Go Back JeepForum.com > Reviews > Recovery > Winches > SmittyBilt XRC 8 Winch
Brand new! XJ Rear DIY Bumper from JcrOffroad!Spartan Lockers FREE SHIPPING Excellent PricesGR8TOPS Introduces the Exogate HD Tire Carrier
SmittyBilt XRC 8 Winch Reviews, Ratings, Specs & Prices
Review Categories
Armor
  Bumpers
  Differential Guards
  Rocker Guards
  Roll Cages
  Skid Plates
Audio, CB, & Electrical
  Audio Players
  Batteries
  CB & HAM Radios
  GPS
  Speakers
Axles
  Axle Shafts
  Brakes
  Gears
  Hubs
  Lockers
  Steering
Body
  Body Lifts
  Consoles, Security & Storage
  Exterior Accessories
  Fender Flares
  Lighting, Lenses & Bulbs
  Roof Racks & Cargo Areas
  Tops
Engine
  Alternators
  Carburetors
  Chips
  Exhaust
  Headers
  Induction
  Internal Parts
  Motor Mounts
  Starters
  Throttle Body
Interior
  Gauges
  Misc
  Seats
Recovery
  Winch Cable and Hooks
  Winches
Suspension
  Complete Lift Kits
  Control Arms
  Shocks
  Springs
  Steering Stabilizers
  Track Bars
Tires & Wheels
  Tires
  Wheels
Transfer Case
  SYE Kits
  Transfer Cases
Transmissions
  Transmissions
Previous Product Winches Next Product
Rating:
Product Information
MSRP: $900.00
Average Price: $306.07
Manufacturer: SmittyBilt
Recommended?
Yes: 235 / No: 7
Direct from 4wd.com:
The NEW Smittybilt XRC8 8,000lb winch has a hand wound permanent magnetic motor which is the standard for the true off Roader. This is the most reliable motor on the market today. Two Year Limited Warranty, 4.1 hp motor, 3-stage planetary gear system, 265:1 reduction ratio for fast line speed, free spooling, automatic load-holding brake, power in and out and a roller fairlead. A 12 ft illuminated handheld remote control,. Comes with a 5/16" x 92’ galvanized aircraft cable with replaceable hook. Mounting bolt pattern: 10" x 4.5", OAL Dim. 21" x 6.22" x 7.283". This item incurs a $19.99 shipping surcharge.
-Rated line pull: 8,000 lbs. (3629 kg) single line
-Gear train: planetary gear system
-Gear ratio: 265:1
-Motor (permanent magnet): 4.1 hp (3kw), 12volt
Page 1 of 13 1 2 3 4 5 6 7 8 9 10 11 12 13 > Last »
Gajeepxj
Gajeepxj's Reviews
02-05-2012, 04:03 PM
Price: $300.00
Pros: price
Cons: rust
Recommended? No
Comments: This winch will work for every need without fear of breakage, however, surface rust plauges these winches.
ez412c
ez412c's Reviews
01-25-2012, 07:32 PM
Price: $299.00
Pros: cheap
Cons: works
Recommended? Yes
Comments: x
jerrym_7758
jerrym_7758's Reviews
01-10-2012, 04:51 PM
Price: $300.00
Pros: Great value
Cons: Bit slow
Recommended? Yes
Comments: ..…….…
paulandcarollib
paulandcarollib's Reviews
01-09-2012, 11:19 PM
Price: $299.00
Pros: inexpensive, well made
Cons: inexpensive, no frills
Recommended? Yes
Comments: Some day when I have mo money, I'll upgrade to a Warn or a SuperWinch but until then I have this inexpensive, hard working winch. I haven't had any problems after 2 uses recovering myself once and a stuck Subaru!
kr1
kr1's Reviews
12-02-2011, 08:40 AM
Price: $299.00
Pros: Great price on a very usable product
Cons: Can't think of any.
Recommended? Yes
Comments: Have winched a huge double stump with this winch. It worked flawlessly. It does suck the current though. I have also test winched the jeep up a hill just to test and get use to how it works. I have found no difficulties in installing it either mechanical or electrical or in using this winch. Its a good buy and works well.
chopperkid2000
Hey man, Check this out !
chopperkid2000's Reviews
11-25-2011, 08:17 PM
Price: $379.00
Pros: This is an X20 (waterproof) Cheap with a 3 year return if anything breaks warranty
Cons: Cheap.
Recommended? Yes
Comments: I haven't had a chance to use it yet. I will repost when I get some winch time.
SwiftJeep
SwiftJeep's Reviews
11-12-2011, 06:01 PM
Price: $299.00
Pros: 5.5 hp motor. 100' wire
Cons: nothing yet
Recommended? Yes
Comments: used it today for the first time. pulled a quad then a xj and finally my tj out of a mud pit at least 10 times within a few hours putting it to the test
DallastheJeeper
A Jeep saved my life
DallastheJeeper's Reviews
10-16-2011, 10:21 PM
Price: $500.00
Pros: Works every time I need it, Came with synthetic line.
Cons: Relay is not sealed, its kinda slow but thats ok
Recommended? Yes
Comments: Works when i need it.
dscabra
dscabra's Reviews
10-10-2011, 10:04 PM
Price: $299.00
Pros: Cheap price -- good enough for what I needed it it for
Cons: Build quality may not hold up to the elements over time very well
Recommended? No
Comments: I don't off-road my Jeep, but wanted a simple winch to mount on my bumper. I do drive in the snow quite a bit in the winter, so the winch was for the "just in case" scenario. After less than a year, however, the finish is fading and I just hope it actually works in the event I do ever need to use it.
mattwillard06
mattwillard06's Reviews
09-30-2011, 02:45 AM
Price: $300.00
Pros: Cheap, works when I need it,
Cons: none
Recommended? Yes
Comments: Used this a few times so far and has pulled me right out when stuck in the mud without the need for a snatch block or making it a single line on the drum full strength pull.
05SilverSi
05SilverSi's Reviews
09-22-2011, 01:21 PM
Price: $250.00
Pros: Seems pretty strong
Cons: Has solenoid issues
Recommended? Yes
Comments: This was on my jeep when I got it. The winch seems to be strong but as stated I have had solenoid issues.
Alohi Ahi
Junior Member
Alohi Ahi's Reviews
08-20-2011, 07:34 PM
Price: $439.00
Pros: Easy to use Good price
Cons: None so far
Recommended? Yes
Comments: Great entry level winch. Upgrade to synthetic rope for 100 more.
lowell1042
lowell1042's Reviews
08-19-2011, 11:07 PM
Price: $300.00
Pros: price
Cons: have not found any yet
Recommended? Yes
Comments: what times i have used it it worked good. I have nothing to compare it to, but the holes it pulled me out of made it well worth the money.
glenn99
glenn99's Reviews
08-19-2011, 04:12 PM
Price: $400.00
Pros: looks nice
Cons: wish I would have bought the warn with the compressor
Recommended? Yes
Comments: never used so..don't listen to me
cont7
cont7's Reviews
08-04-2011, 01:35 PM
Price: $350.99
Pros: Good looks, awesome packaging, awesome finish
Cons: Install on a XRC front bumper is a PITA. But one thing is for sure, if someone wants to steal it, they will have a hard time taking it off
Recommended? Yes
Comments: Install on a XRC front bumper is a PITA. But one thing is for sure, if someone wants to steal it, they will have a hard time taking it off
Jeepnation2011
Jeepnation2011's Reviews
07-09-2011, 08:25 PM
Price: $299.00
Pros: love it. Cheap and reliable.
Cons: none
Recommended? Yes
Comments: Good and reliable for what I do. Trail riding in mountains. Not allot of rock crawling. But for the price and quality it's good for my lifestyle of Jeeping.
bhoover61
bhoover61's Reviews
07-02-2011, 12:36 PM
Price: $300.00
Pros: cheap
Cons: not as good as warn
Recommended? Yes
Comments: good winch
motlemans
motlemans's Reviews
06-13-2011, 05:33 AM
Price: $400.00
Pros: Dependable
Cons: Product of China
Recommended? Yes
Comments: great product for the money. Easy install. Now that WARN has come out with a 8k winch for the same price I think I would go with that instead
s_beckerle
s_beckerle's Reviews
06-05-2011, 02:09 PM
Price: $240.99
Pros: Looks nice, Pulls hard, directions are great.
Cons: NONE
Recommended? Yes
Comments: Have yet to put it to the test, but know it has already been a nice addition.
hellinthewoods
hellinthewoods's Reviews
06-05-2011, 01:25 PM
Price: $400.00
Pros: very reliable pulls hard
Cons: Kinda slow, steel cable
Recommended? Yes
Comments: I've used and used this winch many many times on my xj, its never failed me, i'd rather not get the steel cable next time tho, too hard to roll back in. This is an excellent winch. I do wish it was a little quicker. overall great winch.
ThreadForumRepliesLast Post
Smittybilt XRC8 Winches 48 09-12-2011 08:09 PM
Smittybilt XRC10 Winch Winches 28 06-11-2011 09:01 PM
Smittybilt XRC8 Winches 35 06-01-2011 11:44 AM
Smittybilt XRC10HD Winches 0 01-08-2009 07:38 AM
Bulldog Winch 12k Winches 1 04-12-2008 12:39 PM
Glock Forum
