoid.
Rubby04's Reviews
Price: $750.00 Pros: Tough as ever Cons: None Recommended? Yes
Comments: Owned since 2004, bought new, love the thing. If I had to do it all over, I would still buy this winch. I love Warn products.
GreyfoxVt's Reviews
Price: $412.00 Pros: Fast line speed and great Jeep sixe, not overkill, just right Cons: Covers are hard to find, and may need modification to fit Recommended? Yes
Comments: A full 8,000 lb. pulling capacity makes this winch great for lighter trucks, Jeeps, and SUVs. Quick line speed, durable construction, and WARN dependability ensure this winch will come through time and time again.
Legendary WARN reliability and performance; 8,000 lb. (3630 kg) capacity
Low-profile design will fit most trucks and SUVs
Separate control pack for various mounting options
Exclusive brake design for superior winching control
Durable, smooth, and reliable three-stage planetary geartrain
Series-wound motor for plenty of power and fast line speed
Remote control with 12' (3.7m) lead
94' of 5/16" (28.6m of 8mm) diameter wire rope
Backed by the full WARN Limited Lifetime Warranty
Billy's Reviews
Price: $1.00 Pros: gets the job done every time. Cons: I'll let you know when I find a problem Recommended? Yes
Comments: I haven't had any issues with this winch. It pulls fine and is more than enough for light to moderate situations. Mine Gets wet a lot and has yet to fail me. Pulled a lot of wrecks. The only maintenance I've needed to perform was to pull a bad solenoid. Everything else is just making sure its properly lubed and your good to go. great product.
Squamer's Reviews
Price: $1.00 Pros: Great Winch..... Cons: ....no longer manufactured. Recommended? Yes
Comments: This winch is very good all around. Size wise...it is just right. 8000 lbs worth of pull, on a YJ, that's plenty. If you can find one...buy it. Even if you don't need it, buy it anyway.
The only thing I did not like about the X8000i was that integrated solenoid pack. I like to relocate the box to it keep out of harm's way. Easy to wire a remote winch control.
Also make sure that you have a very strong winch plate to mount to....in addition, make sure the frame bolts are not in bad shape of the front frame rails are not rusted. Mount it rock solid, if you don't...it will rip right off the frame.
jeeptree2112's Reviews
Price: $500.00 Pros: strong remote control Cons: let you know when it lets me down Recommended? Yes
Comments: discontinued years back
9000xi replaced it
great winch
basivey's Reviews
Price: $8,000,000.00 Pros: warn reliability Cons: kinda slow as compared to newer models and new brands Recommended? Yes
Comments: I like it in conjunction with my wireless setup
JDePietro's Reviews
Price: $100.00 Pros: integrated solonoid, Very fast line speed, Cons: Heavy Recommended? Yes
Comments: Got this by luck. A Fire Chief I used to run with was upgrading fire trucks. They found it in a compartment and didn't see a need or use for it. I snatched it up cheap and had to order some missing parts. Cleaned her up and made sure everything worked. One week after I mounted and installed everything a friend got his F250 stuck in some mud. Just barely up to the axles but enough that he wasn't going anywhere. I didn't think my winch could handle it but I gave it a try. Pulled him and the lawn tractor he went in after out like they were on pavement. Amazing winch, I would have paid full price to own this thing I just got lucky.
Army_Barbie's Reviews
Price: $650.00 Pros: dont know yet. havnt used it Cons: dont know yet. havnt used it Recommended? Yes
Comments: dont know yet. havnt used it
xantasm's Reviews
Price: $1,000.00 Pros: Its a Warn winch, what more do I need to say? Cons: None I can think of. Recommended? Yes
Comments: I honestly dont think I could say anything about a Warn winch that hasnt already been said. Warn makes some of the best recovery winches on the market and has been a trusted brand name for many years. I think the newer style controlor recently released is more user friendly than the old one. There are some other pretty good brand winches out there and some probably cheaper than a Warn winch, but then you get what you pay for.
rstolz's Reviews
03-24-2009, 03:08 PM |
Warn X8000i
Price: $550.00 Recommended? Yes
Comments: Great Winch. Need to use it more. It is simple to use. It was simple to install. I would like to have in-cab controls for it, but lots are made.
Du510's Reviews
12-28-2008, 12:15 PM |
Warn X8000i
Recommended? Yes
Comments: Its got solenoid issues, presumably due to the age & use. But aside from that, its pretty stout.
paulzwieg's Reviews
11-12-2008, 04:05 PM |
Warn X8000i
Price: $500.00 Recommended? Yes
Comments: /cool winch wish I had more to say to use up 75 characters I will not add anymore stuff if I have to keep typeing
DP7197's Reviews
11-12-2008, 06:17 AM |
Warn X8000i
Comments: Awesome winch and the integrated solenoid works well with the ARB bumper. Never had an issue with it. Hope to add synthetic rope to it one day.
rea50r's Reviews
10-24-2008, 11:37 AM |
Warn X8000i
Recommended? Yes
Comments: This is an awesome winch.It came with my jeep,the other day I sucked out a Dodge 4 dr crewcab.Was stuck pretty good in the middle of the river.I had to tie off at the rear of my jeep to keep from gettin sucked in but once I did the winch went to work!
Astiroth's Reviews
09-10-2008, 10:57 PM |
Warn X8000i
Price: $600.00 Recommended? Yes
Comments: Pretty good winch, wish it had a higher clearance for the cable. But overall has performed well.
bigchiconky's Reviews
07-08-2008, 05:03 PM |
Warn X8000i
Recommended? Yes
Comments: came with jeep when i purchased it- it works great, but havent been stuck where lockers couldnt get me out.
cjlineman's Reviews
06-25-2008, 08:15 PM |
Warn X8000i
Price: $800.00 Recommended? Yes
Comments: it's pulled me out of a couple of tight spots alway without any problems.easy to operate will probably go to synth. line though
Clamwacker's Reviews
06-20-2008, 01:56 AM |
Warn X8000i
Price: $1.00 Recommended? Yes
Comments: Came with the Jeep. So far I have used it to pull myself out of a giant sandy pit full of bushes, and it worked flawlessly. ($1 indicates it came with the Jeep I guess)
JAZ31's Reviews
06-07-2008, 03:40 PM |
Warn X8000i
Recommended? Yes
Comments: Used it several times to winch tree limbs & logs. Haven't had a need for serious use. Easy to use.
firedog348's Reviews
06-04-2008, 02:25 PM |
Warn X8000i
Price: $300.00 Recommended? Yes
Comments: A few minor problems, Well used!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!!!!11111
