Warn M-8000
Rating: |
Product Information
| MSRP: |
$998.00 |
| Average Price: |
$544.37 |
| Manufacturer: |
Warn |
| Recommended? |
Nick601's Reviews
Price: $100.00 Pros: pulled me out everytime no problem. Never over heated always worked. Cons: control box above it not water tight. Recommended? Yes
Comments: bought it for 100 bucks off a bud and its bin amazing,
sjones26573's Reviews
Price: $0.01 Pros: Works great! Cons: My decal fell off the control box, but warn sent a replacement. Recommended? Yes
Comments: Great, solid product that lives up to its reputation. It has pulled me out of a hole and pulled an S10 with a dead battery out of a library parking spot so the guy could hill start it. It was a gift
Idwheelthat's Reviews
Price: $565.00 Pros: made in U.S.A, looks good Cons: doesn't come with cover, contactor box is not sealed against elements Recommended? Yes
Comments: haven't got into anything I couldn't get out of yet, but I will go practice winching, so I get the hang of it.
boeingxtreme's Reviews
Price: $489.00 Pros: Looks Awesome Cons: Havent Used it! Recommended? Yes
Comments: Looks great, My whole setup on the front of my TJ is Warn, Bumper, Plate, Grill Gaurd, Winch
OregonVette's Reviews
Price: $350.00 Pros: If you want the real deal get a warn Cons: None Recommended? Yes
Comments: It's a warn. You never hear people saying "well, it's as good as a smittybuilt."
Nope. It's a warn, buy the best.
conair's Reviews
Price: $800.00 Pros: Strong Cons: Just the remote, I wish it was installed in the jeep insted of having to plug it in everytime. Recommended? Yes
Comments: Great winch, it pulled me out of a hole when I was bottomed out and I didn't even press the gas
DuckHunter's Reviews
Price: $550.00 Pros: Quick pull, quiet, American Cons: - Recommended? Yes
Comments: The winch pulls great. I have used it multiple times to save myself from some deep ruts and thick mud during solo wheeling(always around the house). It pulls great and is not loud. I would definitely recommend this winch.
Holdem2's Reviews
Price: $350.00 Pros: compact, durable, strong. Cons: power cables are too short, Solenoid should be weatherproof Recommended? Yes
Comments: Bought new from a guy for less than half price, great find.
blk85cj7's Reviews
Price: $530.00 Pros: Well built, does everything I need it to at a decent price Cons: None Recommended? Yes
Comments: Its a good sturdy winch. Easy to install, use, and it hasn't let me down. Long cord for the controls so you can stay out of the way. What else can I say, it's a Warn.
BPEN65's Reviews
Price: $450.00 Pros: LOOKS GOOD, SELF CONTAINED CONTACTER HOUSING Cons: NONE SO FAR Recommended? Yes
Comments: INSTALLED LAST WINTER- NOT USED IT YET.
cbman's Reviews
Price: $550.00 Pros: Excellent quality Cons: None Recommended? Yes
Comments: It's such a good price, the quality and power it has is amazing.
fduncan's Reviews
Price: $540.00 Pros: came with free remote Cons: none Recommended? Yes
Comments: Very good winch for a very good price and it came with a wireless remote. Can't beat it with a stick!
gmakra's Reviews
Price: $800.00 Pros: Good quality Cons: none Recommended? Yes
Comments: It just does what its supposed to do.
vonhef's Reviews
Price: $540.00 Pros: Fast & Powerful Cons: Price Recommended? Yes
Comments: Build quality seems to be good and the winch is fast and powerful.
Was aware when I purchased that I would need to order the solenoid mounting bracket separately; it should have been included. The mounting bracket is designed to be mounted with only one bolt. The single alen-head bolt that threads into the aluminum rod (that crosses the top of the winch) is what is used to hold this bracket. The problem arises when you tighten the bolt enough to keep the solenoid box from moving when plugging the cable in/out… is… you strip the aluminum threads. I solved the problem by installing GARDSERT threads in both side of the rod and then using grade 8 bolts to tighten. Warn could eliminate the issue by redesigning the mounting bracket to use two bolts, or using a better material in the rod.
I am happy with the product so far.
2ACR
 That's Right I Support |
2ACR's Reviews
Price: $570.00 Pros: Didn't break the bank getting a winch that will last Cons: Control box cables are way too short and warn does not provide any mounting hardware. Recommended? Yes
Comments: What can you say about a warn winch. You get what you pay for but you also pay a little extra for the name. They could do a better job making the control box waterproof and give us the D*** mounting hardware. Most of us know by now that you just use a U-bolt plate. I have they not figured that out.
dahlski6's Reviews
Price: $550.00 Pros: plenty of power, reasonable price Cons: none Recommended? Yes
Comments: Has gotten me out of a lot of jams. Highly recommended.
jeep2008's Reviews
Price: $500.00 Pros: lifetime quarranty Cons: more expensive than others with similar or better qualitys Recommended? Yes
Comments: I haven't really put it into the test yet but it looks ready to take all you'll throw at it.The colour has allredy started to go away in some places though...
jlarsen2's Reviews
Price: $2,000.00 Pros: Works great and reliable Cons: Had to replace several major components under warrenty though Recommended? Yes
Comments: Had to replace several components which were several solinoids, a motor, and a clutch assembly all at different times. it has fulfilled its duty though and doesn't fail when under load pulled everything out that i had thrown at it.
