Notices
Warn VR8000 Reviews, Ratings, Specs & Prices
Review Categories
Armor
  Bumpers
  Differential Guards
  Rocker Guards
  Roll Cages
  Skid Plates
Audio, CB, & Electrical
  Audio Players
  Batteries
  CB & Ham Radios
  GPS
  Speakers
Axles
  Axle Shafts
  Brakes
  Gears
  Hubs
  Lockers
  Steering
Body
  Body Lifts
  Consoles, Security & Storage
  Exterior Accessories
  Fender Flares
  Lighting, Lenses & Bulbs
  Roof Racks & Cargo Areas
  Tops
Engine
  Alternators
  Carburetors
  Chips
  Exhaust
  Headers
  Induction
  Internal Parts
  Motor Mounts
  Starters
  Throttle Body
Interior
  Gauges
  Misc
  Seats
Recovery
  Winch Cable and Hooks
  Winches
Suspension
  Complete Lift Kits
  Control Arms
  Shocks
  Springs
  Steering Stabilizers
  Track Bars
Tires & Wheels
  Tires
  Wheels
Transfer Case
  SYE Kits
  Transfer Cases
Transmissions
  Transmissions
Previous Product Winches Next Product
Warn VR8000
Rating:
Product Information
MSRP: $479.99
Average Price: $469.81
Manufacturer: Warn
Recommended?
Yes: 16 / No: 0
Company Website: http://www.warn.com
A full 8,000 lb. pulling capacity makes this winch great for lighter trucks, Jeeps, and SUVs. Quick line speed, durable construction, and WARN dependability ensure this winch will come through time and time again.
Legendary WARN reliability and performance; 8,000 lb. (3630 kg) capacity
Low-profile design will fit most trucks and SUVs
Separate control pack for various mounting options
Exclusive brake design for superior winching control
Durable, smooth, and reliable three-stage planetary geartrain
Series-wound motor for plenty of power and fast line speed
Remote control with 12' (3.7m) lead
94' of 5/16" (28.6m of 8mm) diameter wire rope
Backed by the full WARN Limited Lifetime Warranty
*VR line available for sale only in USA and Canada.
*Product warranty void outside USA and Canada.
VR8000 SPECS/PART NUMBERS
Part numbers: 86245
Rated line pull: 8000 lbs. (3629 kgs)
Motor: 12V DC, Series Wound
Electrical controls: Solenoid
Remote Control: Remote switch, 12 ft. (3.7m) Lead
Geartrain: 3-Stage Planetary
Gear ratio: 216:1
Clutch (freespooling): Sliding Ring Gear
Brake: Automatic Direct Drive Cone
Drum diameter/Length: 2.5 in./9.0 in. (6.4cm/23cm)
Weight (kit shipping): 80 lbs. (36.3 kgs)
Wire rope: 5/16 in. x 94 ft. (8mm x 29m)
Fairlead: Roller
Recommended Battery: 650 CCA minimum for winching
Battery leads: 2 gauge, 72 in. (1.83m)
Finish: Powder coat over primer undercoating
Warranty: Limited Lifetime
12V DC PERFORMANCE SPECS
Line Pull
Lbs.(Kgs.) Line Speed
FT./min(M/min.) Motor
Current Pull by layer
layer/Lbs(Kgs.)
0 29 (8.8) 69.2 amps 1/8000 (3629)
2000 (910) 14.2 (4.3) 179.2 amps 2/7280 (3302)
4000 (1810) 9.9 (3) 281 amps 3/6670 (3026)
6000 (2720) 7.3 (2.2) 381 amps 4/6230 (2826)
8000 (3630) 4.8 (1.4) 457 amps
Above performance specs are based on first layer of drum
Winch Dimensions: 20.80 in. L x 6.3 in. D x 6.97 in. H (528mm L x 160mm D x 177mm H)
Mounting Bolt Pattern: 10.0 in. x 4.5 in. (254mm x 114.3mm)
None
98TJSE
98TJSE's Reviews
10-24-2015, 02:29 PM
Price: $423.00
Pros: price, warn warranty
Cons: made in china
Recommended? Yes
Comments: seems to be well built and up to Warn standards, along with warn's warranty , only time will tell since winter is here and it gets most its use ..
mike1919
mike1919's Reviews
06-27-2015, 10:28 PM
Price: $350.00
Pros: Economical, good name behind it, easy install
Cons: None so far
Recommended? Yes
Comments: VR8000 has done everything I've asked of it. Pulled me out of several deep holes at steep angles. If I had to do it again I would opt for the synthetic rope option! Steel is a bit cheaper and proven, but re-winding is a pain and rust/corrosion over time are a worry. Invest in a cover as it did NOT include one.
Jeeper4life88
Jeeper4life88's Reviews
02-25-2014, 09:48 PM
Price: $450.00
Pros: The "Warn" name at a great price!
Cons: Can't think of any!
Recommended? Yes
Comments: This is a great entry level winch that is Warn quality at a value price! Spend the extra money on a Warn vs the cheaper winches. This winch has been submerged at times and still continues to work great. It has yet to let me down!
XJ93
XJ93's Reviews
02-11-2014, 05:15 PM
Price: $479.00
Pros: Lower cost makes it easy on the wallet. Great entry level winch for a light rig that isn't built to the hilt.
Cons: None so far
Recommended? Yes
Comments: Installation was a breeze, have yet to really use it. I will update this review once I have used the winch a few times.
edinct
edinct's Reviews
11-09-2013, 02:42 PM
Price: $730.00
Pros: high quality
Cons: none
Recommended? Yes
Comments: great product with synthetic line
obxcarolina
obxcarolina's Reviews
07-25-2013, 02:02 AM
Price: $600.00
Pros: actually i have the vr10000 but it wasnt in the drop down. looks great, its a W. came with synthetic cable and a nice hook. but i am currently using a shackle
Cons: none so far
Recommended? Yes
Comments: looks and functions great. great bargin price and bolted right up to the bumper
Audi4awrangler
Audi4awrangler's Reviews
04-05-2013, 02:04 PM
Price: $550.00
Pros: Beast
Cons: Drains Battery Quick
Recommended? Yes
Comments: Monster, Never Fails
CharlieHo
CharlieHo's Reviews
03-07-2013, 11:13 PM
Price: $479.00
Pros: Super easy to install, decent price point
Recommended? Yes
Comments: This is an economical choice from Warn. I didn't want to spend less and end up with Chinese junk.
Warn has a reputation and I'm sure they're not going to risk it anytime soon.
mrv
mrv's Reviews
10-14-2012, 12:44 AM
Price: $427.00
Pros: Price size warranty
Cons: Poor install instructions
Recommended? Yes
Comments: I think its an entry level winch, but it appears it will do the job. I have not had the chance to use it yet. I used a smitty mounting bracket for the original bumper, it was a pain, but it turned out pretty good.
Natesjk
Natesjk's Reviews
10-09-2012, 10:24 PM
Price: $400.00
Pros: Great powerful winch. Warns lifetime warranty and legendary customer service. Easy install. Great price for what you get.
Cons: Can't say I have any yet
Recommended? Yes
Comments: I gotta say I bought this winch back in June and am more than pleased with it. Don't let the "entry level winch" turn you away its the real deal. I have used about a dozen times. Mainly pulling myself out of deep mud holes. Also yanked a dodge Dakota out of a ditch. I truely am 100% satisfied with my purchase and know it will always get me home.
toxicwaste29
toxicwaste29's Reviews
09-02-2012, 10:47 AM
Price: $500.00
Pros: Easy to install, seems reliable/dependable
Cons: n/a
Recommended? Yes
Comments: I installed this in about 30min without the instruction. Very easy install and i have yet to use it but it seem reliable
Butterbuddha
Butterbuddha's Reviews
03-15-2012, 01:02 AM
Price: $500.00
Pros: Its a WARN, nothing else needs to be said.
Cons: More expensive than cheap Chinese counterparts
Recommended? Yes
Comments: Not much can be said, WARN quality has been known for decades now. I don't see this product being any different. Still has the famous WARN warranty in case something does go awry!
jeepinhokie
jeepinhokie's Reviews
02-15-2012, 11:06 AM
Price: $430.00
Pros: cost, Warranty,
Cons: controller connection
Recommended? Yes
Comments: I got this winch for Christmas and promotly put it on my TJ. I pulled myself up a hill attached to the back of a truck to get the winch line nice and tight. everything worked great, its not the fastest winch out there, but it gets the job done. I winched for a little bit then gave it a rest, thinking that the motor would be hot. It was not hot in the slightest.
I recently gave this winch a real workout and it worked great. wheeling in Gore VA in the snow was fun, but required a lot of winching. probably pulled myself 10-12 times over the two days.
only time will tell if this winch will hold up as well as the rest of the Warn line.
dougmorgan99
dougmorgan99's Reviews
01-03-2012, 08:13 AM
Price: $479.00
Pros: Heavy duty. Lifetime Warranty for a Warn "budget" winch.
Cons: None at the moment.
Recommended? Yes
Comments: For sure a much needed accessory for a Jeep. I have not had a chance to test it out yet but I will the first chance I get. Instructions were very clear and spot on. Packing was awesome as well that protected it during shipping.
mark422
mark422's Reviews
12-11-2011, 08:47 PM
Price: $400.00
Pros: n/a
Cons: n/a
Recommended? Yes
Comments: great bang for your buck
jeepinmichguy_
Soar Forever Six
jeepinmichguy_'s Reviews
06-26-2011, 12:35 PM
Price: $320.00
Pros: Low cost, great warrenty, Warn name, 8000 lbs, nice finish
Cons: faulty wiring out of the box
Recommended? Yes
Comments: I purchased this winch on the fly at Jeep beach because of the $400 out the door price plus an $80 mail in rebate and the Warn name. I figured since it had the same warrenty as the other winches in Warn's line why not try it. Unlike the M8000 this winch came with the solenoid box mounting plate and a roller fairlead. Putting the soliniod on the winch and hooking it up was a breeze.
As soon as I had it mounted i went to test it and noticed that i had to wiggle the connector where the remote hooks to the solenoid to get it to make good contact and work. I was getting ready to go on a wheeling trip so i figured I would get it taken care of when I got back. I made a total of 3 pulls on this winch before one of the pins was pushed so bad it would not make contact anymore.
Upon return home I promptly contacted Warn and they gave me the number to one of the guys that does their warrenty work 15 minutes from my house. He allowed me to just remove the solenoid box and take it to him for warrenty work. In less than a week I had the box back with a new pigtail and it cost me nothing but a few buck in gas. Warns customer service and warrenty process makes them a no brainer to use in the future for me, my M8000 has been working with no issues but corrosion on the connectors (my fault) since 2003 with out a hiccup. I would recommend over other low budget winches for the simple fact that warn takes care of there people when issues arise.
ThreadForumRepliesLast Post
Warn Powerplant hp Winches 37 02-07-2016 10:46 AM
Warn 8k Winch Cable and Hooks 21 10-22-2014 08:32 PM
Warn 9.5 ti Winches 135 07-10-2014 02:47 PM
Warn 9.5xp Winches 8 07-19-2011 06:08 PM
Warn Warn Works 4700 Winches 1 12-27-2008 10:25 AM
