Notices
SmittyBilt XRC 8 Winch Reviews, Ratings, Specs & Prices
Review Categories
Armor
  Bumpers
  Differential Guards
  Rocker Guards
  Roll Cages
  Skid Plates
Audio, CB, & Electrical
  Audio Players
  Batteries
  CB & Ham Radios
  GPS
  Speakers
Axles
  Axle Shafts
  Brakes
  Gears
  Hubs
  Lockers
  Steering
Body
  Body Lifts
  Consoles, Security & Storage
  Exterior Accessories
  Fender Flares
  Lighting, Lenses & Bulbs
  Roof Racks & Cargo Areas
  Tops
Engine
  Alternators
  Carburetors
  Chips
  Exhaust
  Headers
  Induction
  Internal Parts
  Motor Mounts
  Starters
  Throttle Body
Interior
  Gauges
  Misc
  Seats
Recovery
  Winch Cable and Hooks
  Winches
Suspension
  Complete Lift Kits
  Control Arms
  Shocks
  Springs
  Steering Stabilizers
  Track Bars
Tires & Wheels
  Tires
  Wheels
Transfer Case
  SYE Kits
  Transfer Cases
Transmissions
  Transmissions
Previous Product Winches Next Product
Rating:
Product Information
MSRP: $900.00
Average Price: $305.47
Manufacturer: SmittyBilt
Recommended?
Yes: 279 / No: 9
Direct from 4wd.com:
The NEW Smittybilt XRC8 8,000lb winch has a hand wound permanent magnetic motor which is the standard for the true off Roader. This is the most reliable motor on the market today. Two Year Limited Warranty, 4.1 hp motor, 3-stage planetary gear system, 265:1 reduction ratio for fast line speed, free spooling, automatic load-holding brake, power in and out and a roller fairlead. A 12 ft illuminated handheld remote control,. Comes with a 5/16" x 92 galvanized aircraft cable with replaceable hook. Mounting bolt pattern: 10" x 4.5", OAL Dim. 21" x 6.22" x 7.283". This item incurs a $19.99 shipping surcharge.
-Rated line pull: 8,000 lbs. (3629 kg) single line
-Gear train: planetary gear system
-Gear ratio: 265:1
-Motor (permanent magnet): 4.1 hp (3kw), 12volt
None
Page 7 of 15 < 1 2 3 4 5 6 7 8 9 10 11 12 13 > Last
ericson89
ericson89's Reviews
03-16-2010, 11:44 AM
Price: $299.00
Pros: cheap and effective
Cons: cheap
Recommended? No
Comments: It gets the job done for simple stucks. If I had the money I would have bought a better winch in the warn, ramsey, superwinch area. All in all it hasn't failed yet but haven't maxed it out either.
dlane2155
dlane2155's Reviews
03-14-2010, 06:46 PM
Price: $299.00
Pros: -Plenty of winching capacity. -More HP than some of the other winches for the same price and capacity. -Easy to wire in.
Cons: For mounting the electronic box above the motor, one of the mounting holes was cross threaded. Not a major issue, just tapped the hole quickly. Also if you mount it above the motor, it could get pulled up and bend the bracket. Easy fix though, I just took a large hose clamp and wrapped it around the motor, and the bottom mounting bracket of the electronic box.
Recommended? Yes
Comments: -More HP than some of the other winches for the same price and capacity.
-Easy to wire in.
NorthWhiteWolf
NorthWhiteWolf's Reviews
03-14-2010, 02:52 PM
Price: $300.00
Pros: comeing
Cons: comeing
Recommended? Yes
Comments: will be installing soon.
havoc64
havoc64's Reviews
03-14-2010, 08:25 AM
Price: $499.00
Pros: Easy Install, great instructions, synthetic rope.
Cons: Tight Clutch Brake, very hard to pull out when clutch is disengaged. Solenoid wont mount over motor when installed on XRC front bumper
Recommended? Yes
Comments: Easy Install, great instructions, synthetic rope. Tight Clutch Brake, very hard to pull out when clutch is disengaged. Solenoid wont mount over motor when installed on XRC front bumper
will_982
will_982's Reviews
03-11-2010, 09:03 PM
Price: $299.00
Pros: The price is right and the service from them is great.
Cons: The closed relay pack is the only downfall.
Recommended? Yes
Comments: The price and company backing is great (thanks Ray at smitty). In general by far best winch for the money for the weekend wheeler.
patrick18
patrick18's Reviews
03-11-2010, 10:35 AM
Price: $299.00
Pros: Solid construction.
Cons: Selector lever had to be replaced out of the box. Slow free-spool.
Recommended? Yes
Comments: Haven't really got a chance to put it to the test yet. Seems to be a quality piece of equipment for the price. Less than half of a Warn. Freespool is a little slow right now however that might change once it gets some usage out of it. Customer service is excellent.
patrick18
patrick18's Reviews
03-11-2010, 10:32 AM
Price: $299.00
Cons: Selector lever had to be replaced. Slow freespool
Recommended? Yes
Comments: Haven't really got a chance to put it to the test yet, however it seems be a quality piece of equipment for the price. Customer service is great!
willsyj
willsyj's Reviews
02-21-2010, 09:56 PM
Price: $300.00
Pros: good price well built hasnt faild me yet
Cons: none
Recommended? Yes
Comments: great whinch for the price no problem
famousstar1026
famousstar1026's Reviews
02-09-2010, 08:31 PM
Price: $300.00
Pros: strong as hell
Cons: slowish
Recommended? Yes
Comments: easy install
Roadrunner2
Roadrunner2's Reviews
01-21-2010, 09:56 PM
Price: $280.00
Pros: Strong, good value
Cons: hard to free spool when new
Recommended? Yes
Comments: The winch is actually a Rugged Ridge 8500lb. I believe its the same as a Smithbuilt. I pulled my friends TJ up a steep hill. It was high centered causing it to drag. Used a snatch block which helped. My TJ was lifted off the ground. I have used it three time and its getting easier to free spool. Looks like it going to be a good winch.
02APEX
02APEX's Reviews
01-06-2010, 02:06 PM
Price: $300.00
Pros: don't know, haven't used it yet
Cons: hard as hell to install
Recommended? Yes
Comments: Since I already had the new Smitty src stinger bumper thought I would go with the xrc8 and xrc winch plate, should all bolt together quite nicely right? Not the case, had do cut plate to fit in between stinger, then had to remove bumper to install plate/winch. Total nightmare. In the end Lokks badass.
ROADDOG516
ROADDOG516's Reviews
01-05-2010, 09:45 PM
Price: $399.00
Pros: great price
Cons: none yet
Recommended? Yes
Comments: just got it not installed but seems great for price.
AFjeepMan
AFjeepMan's Reviews
01-01-2010, 01:58 PM
Price: $284.00
Pros: inexpensive price, looks good
Cons: wire rope instead of synthetic
Recommended? Yes
Comments: looks good, and simple install
mwmoon
mwmoon's Reviews
12-29-2009, 12:02 PM
Price: $269.00
Pros: affordable, reliable
Cons: paint on Smittybilt sticker faded on the solenoid -- who cares?
Recommended? Yes
Comments: This winch gets beat up on the forum all the time from the Warn crowd who swears anything not "made right here in the USA" is going to fall apart on the trail.
I've had this winch for about a year, and it hasn't fallen apart yet. It hasn't failed once. It does the job just as well as any other winch I've seen, and it came with a lifetime warranty. What more can I ask for?
Aarea
Aarea's Reviews
12-27-2009, 07:53 PM
Price: $350.00
Pros: More than enough power. Doesn't drain power too hard. No issues with it yet.
Cons: None
Recommended? Yes
Comments: Got her mounted on a rough country winch mount mounted to the stock bumber of an '01 TJ. The winch has served me great so far. The winch has dragged a 24' speed boat out of a deep brush filled ditch, has dragged a 60' downed aspen up a wooded hill, drug a minivan off a huge snow mound (no idea how she got it up there), oh and was used by the jeep twice to get unstuck. Great winch.
Red_Rubicon
Red_Rubicon's Reviews
12-12-2009, 03:50 PM
Price: $300.00
Pros: small
Cons: Won't work with smitty built bumpers with winch guard/bar.
Recommended? Yes
Comments: Had to make a bracket to offset the control box to work with the XRC rock bumper. Would not work in either location.
jeepzap
jeepzap's Reviews
12-09-2009, 06:34 PM
Price: $300.00
Pros: na
Cons: na
Recommended? Yes
Comments: havent used it yet but it seems like the real deal
lancer27
lancer27's Reviews
12-08-2009, 08:37 PM
Price: $300.00
Pros: great price and works amazing!!!
Cons: free spool is hard to pull out
Recommended? Yes
Comments: i have already used this thing around 4 times. i put my self into holes that i shouldnt have been in! and it pulled me right out. i have also pulled myself up hill climbs i couldnt get up with the jeep alone. but i love this thing.
mdori
mdori's Reviews
11-27-2009, 08:22 PM
Price: $300.00
Pros: Inexpensive, Works as a winch should
Cons: none yet
Recommended? Yes
Comments: I have not had this winch for a very long time but have used it in a few recoveries and it has worked great. Maybe its just me but the cable seems to get kinks easier than other winch cables I have used with other Jeeps. Otherwise it was easy to install, works great and is a great value for the money!
hunter4it
hunter4it's Reviews
10-11-2009, 04:15 PM
Price: $299.00
Pros: cheep
Cons: not a one
Recommended? Yes
Comments: looks good works good cheep like the looks i think it will work good for what i will be doing
ThreadForumRepliesLast Post
Smittybilt XRC10 Winch Winches 66 06-30-2016 06:51 AM
Smittybilt XRC8 Winches 70 06-30-2016 06:46 AM
Smittybilt XRC8 Winches 69 02-15-2016 02:08 PM
Smittybilt XRC10HD Winches 4 02-10-2016 01:20 AM
Bulldog Winch 12k Winches 1 04-12-2008 11:39 AM
