SmittyBilt XRC 8 Winch Reviews, Ratings, Specs & Prices
Review Categories
Armor
  Bumpers
  Differential Guards
  Rocker Guards
  Roll Cages
  Skid Plates
Audio, CB, & Electrical
  Audio Players
  Batteries
  CB & Ham Radios
  GPS
  Speakers
Axles
  Axle Shafts
  Brakes
  Gears
  Hubs
  Lockers
  Steering
Body
  Body Lifts
  Consoles, Security & Storage
  Exterior Accessories
  Fender Flares
  Lighting, Lenses & Bulbs
  Roof Racks & Cargo Areas
  Tops
Engine
  Alternators
  Carburetors
  Chips
  Exhaust
  Headers
  Induction
  Internal Parts
  Motor Mounts
  Starters
  Throttle Body
Interior
  Gauges
  Misc
  Seats
Recovery
  Winch Cable and Hooks
  Winches
Suspension
  Complete Lift Kits
  Control Arms
  Shocks
  Springs
  Steering Stabilizers
  Track Bars
Tires & Wheels
  Tires
  Wheels
Transfer Case
  SYE Kits
  Transfer Cases
Transmissions
  Transmissions
Previous Product Winches Next Product
Rating:
Product Information
MSRP: $900.00
Average Price: $305.47
Manufacturer: SmittyBilt
Recommended?
Yes: 279 / No: 9
Direct from 4wd.com:
The NEW Smittybilt XRC8 8,000lb winch has a hand wound permanent magnetic motor which is the standard for the true off Roader. This is the most reliable motor on the market today. Two Year Limited Warranty, 4.1 hp motor, 3-stage planetary gear system, 265:1 reduction ratio for fast line speed, free spooling, automatic load-holding brake, power in and out and a roller fairlead. A 12 ft illuminated handheld remote control,. Comes with a 5/16" x 92 galvanized aircraft cable with replaceable hook. Mounting bolt pattern: 10" x 4.5", OAL Dim. 21" x 6.22" x 7.283". This item incurs a $19.99 shipping surcharge.
-Rated line pull: 8,000 lbs. (3629 kg) single line
-Gear train: planetary gear system
-Gear ratio: 265:1
-Motor (permanent magnet): 4.1 hp (3kw), 12volt
None
Page 9 of 15 < 3 4 5 6 7 8 9 10 11 12 13 14 15 > Last
82Renegade
82Renegade's Reviews
03-23-2009, 08:56 PM
Price: $300.00
Recommended? Yes
Comments: Only used once- so far, so good. Certainly not highest quality, but should be fine for the few times a year I'll need it. Good value if it holds up.
xXArcticWolfXx
xXArcticWolfXx's Reviews
03-22-2009, 10:09 PM
Price: $300.00
Recommended? Yes
Comments: I've only had to use the winch once since I just put it on yesterday, but it worked amazing and I'm very pleased so far!
Irockatgms
Irockatgms's Reviews
03-21-2009, 11:41 PM
Price: $350.00
Recommended? Yes
Comments: Winch has more then paid for itself... Very good winch, assuming its a canned rotor => no water damage incurred during underwater use
Libtekguy
Libtekguy's Reviews
03-21-2009, 05:19 PM
Price: $299.99
Recommended? Yes
Comments: Bad *** little sucker. Installs just as easy as any other winch. Haven't had to use it yet, only "tested" it on my street.
Chris
Guy with jeep
Chris's Reviews
03-19-2009, 12:55 PM
Price: $269.00
Recommended? Yes
Comments: Picked it up and it was complete in the box with no missing parts so thats a plus. Easy to install. I have only used it twice as of 3/19/09 and worked great both times.
akonius
akonius's Reviews
03-18-2009, 11:48 AM
Price: $293.00
Recommended? Yes
Comments: I like it - its affordable and gets the job done. I also like that its finished in black - matches jeep well
russ03tjsport
russ03tjsport's Reviews
03-17-2009, 08:59 PM
Price: $395.00
Recommended? Yes
Comments: winch was easy to hook up good line speed the only problem I have is they printed the sticker backwards in other words I have to put it in free spool mode in order to have it engaged
DaculaJeep
DaculaJeep's Reviews
03-05-2009, 01:33 PM
Price: $299.99
Recommended? Yes
Comments: Purchased from winchdepot.com. I haven't installed it yet, will do so this weekend.
vilseck21
vilseck21's Reviews
03-04-2009, 09:03 AM
Price: $250.00
Recommended? Yes
Comments: Great winch for the money, 3 times chearper than a warn, but not 3 times worse
PAFirefighter11
Quadratec Live Chat Rep
PAFirefighter11's Reviews
02-28-2009, 08:51 PM
Recommended? Yes
Comments: I haven't yet used this in a recovery situation. I cannot recommend it as of it.
rookcherokee
rookcherokee's Reviews
02-27-2009, 12:49 PM
Price: $250.00
Recommended? Yes
Comments: Amazing product. Works VERY well and haven't had any problems with it at all.
2009_89yj
2009_89yj's Reviews
02-26-2009, 12:03 AM
Recommended? Yes
Comments: So far so good.............................................. ..................
urstolendesire
urstolendesire's Reviews
02-25-2009, 10:08 PM
Price: $299.99
Recommended? Yes
Comments: Works great. pull speed is a little slow but still does incredible for the price.
wilywillie
wilywillie's Reviews
02-22-2009, 12:57 AM
Price: $300.00
Recommended? Yes
Comments: The price was right for a winch I won't be using on a regular basis! It was cheaper than to have the tow company get me out of the mud! We'll see how well she holds up once the ground thaws.
97TJ_Jmarsh
97TJ_Jmarsh's Reviews
02-20-2009, 08:31 AM
Price: $252.00
Recommended? Yes
Comments: haven't had a chance to use it yet on the trail but looks great out of the box, and the install was very straight forward.
NBFarmboy
NBFarmboy's Reviews
02-19-2009, 09:20 AM
Price: $250.00
Recommended? Yes
Comments: Very Nice Winch, Great Price Off of 4wd.com, came with everything except a mounting plate which is normal, hooked up easy pulls like a beast
yellingrebel78
yellingrebel78's Reviews
02-13-2009, 11:48 PM
Price: $299.00
Recommended? Yes
Comments: cheap and affordable Maybe it will help me out when the time comes I also read some good reviews on it
jbach
jbach's Reviews
02-12-2009, 04:20 PM
Price: $269.00
Recommended? Yes
Comments: It hasen't let me down yet. Has quite a few tough pulls and shows no signs of weakness.
papasmurf89
papasmurf89's Reviews
02-08-2009, 05:42 PM
Price: $299.95
Recommended? Yes
Comments: the winch is still new i have yet to actually use it. otherwise the general apperance of it it good
tufrthnails
tufrthnails's Reviews
02-02-2009, 06:29 PM
Price: $329.00
Recommended? Yes
Comments: Great all around winch for the price!! Although I havn't used it for any long pulls, it is a great add-on for peace of mind
ThreadForumRepliesLast Post
Smittybilt XRC10 Winch Winches 66 06-30-2016 06:51 AM
Smittybilt XRC8 Winches 70 06-30-2016 06:46 AM
Smittybilt XRC8 Winches 69 02-15-2016 02:08 PM
Smittybilt XRC10HD Winches 4 02-10-2016 01:20 AM
Bulldog Winch 12k Winches 1 04-12-2008 11:39 AM
