Notices
SmittyBilt XRC 8 Winch Reviews, Ratings, Specs & Prices
Review Categories
Armor
  Bumpers
  Differential Guards
  Rocker Guards
  Roll Cages
  Skid Plates
Audio, CB, & Electrical
  Audio Players
  Batteries
  CB & Ham Radios
  GPS
  Speakers
Axles
  Axle Shafts
  Brakes
  Gears
  Hubs
  Lockers
  Steering
Body
  Body Lifts
  Consoles, Security & Storage
  Exterior Accessories
  Fender Flares
  Lighting, Lenses & Bulbs
  Roof Racks & Cargo Areas
  Tops
Engine
  Alternators
  Carburetors
  Chips
  Exhaust
  Headers
  Induction
  Internal Parts
  Motor Mounts
  Starters
  Throttle Body
Interior
  Gauges
  Misc
  Seats
Recovery
  Winch Cable and Hooks
  Winches
Suspension
  Complete Lift Kits
  Control Arms
  Shocks
  Springs
  Steering Stabilizers
  Track Bars
Tires & Wheels
  Tires
  Wheels
Transfer Case
  SYE Kits
  Transfer Cases
Transmissions
  Transmissions
Previous Product Winches Next Product
Rating:
Product Information
MSRP: $900.00
Average Price: $305.47
Manufacturer: SmittyBilt
Recommended?
Yes: 279 / No: 9
Direct from 4wd.com:
The NEW Smittybilt XRC8 8,000lb winch has a hand wound permanent magnetic motor which is the standard for the true off Roader. This is the most reliable motor on the market today. Two Year Limited Warranty, 4.1 hp motor, 3-stage planetary gear system, 265:1 reduction ratio for fast line speed, free spooling, automatic load-holding brake, power in and out and a roller fairlead. A 12 ft illuminated handheld remote control,. Comes with a 5/16" x 92 galvanized aircraft cable with replaceable hook. Mounting bolt pattern: 10" x 4.5", OAL Dim. 21" x 6.22" x 7.283". This item incurs a $19.99 shipping surcharge.
-Rated line pull: 8,000 lbs. (3629 kg) single line
-Gear train: planetary gear system
-Gear ratio: 265:1
-Motor (permanent magnet): 4.1 hp (3kw), 12volt
None
Page 2 of 15 1 2 3 4 5 6 7 8 9 10 11 12 13 > Last
wrestler22115
wrestler22115's Reviews
09-04-2013, 12:18 PM
Price: $300.00
Pros: works good for what i need
Cons: non
Recommended? Yes
Comments: The winch works great. helped me a couple of times
gunny40
gunny40's Reviews
08-17-2013, 01:41 AM
Price: $299.99
Pros: price
Cons: installation instructions were lacking.
Recommended? Yes
Comments: Through reading reviews and doing a little research I decided to purchase a smittybilt xrc 8 winch. Just installed tonight will try it out tomorrow.
zombiehunta666
zombiehunta666's Reviews
06-24-2013, 11:38 PM
Price: $299.00
Pros: Price and effectiveness
Cons: 8,000 lb limit
Recommended? Yes
Comments: Haven't used it yet. That's actually good news but someone needs one in the group.
rogerv
rogerv's Reviews
06-17-2013, 01:50 PM
Price: $350.00
Pros: Good value
Cons: None
Recommended? Yes
Comments: Great winch for the money spent. If I had to do it over again, I would probably go a little bigger. Installation was a breeze.
rogerv
rogerv's Reviews
Price: $350.00
Pros: Good value
Cons: None
Recommended? Yes
swissmike
swissmike's Reviews
02-14-2013, 11:06 PM
Price: $280.00
Pros: Easy install
Cons: None yet
Recommended? Yes
Comments: Just added the winch this winter and used it a couple time to pull someone out of the ditch. Works great.
ROWA
ROWA's Reviews
02-03-2013, 08:31 PM
Price: $299.00
Pros: Does the job
Cons: Slow
Recommended? Yes
Comments: This winch is slow, but get's the job done. I added a Badland wireless remote.
houndman72
houndman72's Reviews
01-21-2013, 12:22 PM
Price: $259.00
Pros: Easy to install and wire to vehicle system
Cons: heavy! LOL
Recommended? Yes
Comments: works great, no issues in the water or mud at all. It's a great looking winch and look forward to having it get put to use when OTHERS get stuck.
RemoteTrax
RemoteTrax's Reviews
01-12-2013, 12:49 AM
Price: $300.00
Pros: Decent price and it works well.
Cons: none
Recommended? Yes
Comments: I have use this winch a few times, light duty and heavy duty winching. This product worked very well and had plenty of power for my use. For the price, I think this is product.
MarkPlano
MarkPlano's Reviews
12-30-2012, 05:02 PM
Price: $299.00
Pros: Easy Install
Cons: None
Recommended? Yes
Comments: Only used it once so-far. Worked Great! Just need to upgrade alternator ...in case I use winch for a longer period of time,don't want to kill my battery!
Justin_WJ
Justin_WJ's Reviews
12-10-2012, 11:08 PM
Price: $120.00
Pros: great power
Cons: slow line speed
Recommended? Yes
Comments: Great product, very sturdy. only thing i dont like is the slow line speed
GootsYJ1990
GootsYJ1990's Reviews
11-14-2012, 11:32 PM
Price: $300.00
Pros: Waterproof, easy install, looks great, easy to use.
Cons: None.
Recommended? Yes
Comments: I've only had to use it a few times, but for the times I did put it to use it worked flawlessly. I would definitely buy it again.
slamtheright
slamtheright's Reviews
11-11-2012, 10:03 AM
Price: $285.00
Pros: has never let me down
Cons: cheap controllers, known for failure
Recommended? Yes
Comments: i have used it for every weekend for about two yrs. still strong.
govols74n
govols74n's Reviews
10-03-2012, 06:48 PM
Price: $289.00
Pros: Price, reliability.
Cons: It's not a Warn.
Recommended? Yes
Comments: I've used the winch a few times, it does the job, works great, wasn't hard to mount (did it by myself) and the price fit my budget.
jeepersjeepjk
jeepersjeepjk's Reviews
09-10-2012, 09:38 AM
Price: $399.00
Pros: Synthetic rope
Cons: Sometimes the "Emgage/Free Spool" lever gets stuck (maybe once a year). Little WD-40 and it's good to go. Not really an issuse.
Recommended? Yes
Comments: I've done some hard pulls and everything worked great. This will be my 4th XRC8 and I've used them for tree work, setting up fences, pulling people of of ditches in the winter time, and helping out on the trail. Great winch! Highly suggest.
Rhulain
Rhulain's Reviews
08-22-2012, 01:24 AM
Price: $299.00
Pros: been great no downs so far. really strong with the snatch block.
Cons: havent found any yet. my jeep dosent get stuck often enough to use it but it pulls trucks out great. down side it has enough power to pull my jeep into the hole with the stuck vehicle. can pull anything with my snatch block.
Recommended? Yes
Comments: havent found any real downs yet. my jeep dosent get stuck often enough to use it but it pulls trucks out great. actually one down side it has enough power to pull my jeep into the hole with the stuck vehicle. can pull anything with my snatch block and winch combo.
darren2569
darren2569's Reviews
08-21-2012, 08:47 PM
Price: $299.00
Pros: Great winch for the price
Cons: none so far.
Recommended? Yes
Comments: Only used it twice so far but it worked great both times
tclewis
tclewis's Reviews
08-12-2012, 09:54 PM
Price: $10.00
Pros: It was free
Cons: Its not a warn power plant 12
Recommended? Yes
Comments: have not had a chance to use it yet but it was easy to install.
tmichael921
tmichael921's Reviews
08-12-2012, 01:50 AM
Price: $280.00
Pros: Install is easy (as long as you wire before mounting to winch plate) runs good
Cons: Very hard install if doing on your own
Recommended? Yes
Comments: This is a quality winch that has worked quite well so far. I've used it a few times to for my YJ and also to help other jeeps and it seems like it will hold up. You may want to buy the winch cover or make one yourself just because the plastic solenoid casing seems like it may weather easily.
Ahendo
Ahendo's Reviews
07-22-2012, 09:17 PM
Price: $249.00
Pros: Affordable. Decent reviews, good reputation for occasional winching. Free cover (junk).
Cons: China winch. Could die at any moment.
Recommended? Yes
Comments: Bought at 4WP truckfest, so good prices were to be had. I don't winch often, so this product is ideal for me.
ThreadForumRepliesLast Post
Smittybilt XRC10 Winch Winches 66 06-30-2016 06:51 AM
Smittybilt XRC8 Winches 70 06-30-2016 06:46 AM
Smittybilt XRC8 Winches 69 02-15-2016 02:08 PM
Smittybilt XRC10HD Winches 4 02-10-2016 01:20 AM
Bulldog Winch 12k Winches 1 04-12-2008 11:39 AM
