Notices
Warn M-8000 Reviews, Ratings, Specs & Prices
Review Categories
Armor
  Bumpers
  Differential Guards
  Rocker Guards
  Roll Cages
  Skid Plates
Audio, CB, & Electrical
  Audio Players
  Batteries
  CB & Ham Radios
  GPS
  Speakers
Axles
  Axle Shafts
  Brakes
  Gears
  Hubs
  Lockers
  Steering
Body
  Body Lifts
  Consoles, Security & Storage
  Exterior Accessories
  Fender Flares
  Lighting, Lenses & Bulbs
  Roof Racks & Cargo Areas
  Tops
Engine
  Alternators
  Carburetors
  Chips
  Exhaust
  Headers
  Induction
  Internal Parts
  Motor Mounts
  Starters
  Throttle Body
Interior
  Gauges
  Misc
  Seats
Recovery
  Winch Cable and Hooks
  Winches
Suspension
  Complete Lift Kits
  Control Arms
  Shocks
  Springs
  Steering Stabilizers
  Track Bars
Tires & Wheels
  Tires
  Wheels
Transfer Case
  SYE Kits
  Transfer Cases
Transmissions
  Transmissions
Previous Product Winches Next Product
Warn M-8000
Rating:
Product Information
MSRP: $998.00
Average Price: $553.60
Manufacturer: Warn
Recommended?
Yes: 43 / No: 0
Warn Winch
None
Page 2 of 3 1 2 3 > Last »
DuckHunter
DuckHunter's Reviews
02-28-2011, 12:29 AM
Price: $550.00
Pros: Quick pull, quiet, American
Cons: -
Recommended? Yes
Comments: The winch pulls great. I have used it multiple times to save myself from some deep ruts and thick mud during solo wheeling(always around the house). It pulls great and is not loud. I would definitely recommend this winch.
Holdem2
Holdem2's Reviews
01-13-2011, 08:02 AM
Price: $350.00
Pros: compact, durable, strong.
Cons: power cables are too short, Solenoid should be weatherproof
Recommended? Yes
Comments: Bought new from a guy for less than half price, great find.
blk85cj7
Junior Member
blk85cj7's Reviews
10-07-2010, 01:00 PM
Price: $530.00
Pros: Well built, does everything I need it to at a decent price
Cons: None
Recommended? Yes
Comments: Its a good sturdy winch. Easy to install, use, and it hasn't let me down. Long cord for the controls so you can stay out of the way. What else can I say, it's a Warn.
zombiesmasher13
zombiesmasher13's Reviews
09-03-2010, 11:14 PM
Price: $300.00
Pros: its a warn
Cons: n/a
Recommended? Yes
Comments: good freaking winch
BPEN65
BPEN65's Reviews
07-21-2010, 06:18 PM
Price: $450.00
Pros: LOOKS GOOD, SELF CONTAINED CONTACTER HOUSING
Cons: NONE SO FAR
Recommended? Yes
Comments: INSTALLED LAST WINTER- NOT USED IT YET.
cbman
cbman's Reviews
04-29-2010, 09:02 PM
Price: $550.00
Pros: Excellent quality
Cons: None
Recommended? Yes
Comments: It's such a good price, the quality and power it has is amazing.
fduncan
fduncan's Reviews
04-23-2010, 09:31 AM
Price: $540.00
Pros: came with free remote
Cons: none
Recommended? Yes
Comments: Very good winch for a very good price and it came with a wireless remote. Can't beat it with a stick!
gmakra
gmakra's Reviews
04-05-2010, 07:53 AM
Price: $800.00
Pros: Good quality
Cons: none
Recommended? Yes
Comments: It just does what its supposed to do.
vonhef
vonhef's Reviews
03-03-2010, 04:36 PM
Price: $540.00
Pros: Fast & Powerful
Cons: Price
Recommended? Yes
Comments: Build quality seems to be good and the winch is fast and powerful.
Was aware when I purchased that I would need to order the solenoid mounting bracket separately; it should have been included. The mounting bracket is designed to be mounted with only one bolt. The single alen-head bolt that threads into the aluminum rod (that crosses the top of the winch) is what is used to hold this bracket. The problem arises when you tighten the bolt enough to keep the solenoid box from moving when plugging the cable in/out… is… you strip the aluminum threads. I solved the problem by installing GARDSERT threads in both side of the rod and then using grade 8 bolts to tighten. Warn could eliminate the issue by redesigning the mounting bracket to use two bolts, or using a better material in the rod.
I am happy with the product so far.
2ACR
That's Right I Support
2ACR's Reviews
02-05-2010, 02:04 AM
Price: $570.00
Pros: Didn't break the bank getting a winch that will last
Cons: Control box cables are way too short and warn does not provide any mounting hardware.
Recommended? Yes
Comments: What can you say about a warn winch. You get what you pay for but you also pay a little extra for the name. They could do a better job making the control box waterproof and give us the D*** mounting hardware. Most of us know by now that you just use a U-bolt plate. I have they not figured that out.
dahlski6
dahlski6's Reviews
02-01-2010, 04:01 PM
Price: $550.00
Pros: plenty of power, reasonable price
Cons: none
Recommended? Yes
Comments: Has gotten me out of a lot of jams. Highly recommended.
jeep2008
jeep2008's Reviews
12-27-2009, 05:46 AM
Price: $500.00
Pros: lifetime quarranty
Cons: more expensive than others with similar or better qualitys
Recommended? Yes
Comments: I haven't really put it into the test yet but it looks ready to take all you'll throw at it.The colour has allredy started to go away in some places though...
jlarsen2
jlarsen2's Reviews
12-08-2009, 08:04 PM
Price: $2,000.00
Pros: Works great and reliable
Cons: Had to replace several major components under warrenty though
Recommended? Yes
Comments: Had to replace several components which were several solinoids, a motor, and a clutch assembly all at different times. it has fulfilled its duty though and doesn't fail when under load pulled everything out that i had thrown at it.
limeking
limeking's Reviews
11-19-2009, 10:45 AM
Price: $565.00
Pros: roller fairlead and 100' of cable
Cons: no braket for the selinoid
Recommended? Yes
Comments: best winch for the price.
scdiver
scdiver's Reviews
11-18-2009, 07:57 PM
Price: $500.00
Pros: great small gets the job done not expensive easy to install
Cons: solenoids not waterproof
Recommended? Yes
Comments: easy to install even for the novice more than enough for a single rig gets the job done
RockyClymer
RedRock4Wheeler
RockyClymer's Reviews
05-10-2009, 05:25 PM
Price: $550.00
Pros: Easy install and good instructions
Cons: Had to purchase solenoid bracket as separate item
Recommended? Yes
Comments: I have had my M8000 installed for 18 months now and been through many uses of it. Most to help others out and 4 or 5 to help myself up and over obstacles. I have never seen it overheat or wimp out. I do keep the engine running for any extended winching to keep battery and voltage/amps up. For the price, this is a big bang for the bucks. I have never had to test the warranty yet - but others have said it is good to go. The only thing I may do is replace cable with synthetic line.
crash070602
crash070602's Reviews
03-07-2009, 12:01 AM
Warn M-8000
Recommended? Yes
Comments: Just installed it 3/06/09. Install directions could use a little work. Also didn't come with the bracket for the control box. had to buy one locally
DuRubi
DuRubi's Reviews
03-03-2009, 06:51 AM
Warn M-8000
Price: $5.00
Recommended? Yes
Comments: Great Winch, I have made many recoveries on this winch without any problems with it, a couple of them i truely pulled 8000lbs. and it is still pulling strong.
Jumphog
Jumphog's Reviews
01-01-2009, 10:42 AM
Warn M-8000
Price: $546.00
Recommended? Yes
Comments: Not had the occassion to use it yet, but appears to be all I need/want. Hopefully, I will use it only to pull OTHERS out. With Detroits at both ends, it will have to get pretty bad for me to stop moving, but never say never!
JSutterlin
JSutterlin's Reviews
12-25-2008, 07:56 PM
Warn M-8000
Price: $998.00
Recommended? Yes
Comments: I,ve used this winch twice on the same trail in the same day. Figured it paid for its self.
ThreadForumRepliesLast Post
Mile Marker PE 8000 Winches 88 11-02-2013 05:23 PM
Harbor Freight 8000 LB Winch Winches 51 01-15-2013 10:24 PM
Vortex 8000 Winches 5 04-14-2012 05:34 PM
Chicago Electric 8000# Winches 10 09-13-2010 07:16 PM
Warn Warn Works 4700 Winches 1 12-27-2008 11:25 AM
