Go Back JeepForum.com > Reviews > Recovery > Winches > Warn M8274-50
GR8TOPS Introduces the Exogate HD Tire CarrierJcrOffroad new Crusader TJ/YJ/CJ Bumpers available!!JKS products - Free shipping! Lowest prices!
Warn M8274-50 Reviews, Ratings, Specs & Prices
Review Categories
Armor
  Bumpers
  Differential Guards
  Rocker Guards
  Roll Cages
  Skid Plates
Audio, CB, & Electrical
  Audio Players
  Batteries
  CB & HAM Radios
  GPS
  Speakers
Axles
  Axle Shafts
  Brakes
  Gears
  Hubs
  Lockers
  Steering
Body
  Body Lifts
  Consoles, Security & Storage
  Exterior Accessories
  Fender Flares
  Lighting, Lenses & Bulbs
  Roof Racks & Cargo Areas
  Tops
Engine
  Alternators
  Carburetors
  Chips
  Exhaust
  Headers
  Induction
  Internal Parts
  Motor Mounts
  Starters
  Throttle Body
Interior
  Gauges
  Misc
  Seats
Recovery
  Winch Cable and Hooks
  Winches
Suspension
  Complete Lift Kits
  Control Arms
  Shocks
  Springs
  Steering Stabilizers
  Track Bars
Tires & Wheels
  Tires
  Wheels
Transfer Case
  SYE Kits
  Transfer Cases
Transmissions
  Transmissions
Previous Product Winches Next Product
Warn M8274-50
Rating:
Product Information
MSRP: $1,580.00
Average Price: $578.47
Manufacturer: Warn
Recommended?
Yes: 20 / No: 0
M8274-50 SELF-RECOVERY WINCH
Loved by off-roaders who compete, it's our fastest winch. No load retrieval speed for the M8274-50 is 73.4 feet per minute and that's not all. At 150 feet of 5/16" cable, it also has a very long line capacity. Its unique spur-gear drive train and upright design are totally rugged. Its braking system delivers smooth operation with superior heat dissipation. Roller fairlead, remote control on 12-ft. lead, free spool clutch and battery cables are included.
Part Numbers: PN 38631 CE (12V DC) , PN 375832 CE (24V DC)
Rated Line Pull: 8000 lbs. (3630 kgs.) single-line
Motor: 12V 4.6 hp/3.43kw, 24V 2.5 hp/3.43kw, Series WoundTM
Remote Control: Remote switch, 12' (3.7m) lead
Geartrain: Spur Gear
Gear Ratio: 134:1
Lubrication: 6 oz. SAE 30 (non-detergent)
Clutch (freespooling): Sliding Motor Pinion Gear
Brake: Automatic, disc type
Drum Diameter/Length: 3.5"/8.5" (9cm/22cm)
Weight: 110 lbs. (50 kgs.)
Wire Rope: 150', 5/16" diameter (46m, 8mm diam.)
Fairlead: Roller
Recommended Battery: 650 CCA for winching
Battery Leads: 2 gauge, 72" (1.83m)
Finish: Argent Gray Powder Coat with Clear Coat
Nuts: PN 7616, L/W: PN 2146
Bolts: PN 7165
CE Winches: CE products are designed to meet European Standards. CE winches include CE labels, manuals, roller fairlead, safety hook and thimble.
Winch Dimensions: 16.5" L. x 8.5" D. x 15" H.
(420mm L. x 220mm D. x 381 mm H.)
Mounting Bolt Pattern: 10.0" x 4.5" (254mm x 114.3mm)
bbusch
bbusch's Reviews
01-15-2012, 02:47 PM
Price: $1,479.00
Pros: Design, reliability, looks, line speed... What's not to like!
Cons: Close mount to my TJ grill and blocks several of the grill vents. For some possibly the size and weight.
Recommended? Yes
Comments: Wanted this winch for fifteen years and after running XDs and the ti I finally splurged because Warn was offering a two hundred dollar rebate.
manicjester3
Junior Member
manicjester3's Reviews
11-10-2011, 09:34 PM
Price: $450.00
Pros: Best winch ever made for about $2000 less than Warn sells it for!
Cons: Probably too good of a winch... And probably limits cooling capacity, but who cares about staying cool?
Recommended? Yes
Comments: Been looking for one of these babies used for about 2 years now. Finally found one at a price I liked!
talldriver
Newbie
talldriver's Reviews
07-18-2011, 08:10 PM
Price: $50.00
Pros: great winch but wveryone knows that
Cons: solenoids exposed to alot of weather
Recommended? Yes
Comments: bought mine from a guy with a junk pile behind his house, great find understates this one was an original amc factory winch says "JEEP" has old amc incignia and made by warn winch co for amc jeep still has original motor and cable had to replace brake and solenoids were replaced and relocated under hood
skiandgolf
skiandgolf's Reviews
04-17-2011, 03:25 PM
Price: $200.00
Pros: 30+ years old and still works fine, so you tell me.
Cons: Heavy and blocks airflow
Recommended? Yes
Comments: Older 8274 picked up off CL for cheap. Needed lots of cleaning, and someone had decided to run grease inside rather than the intended oil. Lot's of fun cleaning the grease out!
arkiemurph
arkiemurph's Reviews
11-06-2010, 07:58 PM
Price: $325.00
Pros: bad to the bone, speed and power
Cons: heavy, blocks some cooling airflow
Recommended? Yes
Comments: Yal know it's the best!
elpound
Junior Member
elpound's Reviews
12-27-2009, 12:52 AM
Price: $1,100.00
Pros: Great winch and a well proven design. i love the style of the newer mouting plates. Very stong.
Cons: Sits high on my TJ, but I haven't experianced and cooling problems.
Recommended? Yes
Comments: What is there not to love about this winch? It is fast, durable, and has been around forever. I like it's old school looks too.
sar50
Newbie
sar50's Reviews
12-18-2009, 01:52 AM
Price: $200.00
Pros: Reliable High Speed work horse. Can still get parts to repair.
Cons: upright profile is harder to find mounts for and obscures more of the grill opening
Recommended? Yes
Comments: I bought this winch used many many years ago for a couple hundred bucks. It has been throught three vehicles and and an extended period of non-use sitting outside. With a couple of relays, a few maintenace pieces and some clean up time, it's working great and hopefully good to go for another 10-15 years.
W7NB
Educated Redneck
W7NB's Reviews
12-06-2009, 12:30 AM
Price: $300.00
Pros: Fast, holds lots of cable
Cons: large, takes special mounting plate
Recommended? Yes
Comments: Purchased used. Works great for the jeep. Running a single Red top Optima with it so I need to add a 2nd battery to get full potential.
SOUTHERN-CJ5
SOUTHERN-CJ5's Reviews
07-17-2009, 09:32 PM
Price: $400.00
Pros: Speed, reliability
Cons: none
Recommended? Yes
Comments: This winch works great. It is very fast under no load, and works flawlessly. It is an older model, probably mid 80s. But it still works great.
cjmike67
cjmike67's Reviews
03-07-2009, 01:03 AM
Warn M8274-50
Price: $1,580.00
Recommended? Yes
Comments: Best winch money can buy!Has incredible line speed and endurance.Also has the longest cable at 150 feet!
Kimberfan
Kimberfan's Reviews
08-08-2008, 03:09 AM
Warn M8274-50
Recommended? Yes
Comments: Not one of the new ones, but the older ones. I like it and when I have to give it back to my brother I'll be buying one myself.
bigredcherokee
bigredcherokee's Reviews
08-06-2008, 10:01 PM
Warn M8274-50
Price: $200.00
Recommended? Yes
Comments: I have a used 8274 Great winch fast spool out and return. Steel gears not a bit of trouble from this winch,
NWFatboy
NWFatboy's Reviews
07-12-2008, 06:16 AM
Warn M8274-50
Price: $250.00
Recommended? Yes
Comments: Works great unless I forget to connect my auxillary battery to the alternator. Doh!
natedogg
natedogg's Reviews
04-23-2008, 10:13 PM
Warn M8274-50
Recommended? Yes
Comments: ive pulled a big work truck out, that was stuck in snow on top of mud. i pulled some heavy stuff out with this winch!
04limegreen
04limegreen's Reviews
04-13-2008, 09:32 PM
Warn M8274-50
Price: $500.00
Recommended? Yes
Comments: best winch you can buy
97TJGUZZY
97TJGUZZY's Reviews
04-12-2008, 09:06 PM
Warn M8274-50
Price: $200.00
Recommended? Yes
Comments: Great winch, Got it used and its never failed me.
TSEJEEPERS
TSEJEEPERS's Reviews
04-03-2008, 08:45 AM
Warn M8274-50
Price: $1,000.00
Recommended? Yes
mustangtoby
mustangtoby's Reviews
03-17-2008, 08:12 PM
Warn M8274-50
Price: $1,300.00
Recommended? Yes
Comments: no complaints whatsoever.
rgingerelli99tj
rgingerelli99tj's Reviews
02-27-2008, 01:03 PM
Warn M8274-50
Price: $300.00
Recommended? Yes
Comments: I installed the Warn 8274 not the 8274-50. I bought it from a guy parting out a 1973 CJ-7 and the winch came on the CJ from the dealer, and says on it "Jeep Stock Special Equipment" Its 30 something years old and still running.
maximum729
maximum729's Reviews
02-26-2008, 01:48 PM
Warn M8274-50
Pros: Fast wind speed, 10+years of maintenance free use
Cons: physical size (blocking front radiator)
Recommended? Yes
Comments: I actually have the 8274, not the -50, and it still works AMAZING. NEVER a hickup with it's performance, even using a stock battery.
ThreadForumRepliesLast Post
Warn 9.5 ti Winches 110 07-27-2011 09:41 AM
Warn 9.5xp Winches 5 06-28-2010 07:21 AM
Warn 8k Winch Cable and Hooks 11 11-18-2009 10:32 AM
Warn 8274-50 Winches 0 04-16-2009 08:43 AM
Warn Warn Works 4700 Winches 1 12-27-2008 11:25 AM
Glock Forum
