SmittyBilt XRC 8 Winch Reviews, Ratings, Specs & Prices
Review Categories
Armor
  Bumpers
  Differential Guards
  Rocker Guards
  Roll Cages
  Skid Plates
Audio, CB, & Electrical
  Audio Players
  Batteries
  CB & Ham Radios
  GPS
  Speakers
Axles
  Axle Shafts
  Brakes
  Gears
  Hubs
  Lockers
  Steering
Body
  Body Lifts
  Consoles, Security & Storage
  Exterior Accessories
  Fender Flares
  Lighting, Lenses & Bulbs
  Roof Racks & Cargo Areas
  Tops
Engine
  Alternators
  Carburetors
  Chips
  Exhaust
  Headers
  Induction
  Internal Parts
  Motor Mounts
  Starters
  Throttle Body
Interior
  Gauges
  Misc
  Seats
Recovery
  Winch Cable and Hooks
  Winches
Suspension
  Complete Lift Kits
  Control Arms
  Shocks
  Springs
  Steering Stabilizers
  Track Bars
Tires & Wheels
  Tires
  Wheels
Transfer Case
  SYE Kits
  Transfer Cases
Transmissions
  Transmissions
Previous Product Winches Next Product
Rating:
Product Information
MSRP: $900.00
Average Price: $305.47
Manufacturer: SmittyBilt
Recommended?
Yes: 279 / No: 9
Direct from 4wd.com:
The NEW Smittybilt XRC8 8,000lb winch has a hand wound permanent magnetic motor which is the standard for the true off Roader. This is the most reliable motor on the market today. Two Year Limited Warranty, 4.1 hp motor, 3-stage planetary gear system, 265:1 reduction ratio for fast line speed, free spooling, automatic load-holding brake, power in and out and a roller fairlead. A 12 ft illuminated handheld remote control,. Comes with a 5/16" x 92 galvanized aircraft cable with replaceable hook. Mounting bolt pattern: 10" x 4.5", OAL Dim. 21" x 6.22" x 7.283". This item incurs a $19.99 shipping surcharge.
-Rated line pull: 8,000 lbs. (3629 kg) single line
-Gear train: planetary gear system
-Gear ratio: 265:1
-Motor (permanent magnet): 4.1 hp (3kw), 12volt
None
Page 8 of 15 < 2 3 4 5 6 7 8 9 10 11 12 13 14 > Last
bobdog
bobdog's Reviews
09-21-2009, 10:45 AM
Price: $299.00
Pros: Good price; Stout build
Cons: none yet
Recommended? Yes
Comments: Good deal
IdahoTJ
IdahoTJ's Reviews
09-17-2009, 04:02 PM
Price: $329.00
Pros: Inexpensive, easily installed, simple to use, if I need it I have it
Cons: No so far
Recommended? Yes
Comments: No problems so far, had it less than a month, haven't pulled anything except the Jeep in the driveway to reload the winch.
ModernJ
ModernJ's Reviews
09-10-2009, 03:48 PM
Price: $299.00
Pros: Nice fit with the stock bumper and mounting plate.Works good nice price
Cons: None
Recommended? Yes
Comments: Its best to install the unit wiring first. Put the switch box on it. Then attach winch to plate prior to mounting on Jeep. Last run the wires to your Battery. Its a custom fit everything lines up.
LandoCommando
LandoCommando's Reviews
09-09-2009, 12:41 PM
Price: $299.00
Pros: Works. Works well. Gets the job done. The job done it gets. Reliable. Quality for its price.
Cons: Its not a warn, don't expect it to be.
Recommended? Yes
Comments: Itll get you unstuck
TeamFATBOY
TeamFATBOY's Reviews
08-16-2009, 10:45 PM
Price: $320.00
Pros: Price and Function
Cons: None so far
Recommended? Yes
Comments: Have had three warns with no problems with them on other vehicles and they worked great for pulling others out of trouble but never used them enough for myself to justify spending that much on a winch I may use three times a year on myself. Havn't had any problems with the Smittybilt
Adamlee78
Adamlee78's Reviews
07-31-2009, 04:26 PM
Price: $275.00
Pros: great. has pulled my Tj out several times and others too!
Cons: ? none yet
Recommended? Yes
Comments: I installed on the smittybilt XRC front bumper on my TJ and it works great. Smittybilt sent me a new controller box for free to accomodate for the winch bar being in front of the remote socket. And i did not need to return the other. Will work even better if i ever need a part!
mav383
mav383's Reviews
05-28-2009, 04:22 PM
Price: $300.00
Pros: gets the job done, go where few have gone before
Cons: some not as well developed features
Recommended? Yes
Comments: A friend has one and well I thought I'd reveiw it because it is 9 times out of 10 yanking my WJ out of stuff way too deep/steep. been in multiple situations pulling at odd angles and has performed remarkably. Just a few qirks like the free spool leaver getting gunked up and becoming immoble or loose and the control recepticle cover falling apart. but other than that absolutely worth the money he paid and money I've saved!
John O
John O's Reviews
05-27-2009, 11:16 AM
Price: $299.00
Pros: Inexpensive, complete and ready for installation and use, good instructions. Decent line speed.
Cons: Haven't found one yet.
Recommended? Yes
Comments: Purchased from the Winch Depot (good customer service) for $299 and free shipping. Came complete and ready to install. Clear easy to follow instructions. The day I installed it I pulled out a TJ that was framed in sugar sand...the winch free spooled easy and pulled out the TJ w/o a hesitation. Great inexpensive winch!
itsa67
itsa67's Reviews
05-25-2009, 10:06 PM
Price: $299.00
Pros: Great price Works great so far Plenty of pulling power
Cons: The remote is kinda chinsey Not made in the US
Recommended? No
Comments: I got this winch for 299 shipped with a winch plate, i have the 2nd generation. The whole thing bolted up in less than a half hour. Have had it on for almost a year, and have used it about 5 times. Its worked great every time without any problems. The engangement lever got stuck shut once, but some wd40 losened it real quick. Overall a nice winch for the money, i dont see how you could go wrong.
wilywillie
wilywillie's Reviews
05-15-2009, 11:32 PM
Price: $260.00
Pros: price
Cons: Chinese made
Recommended? Yes
Comments: great price--more than paid for itself after using twice. Works great, too, I just don't want to have to rely on it (or ANY winch) when I'm really up the creek!
NorcalYJ92
NorcalYJ92's Reviews
05-12-2009, 04:03 AM
Price: $300.00
Pros: Awesome
Cons: NONE
Recommended? Yes
Comments: Awesome
Feetwet
Enjoying the Ride
Feetwet's Reviews
04-08-2009, 08:19 AM
Price: $299.00
Pros: Low price, easy install, stainless housing hardware
Cons: None
Recommended? Yes
Comments: Works like a Big Dog. Strong and stable. Decent line speed with 5/16 wire rope. Long cable on controller. Solid fairlead. Has series wound not perm mag motor. These motors are standard now.
the_weirdo
the_weirdo's Reviews
04-06-2009, 11:32 PM
Price: $260.00
Recommended? Yes
Comments: I have winched with the XRC8 about a dozen times and it has impressed me each time. I would not hesitate to buy it again.
SCHRISCO
SCHRISCO's Reviews
04-01-2009, 03:23 AM
Price: $200.00
Recommended? Yes
Comments: great!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!!!!!!!!!!!!
ayeohellucks
ayeohellucks's Reviews
03-30-2009, 11:31 AM
Price: $299.00
Recommended? Yes
Comments: Haven't needed to use it for real yet, but its nice to have peace of mind. great price
rock-rocker
rock-rocker's Reviews
03-26-2009, 10:38 PM
Price: $299.99
Recommended? Yes
Comments: Haven't had a chance to use it yet. I only installed it just in case I have to help someone else get un-stuck (right)
bsouth
bsouth's Reviews
03-26-2009, 06:58 PM
Price: $300.00
Recommended? Yes
Comments: old permanent wound crapped out but 4wd was great and sent me the new style with the series wound motor 100x better
jeephildo
jeephildo's Reviews
03-25-2009, 09:54 PM
Price: $299.00
Recommended? Yes
Comments: Great winch for the price for a poor person like me. Def. recommend to others.
chucklesk
chucklesk's Reviews
03-24-2009, 05:51 PM
Price: $270.00
Recommended? Yes
Comments: I got an awesome deal on this from 4wd.com it was $299 on sale with free shipping and a winch plate, plus I had a 10% off coupon. It has pulled me out out of the snow twice. I also used it pull my sisters Subaru out of the driveway after she got plowed in this winter. Its probably the best 300 I have spent so far.
rip_1986
rip_1986's Reviews
03-24-2009, 03:27 PM
Price: $299.99
Recommended? Yes
Comments: nice winch for the price, rough sounding at first, but after it is used a couple times it starts so sound smother
ThreadForumRepliesLast Post
Smittybilt XRC10 Winch Winches 66 06-30-2016 06:51 AM
Smittybilt XRC8 Winches 70 06-30-2016 06:46 AM
Smittybilt XRC8 Winches 69 02-15-2016 02:08 PM
Smittybilt XRC10HD Winches 4 02-10-2016 01:20 AM
Bulldog Winch 12k Winches 1 04-12-2008 11:39 AM
