Product Information
RECON's new "Recovery Division" has everything you need if you are serious about mudding, off-roading, rock climbing, or salvage & recovery. RECON's new Pro Performance Series Winches & Brute Force Series Winches are the best money can buy & we back that statement up with a limited lifetime warranty.
So whether you're 4 feet deep in a Louisiana swamp, sliding along on red Georgia clay, jumping sand dunes in Arizona, sandwiched between 2 rock mountains somewhere in Utah, or up to your windshield in fresh white powder, RECON's new line of award winning winches will give you the piece of mind you need so you don't get stuck way out in the boondocks.
RECON's newest award-winning winches have raised the bar with regards to reliability, line speed, and pulling power. With the fastest line speed (28 feet per minute) of any serious winch sold in the automotive aftermarket & enough pulling capacity (17,500LBS) to get you out of even the most serious bind.
PART # 264100PPW - PRO PERFORMANCE SERIES Winch Specs are as follows:
10,500LB, 12VDC 6.5HP MOTOR, 3-Stage Planetary Gear w/ 218:1 Ratio for Exceptional Line Speed, Aluminum Hawse Fairlead, 88ft of 7/16" Synthetic Rope Rated 16,500LBS, Controlled by both Wireless (30ft Range) & Wired Remotes
Performance: 12VDC
Single line rated pull: 10,500lb (4773kg)
Motor: 6.5hp Series Wound (4.9kw)
Solenoid: IP67 Rated against dust and water
Wired Remote: Wired Remote switch, 12ft (3.7m) lead
Wireless Remote: RF Wireless Remote, 30ft (9.14m) range
Gear train: 3 Stage Performance Planetary Gear Train
Gear Reduction Ratio: 218:1 for incredible line speed
Clutch: Sliding Ring Gear
Braking Action: Automatic In-The-Drum
Drum size: Drum size Diameter 2.5"(63.5mm ) Length 8.8"( 224mm)
Synthetic Rope: 88ft of 7/16" diameter (26.5m of 10.5mm) Rated 7.5 tons or 16,500lb
Fairlead: Aluminum Hawse Fairlead
Mounting Pattern: 4.5" x 10" bolt pattern (114.3mm x 254mm)
Battery Recommended: 650CCA minimum for winching
Battery Leads: 2 gauge 72"(1.83m)
Net Weight: 62lb (28kg)
Gross Weight: 66lbs (30kg)
PART # 264100BFW - BRUTE FORCE SERIES Winch Specs are as follows:
17,500LB, 12VDC 7.0HP MOTOR, 3-Stage Planetary Gear w/ 358.4:1 Ratio, 22,050LB Snatch Block, 4-Way Roller Fairlead, 92ft of 7/16" Aircraft Grade Steel Cable Controlled by Wired Remote
Performance: 12VDC
Single line rated pull: 17,500lbs (7,955kg)
Motor: 7.0hp Series Wound (5.2kw)
Gear train: 3 Stage Planetary
Gear ratio: 358.4:1 for increased torque
Brake: Automatic in-the-drum
Drum size: 3.5"(89mm) diameter X 8.8"(223mm) length
Steel Line Cable: 7/16" (12mm) diameter X 92ft. (28m) length - Aircraft grade steel
Snatch Block: 22,050lb (10 ton)
Fairlead: 4-way roller fairlead
Overall dimensions (LxWxH) 21.85" x 7.75" x 9.8" (555 x 196 x 249mm)
Mounting bolt pattern: 10" x 4.5" (254mm x 114mm)
Net weight: 125lb (56kg)
Gross weight: 129lb (58kg)
Price | $999.99 |
Rating | 4 |
Average Price | $442.42 |
Manufacturer | Recon |
Recommended | Yes: 8 / No: 0 |
Company website | http://www.gorecon.com |
Performance: 12VDC
Performance: 12VDC
