Warn 9.5 ti Reviews, Ratings, Specs & Prices
Review Categories
Armor
  Bumpers
  Differential Guards
  Rocker Guards
  Roll Cages
  Skid Plates
Audio, CB, & Electrical
  Audio Players
  Batteries
  CB & Ham Radios
  GPS
  Speakers
Axles
  Axle Shafts
  Brakes
  Gears
  Hubs
  Lockers
  Steering
Body
  Body Lifts
  Consoles, Security & Storage
  Exterior Accessories
  Fender Flares
  Lighting, Lenses & Bulbs
  Roof Racks & Cargo Areas
  Tops
Engine
  Alternators
  Carburetors
  Chips
  Exhaust
  Headers
  Induction
  Internal Parts
  Motor Mounts
  Starters
  Throttle Body
Interior
  Gauges
  Misc
  Seats
Recovery
  Winch Cable and Hooks
  Winches
Suspension
  Complete Lift Kits
  Control Arms
  Shocks
  Springs
  Steering Stabilizers
  Track Bars
Tires & Wheels
  Tires
  Wheels
Transfer Case
  SYE Kits
  Transfer Cases
Transmissions
  Transmissions
Previous Product Winches Next Product
Warn 9.5 ti
Rating:
Product Information
MSRP: $921.06
Average Price: $53,398,770,492,737.83
Manufacturer: Warn
Recommended?
Yes: 136 / No: 0
9.5ti THERMOMETRIC SELF-RECOVERY WINCH
The 9.5ti packs 9500 lbs of pulling capacity into a massive 12.5 lb aluminum die-cast body. This winch not only looks great, but sheds the elements like no other winch on the market: seals at the key points give extreme-duty water resistance. A Gen II Series Wound motor delivers just the right balance between torque and speed. Plus another Warn Industries first - operator feedback - the thermometric indicator gives the operator information about motor temperature during the winching operation.
None
Page 2 of 7 1 2 3 4 5 6 7 > Last
glockster
glockster's Reviews
07-26-2010, 10:07 PM
Price: $1,050.00
Pros: It's a WARN
Cons: none
Recommended? Yes
Comments: I wanted a winch that had the solenoid pack integrated into the winch housing. The 9500ti was the winch I chose. 2 wire hook up and your done with it. Looks good and has a nice aluminum frame to protect it all.
jeepngrl
jeepngrl's Reviews
07-04-2010, 09:07 AM
Price: $1,100.00
Pros: Very weather resistant, fast line pulls, dependable.
Cons: Expensive, but you get what you pay for.
Recommended? Yes
Comments: My first winch, the only one I've seen in action. I've used it a few times and it's worked flawlessly every time. Worth every penny.
Bethlynn
Bethlynn's Reviews
06-30-2010, 10:21 PM
Price: $1,200.00
Pros: Unknown
Cons: Unknown
Recommended? Yes
Comments: I just received this winch as a gift from my husband. I haven't had a chance to use it yet!
KendallWC
Junior Member
KendallWC's Reviews
06-08-2010, 10:34 PM
Price: $1,100.00
Pros: Added security for wheeling. Get you out of tight spots. Very strong.
Cons: Can be easily removed. Spot weld recommended for added security against theft.
Recommended? Yes
Comments: I added this winch with a new rock crawler Warn bumper. This was actually easy to install. I took an added step of doing several spot welds to prevent or make it more difficult if someone wanted to steel it. I would recommend this to anyone. Not that I live in a bad area or such but there's always those times you're in an area you're not sure about. Just some helpful advice.
wrangler97
Overbuild
wrangler97's Reviews
06-05-2010, 10:43 PM
Price: $480.00
Pros: Very strong, works with stock battery, looks great
Cons: Steel cable does not spool well and can kink easliy
Recommended? Yes
Comments: It's great to be able to pull myself (or anyone else) our when they're stuck. I pulled a few bushes out for a friend and drug a Ford Explorer sideways over a 8" curb to get him out. Winch works well and smoothly. My only complaint is the steel cable. Bought used and that might be the issue with the cable.
Shiguy
Shiguy's Reviews
05-25-2010, 10:20 AM
Price: $1,500.00
Pros: Powerful, and reliable
Cons: Slow top speed, but at the same time switch is only on off, so when very precise movement is needed can be difficult
Recommended? Yes
Comments: This came with my jeep. Was almost a selling point alone in buying as to buy on my own would have been expensive. Despite the previous owner not using the winch for anything at all it still worked perfectly when i needed it.
Charles
Charles's Reviews
04-04-2010, 01:19 PM
Price: $1,000.00
Pros: This winch installed easily and looks great.
Cons: It's not free.
Recommended? Yes
Comments: I've done four pulls so far and the winch performs well. When you install it you may have to install the fairlead roller after the winch. The tolerances were very close between the fairlead roller and the winch and I had to put the winch on first to make it work.
dendrophobe
dendrophobe's Reviews
12-29-2009, 08:06 PM
Price: $1,100.00
Pros: Great looks, fast, internal solenoid, thermometric monitoring
Cons: Price
Recommended? Yes
Comments: This winch allows for temperature monitoring so that you don't fry your winch during a heavy pull. The internal solenoid gives it a compact appearance, and you don't have any external boxes to damage. Nice and stout, it really seems to do the job well, and look great doing it.
kbrawlz
kbrawlz's Reviews
12-14-2009, 06:05 AM
Price: $900.00
Pros: looks cool. 9500lbs. fast
Cons: expensive
Recommended? Yes
Comments: get it. you get what you pay for. i've had mine for 6 years with not one problem
Jeep-AI
Jeep-AI's Reviews
12-04-2009, 12:50 AM
Price: $1.00
Pros: .
Cons: .
Recommended? Yes
Comments: ....................
unsung
unsung's Reviews
12-02-2009, 05:29 PM
Price: $1.00
Pros: na
Cons: na
Recommended? Yes
Comments: I dont want to do a review but it makes me put something in the box. PM me for full details,
fun
fun's Reviews
11-26-2009, 12:40 PM
Price: $1,100.00
Pros: Well Built
Cons: None
Recommended? Yes
Comments: WARN - what else do I need to say. It's there when you need it.
BFD1012
BFD1012's Reviews
08-21-2009, 04:13 AM
Price: $1,000.00
Pros: Awesome, fast and reliable.
Cons: Could be wireless.
Recommended? Yes
Comments: Never gave me any problems. Works good in the summer and winter.
cjdriver79
cjdriver79's Reviews
08-11-2009, 09:46 PM
Price: $1,200.00
Pros: Over Temp. warning light on handle. High weight capacity. Compact design.
Cons: None yet
Recommended? Yes
Comments: I've used this winch many times and have no complaints yet! It has performed above and beyond expectations in all fields. I not only use it for myself, but even for pulling friends who's winches have failed out! When combined with a pulley I don't think this winch could ever have to "hard" of a pull with my Jeep.
jaredwade81
jaredwade81's Reviews
07-03-2009, 11:49 AM
Price: $950.00
Pros: very dependable, never had any problems
Cons: kinda slow, old wire rope is gettin rusted, needs to be replaced with synthetic.
Recommended? Yes
Comments: Very dependable, would highly recomend this winch. after a few years of use you will need to replace the cable. but thats normal with any winch. hasnt failed me yet.. thinkin about getting another one for the rear.
ElPaso2007
ElPaso2007's Reviews
05-13-2009, 12:31 PM
Price: $1,000.00
Pros: Reliable
Cons: None
Recommended? Yes
Comments: This winch is actually not working and hasn't since I bought the jeep. Will update once I deal with it.
Rob55
Rob55's Reviews
03-23-2009, 11:09 PM
Warn 9.5 ti
Price: $900.00
Recommended? Yes
Comments: Have not had to use the winch yet but it sure is purty! I like the construction of the unit and the fit on my jeep.
msumike1
msumike1's Reviews
03-18-2009, 04:20 PM
Warn 9.5 ti
Price: $900.00
Recommended? Yes
Comments: Love it.... fast, clean looking, great addition to the front of any jeep. love it love it love it
GOTROX
GOTROX's Reviews
03-12-2009, 10:38 PM
Warn 9.5 ti
Price: $1,300.00
Recommended? Yes
Comments: My winch is actually a 9.5 si.
VERY fast, plenty of power, and ultra reliable. I would definitely buy this product again.
AlexGeorgakis
AlexGeorgakis's Reviews
02-26-2009, 08:42 AM
Warn 9.5 ti
Price: $970.71
Recommended? Yes
Comments: Excellent winch! Fast, durable, water resistant, heavy duty. Has never let me down!
ThreadForumRepliesLast Post
Warn XD9000i Winches 66 04-11-2016 09:25 PM
Warn X8000i Winches 32 02-11-2015 08:05 AM
Warn 8k Winch Cable and Hooks 21 10-22-2014 08:32 PM
Warn 9.5xp Winches 8 07-19-2011 06:08 PM
Warn Warn Works 4700 Winches 1 12-27-2008 10:25 AM
