Go Back JeepForum.com > Reviews > Recovery > Winches > Warn 9.0Rc Rock Crawling Winch
DISCOUNT - Chromoly Front Axle Shaft Kits, 87-95 YJ's, 97-GR8TOPS Introduces the Exogate HD Tire CarrierTruck-Lite's New LED Headlamp Series
Warn 9.0Rc Rock Crawling Winch Reviews, Ratings, Specs & Prices
Review Categories
Armor
  Bumpers
  Differential Guards
  Rocker Guards
  Roll Cages
  Skid Plates
Audio, CB, & Electrical
  Audio Players
  Batteries
  CB & HAM Radios
  GPS
  Speakers
Axles
  Axle Shafts
  Brakes
  Gears
  Hubs
  Lockers
  Steering
Body
  Body Lifts
  Consoles, Security & Storage
  Exterior Accessories
  Fender Flares
  Lighting, Lenses & Bulbs
  Roof Racks & Cargo Areas
  Tops
Engine
  Alternators
  Carburetors
  Chips
  Exhaust
  Headers
  Induction
  Internal Parts
  Motor Mounts
  Starters
  Throttle Body
Interior
  Gauges
  Misc
  Seats
Recovery
  Winch Cable and Hooks
  Winches
Suspension
  Complete Lift Kits
  Control Arms
  Shocks
  Springs
  Steering Stabilizers
  Track Bars
Tires & Wheels
  Tires
  Wheels
Transfer Case
  SYE Kits
  Transfer Cases
Transmissions
  Transmissions
Previous Product Winches Next Product
Rating:
Product Information
MSRP: $1,200.00
Average Price: $779.33
Manufacturer: Warn
Recommended?
Yes: 12 / No: 0
Like its professional counterpart, the 9.0R, the 9.0Rc is a short-drum, 9,000 lb. capacity winch that features a 4.8 hp Series Wound Motor for fast line speeds. An exclusive, multi-segment Cam Actuated Brake gives positive operator control during winching.
The 9.0Rc comes standard with 50' of 3/8" diameter synthetic rope. Other features include: a chromate undercoating and gloss red paint that provide superior corrosion resistance; a rugged, 360-degree swivel hook and thimble; an aluminum hawse fairlead; extreme duty winch sealing; and a "Ballistic Nylon" Sliding Sleeve that provides extra protection against abrasion and wear.
The 9.0Rc - a winch built for rock crawlers looking for efficiency, reliability and the legendary WARN performance.
9.0Rc SPECS/PART NUMBER
Part Number: 71550
Rated Line Pull: 9000 lbs. (4080 kgs.) single-line
Motor: Series Wound, 12V 4.8 hp
Remote Control: Remote switch, 12' (3.7m) lead
Geartrain: 3-Stage Planetary
Gear Ratio: 216:1
Lubrication: Aeroshell #17
Clutch (freespooling): Sliding Ring Gear
Brake: Automatic Direct Drive Cone
Drum Diameter/Length: 2.75"/4.75" (7.0cm/12cm)
Weight: 54 lbs. (24.8 kgs)
Rope: 50', 3/8" Synthetic Rope
Fairlead: Polished Aluminum Hawse
Recommended Battery: 650 CCA minimum for winching
Battery Leads: 2 gauge, 72" (1.83m)
Finish: Chromate with high-gloss red paint
Nuts/Bolts: PN 39625
PERFORMANCE SPECIFICATIONS
Line Pull
Lbs.(Kgs.) Line Speed
FT./min(M/min.) Motor
Current Pull by layer
layer/Lbs(Kgs.)
0 42 (12.8) 80 amps 1/900 (4082)
2000 16 (4.88) 200 amps 2/7280 (3302)
4000 11.9 (3.63) 285 amps 3/6670 (3026)
6000 9.79 (2.98) 350 amps 4/6230 (2826)
8000 8.01 (2.44) 435 amps
9000 6.4 (1.94) 465 amps
**NOTE: This winch requires a 6"x4.5" mounting pattern.
89wangler
89wangler's Reviews
12-01-2010, 12:32 AM
Price: $350.00
Pros: awesome power super fast dependable and its rebuild able for very little expense.
Cons: gotta do a dual battery setup if your gonna do any kinda major winching as well as a alternator upgrade and a little rewiring of important battery connections
Recommended? Yes
Comments: After i installed this on a plate i mounted it to a tractor and dead pulled 9k worth of cement block on a sled with no problem it almost stalled when it caught a corner but then it stared to drag the cat it was mounted on around . I just ordered a Smittybilt xrc bumper to go with it i will review the combo as well as mounting ease of both when i receive it .
MoCab
MoCab's Reviews
12-07-2009, 05:17 PM
Price: $1.00
Pros: was on vehicle when purchased. very powerful and light in weight. Fast Line speed.
Cons: line is only 50' more like 45-47' effective. use if extension required often.
Recommended? Yes
Comments: Not much to say it was on the Jeep when I bought it.
rollercam351
rollercam351's Reviews
11-16-2009, 03:44 PM
Price: $1,500.00
Pros: Red, instead of black, small, perfect capacity, better duty cycle than others
Cons: EXPENSIVE
Recommended? Yes
Comments: Best winch for jeeps that constantly use them
JPTJTrav
JPTJTrav's Reviews
10-14-2009, 08:43 AM
Price: $850.00
Pros: very fast pull
Cons: short cable, bring an extension with you
Recommended? Yes
Comments: used this winch multiple times and it is very fast and quite strong. I highly recommend it for the weight and speed of pull.
bnine
bnine's Reviews
03-18-2009, 12:10 PM
Price: $1,050.00
Recommended? Yes
Comments: Great weight wise, a tad slow. The line, hook, and insolator all good quality.
wizwoz
Mountain Jeeper
wizwoz's Reviews
01-18-2009, 01:13 PM
Price: $1,200.00
Recommended? Yes
Comments: No real rating yet but I got this winch because I wanted to stay lightweight and use synthetic rope. I carry an extra 50 foot cable and 20 foot strap in case the 50 feet winch cable is too short, but expect that this winch will be easier to use because I can pull out all the cable quickly and use the first few turns to get max power.
luskie
luskie's Reviews
11-19-2008, 04:01 PM
Price: $1,100.00
Recommended? Yes
Comments: works well no cable frays,
rope not long enough would like 100' just use an extension
badasscrawlers
badasscrawlers's Reviews
03-26-2008, 08:29 AM
Price: $500.00
Recommended? Yes
Comments: got it on a trade
flyerboy1522
flyerboy1522's Reviews
03-16-2008, 08:47 PM
Price: $850.00
Recommended? Yes
Comments: very nice winch I have never used it on the trail but just playing around with it, it seems to be very good and fast too!!!
Steve and Will
Dad and Son
Steve and Will's Reviews
02-25-2008, 08:52 AM
Price: $950.00
Recommended? Yes
Comments: looks good also
Newbie
's Reviews
02-05-2008, 09:55 AM
Price: $2.00
Recommended? Yes
Comments: asdf
ChristopherJ
ChristopherJ's Reviews
08-08-2006, 10:00 AM
Price: $999.00
Pros: fast line pull, strong, light weight, looks cool
Cons: only holds 50ft of line
Recommended? Yes
Comments: This product was initially sold as a professional rock crawling winch, only for those with sponsors in competing in large events. Once made available at a good price to the public by Biff @ offroadoverstock.com I had to take advantage. With price being equal between the RC and Warn's thermometric winch, I had to look at the features and decide which was better. The biggest deciding factor for me was the weight difference. The RC was half the weight of the other, perhaps largely due to the synthetic line which comes with the RC. I had zero spring sag from this winch which weighs in at 45 lbs. The only negative is that it holds only 50ft of line. I plan to get an extension line to keep in the jeep, just in case.
ThreadForumRepliesLast Post
Warn 9.5 ti Winches 110 07-27-2011 09:41 AM
Warn XD9000i Winches 56 11-19-2010 08:33 AM
Warn 9.5xp Winches 5 06-28-2010 07:21 AM
Warn 8k Winch Cable and Hooks 11 11-18-2009 10:32 AM
Warn Warn Works 4700 Winches 1 12-27-2008 11:25 AM
Glock Forum
