Notices
SmittyBilt XRC 8 Winch Reviews, Ratings, Specs & Prices
Review Categories
Armor
  Bumpers
  Differential Guards
  Rocker Guards
  Roll Cages
  Skid Plates
Audio, CB, & Electrical
  Audio Players
  Batteries
  CB & Ham Radios
  GPS
  Speakers
Axles
  Axle Shafts
  Brakes
  Gears
  Hubs
  Lockers
  Steering
Body
  Body Lifts
  Consoles, Security & Storage
  Exterior Accessories
  Fender Flares
  Lighting, Lenses & Bulbs
  Roof Racks & Cargo Areas
  Tops
Engine
  Alternators
  Carburetors
  Chips
  Exhaust
  Headers
  Induction
  Internal Parts
  Motor Mounts
  Starters
  Throttle Body
Interior
  Gauges
  Misc
  Seats
Recovery
  Winch Cable and Hooks
  Winches
Suspension
  Complete Lift Kits
  Control Arms
  Shocks
  Springs
  Steering Stabilizers
  Track Bars
Tires & Wheels
  Tires
  Wheels
Transfer Case
  SYE Kits
  Transfer Cases
Transmissions
  Transmissions
Previous Product Winches Next Product
Rating:
Product Information
MSRP: $900.00
Average Price: $305.47
Manufacturer: SmittyBilt
Recommended?
Yes: 279 / No: 9
Direct from 4wd.com:
The NEW Smittybilt XRC8 8,000lb winch has a hand wound permanent magnetic motor which is the standard for the true off Roader. This is the most reliable motor on the market today. Two Year Limited Warranty, 4.1 hp motor, 3-stage planetary gear system, 265:1 reduction ratio for fast line speed, free spooling, automatic load-holding brake, power in and out and a roller fairlead. A 12 ft illuminated handheld remote control,. Comes with a 5/16" x 92 galvanized aircraft cable with replaceable hook. Mounting bolt pattern: 10" x 4.5", OAL Dim. 21" x 6.22" x 7.283". This item incurs a $19.99 shipping surcharge.
-Rated line pull: 8,000 lbs. (3629 kg) single line
-Gear train: planetary gear system
-Gear ratio: 265:1
-Motor (permanent magnet): 4.1 hp (3kw), 12volt
None
Page 3 of 15 1 2 3 4 5 6 7 8 9 10 11 12 13 > Last
JEEPSRK
JEEPSRK's Reviews
05-26-2012, 01:54 PM
Price: $449.99
Pros: strong, easy to use
Cons: not water proof
Recommended? Yes
Comments: I love this winch its strong, durable and any one can use it (even your wife LOL) but it is water RESISTANT so if I get stuck and it is under water I'm in trouble.
Tom95YJ
[] Eye'd Jeep Connoisseur
Tom95YJ's Reviews
05-17-2012, 02:16 PM
Price: $412.00
Pros: Price, Synthetic Rope
Cons: It's not a Warn
Recommended? Yes
Comments: I bought this over a warn vr8000 due to the price being the same and it came with a synthetic rope which is safer and would have ran me $200 more if I had went with the Warn VR8000. It it slow but I'm not into comps so I dont need insane line speed .
Bud2011JK
Bud2011JK's Reviews
05-06-2012, 01:38 PM
Price: $400.00
Pros: Works Great and was not hard to install.
Cons: None so far, but it's still new.
Recommended? Yes
Comments: I bought a cover and found that I had left the cables to the battery short and they were up against the front grill too tightly to be able to even slide the cover between them. Just a small glitch. Looks great too. Of course I also purchased the Smittybuilt stuby front bumper with it and together they are a sight for sore eyes. Very good looking and useful makes a great combo. It has more than enough power to get my Unlimited Sahara out of a sticky situation. (Pun intended).
boxjeep
boxjeep's Reviews
04-01-2012, 12:37 PM
Price: $299.00
Pros: cheap, reliable , and it has helped me help others out of hairy situations
Cons: cheap....some of the pieces r brittle plastic and can break
Recommended? No
Comments: ok winch at a cheap price, too many little pieces of plastic that can break easily
but over all not many problems with winching ppl or things out so until i have to breakdown and get a more serious winch ill stay with this pup...
YJeeps
YJeeps's Reviews
03-22-2012, 12:03 AM
Price: $300.00
Pros: Works great for occasional use. Price.
Cons: Remote plug on winch is kind of cheap design
Recommended? Yes
Comments: Good price for entry level winch
Steel4Pens
Steel4Pens's Reviews
02-13-2012, 10:20 PM
Price: $250.00
Pros: Cheap works great
Cons: no wireless remote
Recommended? Yes
Comments: I love this winch. I was able to get it for a discount at the local off road store which helped. I like that the winch is a lot cheaper then some of the other brands. I do wish that it came with a wireless remote. I have mine installed on a winch plate mounted to a receiver hitch adapter so I can take it off when I'm just driving down the road and don't want the extra weight. Overall I love this winch.
Gajeepxj
Gajeepxj's Reviews
02-05-2012, 05:03 PM
Price: $300.00
Pros: price
Cons: rust
Recommended? No
Comments: This winch will work for every need without fear of breakage, however, surface rust plauges these winches.
ez412c
ez412c's Reviews
01-25-2012, 08:32 PM
Price: $299.00
Pros: cheap
Cons: works
Recommended? Yes
Comments: x
jerrym_7758
jerrym_7758's Reviews
01-10-2012, 05:51 PM
Price: $300.00
Pros: Great value
Cons: Bit slow
Recommended? Yes
Comments: ...
paulandcarollib
paulandcarollib's Reviews
01-10-2012, 12:19 AM
Price: $299.00
Pros: inexpensive, well made
Cons: inexpensive, no frills
Recommended? Yes
Comments: Some day when I have mo money, I'll upgrade to a Warn or a SuperWinch but until then I have this inexpensive, hard working winch. I haven't had any problems after 2 uses recovering myself once and a stuck Subaru!
kr1
kr1's Reviews
12-02-2011, 09:40 AM
Price: $299.00
Pros: Great price on a very usable product
Cons: Can't think of any.
Recommended? Yes
Comments: Have winched a huge double stump with this winch. It worked flawlessly. It does suck the current though. I have also test winched the jeep up a hill just to test and get use to how it works. I have found no difficulties in installing it either mechanical or electrical or in using this winch. Its a good buy and works well.
chopperkid2000
chopperkid2000's Reviews
11-25-2011, 09:17 PM
Price: $379.00
Pros: This is an X20 (waterproof) Cheap with a 3 year return if anything breaks warranty
Cons: Cheap.
Recommended? Yes
Comments: I haven't had a chance to use it yet. I will repost when I get some winch time.
SwiftJeep
SwiftJeep's Reviews
11-12-2011, 07:01 PM
Price: $299.00
Pros: 5.5 hp motor. 100' wire
Cons: nothing yet
Recommended? Yes
Comments: used it today for the first time. pulled a quad then a xj and finally my tj out of a mud pit at least 10 times within a few hours putting it to the test
DallastheJeeper
DallastheJeeper's Reviews
10-16-2011, 11:21 PM
Price: $500.00
Pros: Works every time I need it, Came with synthetic line.
Cons: Relay is not sealed, its kinda slow but thats ok
Recommended? Yes
Comments: Works when i need it.
dscabra
dscabra's Reviews
10-10-2011, 11:04 PM
Price: $299.00
Pros: Cheap price -- good enough for what I needed it it for
Cons: Build quality may not hold up to the elements over time very well
Recommended? No
Comments: I don't off-road my Jeep, but wanted a simple winch to mount on my bumper. I do drive in the snow quite a bit in the winter, so the winch was for the "just in case" scenario. After less than a year, however, the finish is fading and I just hope it actually works in the event I do ever need to use it.
mattwillard06
mattwillard06's Reviews
09-30-2011, 03:45 AM
Price: $300.00
Pros: Cheap, works when I need it,
Cons: none
Recommended? Yes
Comments: Used this a few times so far and has pulled me right out when stuck in the mud without the need for a snatch block or making it a single line on the drum full strength pull.
05SilverSi
05SilverSi's Reviews
09-22-2011, 02:21 PM
Price: $250.00
Pros: Seems pretty strong
Cons: Has solenoid issues
Recommended? Yes
Comments: This was on my jeep when I got it. The winch seems to be strong but as stated I have had solenoid issues.
Alohi Ahi
Alohi Ahi's Reviews
08-20-2011, 08:34 PM
Price: $439.00
Pros: Easy to use Good price
Cons: None so far
Recommended? Yes
Comments: Great entry level winch. Upgrade to synthetic rope for 100 more.
lowell1042
lowell1042's Reviews
08-20-2011, 12:07 AM
Price: $300.00
Pros: price
Cons: have not found any yet
Recommended? Yes
Comments: what times i have used it it worked good. I have nothing to compare it to, but the holes it pulled me out of made it well worth the money.
glenn99
glenn99's Reviews
08-19-2011, 05:12 PM
Price: $400.00
Pros: looks nice
Cons: wish I would have bought the warn with the compressor
Recommended? Yes
Comments: never used so..don't listen to me
ThreadForumRepliesLast Post
Smittybilt XRC10 Winch Winches 66 06-30-2016 06:51 AM
Smittybilt XRC8 Winches 70 06-30-2016 06:46 AM
Smittybilt XRC8 Winches 69 02-15-2016 02:08 PM
Smittybilt XRC10HD Winches 4 02-10-2016 01:20 AM
Bulldog Winch 12k Winches 1 04-12-2008 11:39 AM
