Warn M8000 Reviews, Ratings, Specs & Prices
Review Categories
Armor
  Bumpers
  Differential Guards
  Rocker Guards
  Roll Cages
  Skid Plates
Audio, CB, & Electrical
  Audio Players
  Batteries
  CB & Ham Radios
  GPS
  Speakers
Axles
  Axle Shafts
  Brakes
  Gears
  Hubs
  Lockers
  Steering
Body
  Body Lifts
  Consoles, Security & Storage
  Exterior Accessories
  Fender Flares
  Lighting, Lenses & Bulbs
  Roof Racks & Cargo Areas
  Tops
Engine
  Alternators
  Carburetors
  Chips
  Exhaust
  Headers
  Induction
  Internal Parts
  Motor Mounts
  Starters
  Throttle Body
Interior
  Gauges
  Misc
  Seats
Recovery
  Winch Cable and Hooks
  Winches
Suspension
  Complete Lift Kits
  Control Arms
  Shocks
  Springs
  Steering Stabilizers
  Track Bars
Tires & Wheels
  Tires
  Wheels
Transfer Case
  SYE Kits
  Transfer Cases
Transmissions
  Transmissions
Previous Product Winches Next Product
Warn M8000
Rating:
Product Information
MSRP: $600.00
Average Price: $482.47
Manufacturer: Warn
Recommended?
Yes: 49 / No: 0
(M8000 pictured with the Roller Fairlead)
Compact. Tough. An outstanding value. Available with a roller or hawse fairlead and your choice of 80 or 100' of 5/16" diameter wire rope. Pulls a fast 8 ft. per minute at rated load.
Click for Picture of Hawse Fairlead or Roller Fairlead
M8000 Winch Specifications
Part Number: 20910 80' wire rope and hawse fairlead
Part Number: 26502 100' wire rope and roller fairlead
Part Number: 265032 100' wire rope, roller fairlead, safety hook and thimble
Rated Line Pull: 8000 lbs. single-line
Motor: 12V 4.8 hp, 24V 2.1 hp Series Wound
Remote Control: Remote switch, 12' lead
Geartrain: 3-Stage Planetary
Gear Ratio: 216:1
Lubrication: Aeroshell #17
Clutch (freespooling): Sliding Ring Gear
Brake: Automatic Direct Drive Cone
Drum Diameter/Length: 2.5"/9.0"
Weight: 74 lbs.
Wire Rope: 80', 5/16" diameter. or 100', 5/16" diameter
Fairlead for 20910: Hawse
Fairlead for 26502, 265022, 265032: Roller
Recommended Battery: 650 CCA minimum for winching
Battery Leads: 2 gauge, 72"
Finish: Argent Gray Powder Coat
Nuts/Bolts: 39625
12V DC PERFORMANCE SPECS
Line Pull Lbs. Line Speed FT./min Motor Current Pull by layer layer/Lbs.
0 42 80 amps 1/8000
2000 16 200 amps 2/7280
4000 11.9 285 amps 3/6670
6000 9.79 350 amps 4/6230
8000 8.01 435 amps
24V DC PERFORMANCE SPECS
0 27.3 46 amps 1/8000
2000 17.1 99 amps 2/7460
4000 12.6 145 amps 3/3980
6000 10.3 190 amps 4/6620
8000 8.8 235 amps
None
Page 2 of 3 1 2 3 > Last
Disco69
Disco69's Reviews
10-14-2009, 12:09 PM
Price: $539.00
Pros: Fast pull, pretty cheap
Cons: Heavy
Recommended? Yes
Comments: So far this winch has performed quite well. I'm very happy with the purchase. I suggest swapping out the cable with synthetic winch line. It is quite heavy as it is.
Firedog13
Firedog13's Reviews
06-09-2009, 12:39 AM
Price: $700.00
Pros: Works great
Cons: Can't think of any
Recommended? Yes
Comments: I've only used it once, but it was to pull the neighbor's truck out of a ditch. He slid off a muddy road and got stuck pretty bad. Used the winch with a single line pull. Pulled him out of that muck with no problem. After I pulled him out, we noticed that the truck's axle actually drug the ground most of the way out. I was pretty impressed.
JJR00XJ
JJR00XJ's Reviews
04-06-2009, 05:26 PM
Warn M8000
Price: $509.00
Recommended? Yes
Comments: Nice winch for the money. Figured I'd buy a popular model that I can trust.
CeeJayFiver
CeeJayFiver's Reviews
03-30-2009, 04:29 PM
Warn M8000
Recommended? Yes
Comments: Awesome, could easily pull Jeep off the ground, only used it to test it and it is STRONG
rog1997
rog1997's Reviews
03-29-2009, 03:37 PM
Warn M8000
Price: $549.00
Recommended? Yes
Comments: Good solid winch, no problems past 3 years. Did add a snythetic line. xxxxxxxxxxxxxxxxxxxxxxx
DocHolliday
DocHolliday's Reviews
03-26-2009, 10:52 PM
Warn M8000
Price: $600.00
Recommended? Yes
Comments: This workhorse has pulled its heart out for me. The most unusual events were pulling a 3/4 2x4 pulling a 16' camping trailer out of the sand at South Padre Island. More than enough winch for the Wrangler, and reasonably priced.
itsajeepthang86
itsajeepthang86's Reviews
03-18-2009, 03:00 PM
Warn M8000
Price: $600.00
Recommended? Yes
Comments: I love this winch...I go wheeling with a friend who has a Blazer and this winch has recovered him many of times. The only time I have maxed it out was when he was about to roll over a 4 foot drop and with such a hard pull my battery cable termination melted so I don't know if the winch couldn't do the pull or if it just wasn't getting enough power.
wingshooter2009
wingshooter2009's Reviews
02-26-2009, 11:32 PM
Warn M8000
Recommended? Yes
Comments: .................................................. .................................................. ....
Miller57
Miller57's Reviews
02-02-2009, 07:53 PM
Warn M8000
Price: $500.00
Recommended? Yes
Comments: Good Winch and the price was right.
Mounted control box under brake booster, seems to be working.
OffRoadJeepr
OffRoadJeepr's Reviews
02-01-2009, 03:46 PM
Warn M8000
Price: $569.00
Recommended? Yes
Comments: Love it! Good line speed and enough pull. Would recommend it to anyone looking for a mid-grade winch and still watchin your wallet.
photontraveler
Old Dude
photontraveler's Reviews
01-18-2009, 08:01 AM
Warn M8000
Price: $569.00
Recommended? Yes
Comments: The Warn M8000 is very capable on the trail and off. The wire cable makes me a bit nervous but I plan on purchasing a synthetic cable shortly.............
turner94yj
turner94yj's Reviews
01-14-2009, 09:18 PM
Warn M8000
Price: $350.00
Recommended? Yes
Comments: .................................................. .................................................. .................................................. .................
mjp83
mjp83's Reviews
12-28-2008, 11:37 PM
Warn M8000
Price: $350.00
Recommended? Yes
Comments: Great winch with many uses! Does the job of recovering my rig just fine. picked it up used and had a new winch line installed - caution, always rewind your line properly after a pull, to lenghten wire life. Also, winch controllers are diffenerent between years of manufacturer of same type winch (found out the hard way, with new winch on jeep and unable to use it since controller was in garage AT HOME!)
VT_Jeeper
VT_Jeeper's Reviews
12-24-2008, 12:00 AM
Warn M8000
Price: $500.00
Recommended? Yes
Comments: good reliable winch............................................. .................................................. ..
mr_dees
mr_dees's Reviews
12-12-2008, 04:09 PM
Warn M8000
Price: $500.00
Recommended? Yes
Comments: only used it once so far!
awesomeawesomeawesomeawesomeawesomeawesomeawesomea wesomeawesomeawesomeawesomeawesomeawesomeawesomeaw esomeawesome
alex_35
alex_35's Reviews
12-10-2008, 11:28 PM
Warn M8000
Price: $550.00
Recommended? Yes
Comments: its strong,good quality,i would recomended this to other people,easy to install,this is simply the best.
DH19922010
DH19922010's Reviews
11-24-2008, 11:46 PM
Warn M8000
Price: $499.99
Recommended? Yes
Comments: Very good winch.It has more than enough power for my TJ and with a stable anchor available,it will get you out of almost any mess.I used it the day after i got it and it puled me out of a nasty mud pit with no problem.
mudslingernick
mudslingernick's Reviews
11-18-2008, 12:36 PM
Warn M8000
Price: $320.00
Recommended? Yes
Comments: good winch hasn't left me stranded. Got a good deal on it. easy to install. easy to use
99TJtoy
99TJtoy's Reviews
11-03-2008, 12:19 PM
Warn M8000
Price: $300.00
Recommended? Yes
Comments: I have the winch and a mounting plate. I have not had the time to get it mounted. Besides I want to put hooks on at the same time and I don't have everything yet.
Rockcrushingxj
Rockcrushingxj's Reviews
10-30-2008, 05:57 AM
Warn M8000
Recommended? Yes
Comments: This winch has been proven many times
to be top shelf! It was given to me for trade work, off of another Jeep
ThreadForumRepliesLast Post
Warn M8000 Winches 48 04-21-2017 09:22 AM
Warn M8000 Winches 157 06-30-2015 02:27 PM
Warn 8k Winch Cable and Hooks 21 10-22-2014 09:32 PM
Warn 9.5xp Winches 8 07-19-2011 07:08 PM
Warn Warn Works 4700 Winches 1 12-27-2008 11:25 AM
