Mile Marker Hydraulic
Rating: |
Product Information
| MSRP: |
$1,500.00 |
| Average Price: |
$892.90 |
| Manufacturer: |
Mile Marker |
| Recommended? |
10,500 lb winch, military specs. Two speeds, free spooling.
byersbm1's Reviews
Price: $1,500.00 Pros: Has not let me down when needed Cons: Nonw Recommended? Yes
Comments: Does what its supposed to do, gets you or a buddy out of a tight spot
Kitsune's Reviews
Price: $750.00 Pros: Strong like bull Cons: Slow like snail Recommended? Yes
Comments: It has never let me down, pulled everything from myself to a full size Dodge 3500 Diesel with 44 swampers on it. It chugs along slow and reliable. If my engine is running this thing is pulling.
lam4eks's Reviews
Price: $187.00 Pros: Great Price Cons: none Recommended? Yes
Comments: I bought this online from govligudation.com. It was a used 10500 winch, once i got it I had to clean it up and change out a few things which were added cost to it but Totally i think i spend under $500.00
Netpackrat's Reviews
Price: $800.00 Pros: Strong as hell, trouble free, 100% duty cycle, can be reconfigured to run in either direction. Cons: Requires modification of power steering circuit, slow, and will not work if engine is not running Recommended? Yes
Comments: No complaints whatsoever about the winch. I was able to mount it to a front winch bumper designed specifically for another brand winch, by turning the motor 180 degrees, changing the valving around (Milemarker will provide instructions on how to do this if you ask), and mounting the winch backwards. The ONLY problem I have had was with getting one of the supplied hoses to fit, and I think that was because I ended up with the YJ adapter kit. I used a splice kit to combine my stock PS hose to the supplied hydraulic hose, and later I had a custom hose made so I could eliminate the splice. After 8 years I also replaced some of the original wiring, which was getting a bit ratty under the hood of my Jeep.
jetter's Reviews
03-25-2009, 01:27 PM |
Price: $920.69 Recommended? Yes
Comments: Mile Marker HI-9000
Strong winch that never gets hot and just keeps on running. Speed is not as fast as electric but acceptable.
Installation was not difficult but the instructions could be a little better. The hydraulic hoses that come with the kit are way too long for a jeep. I had them cut down about half the size.
73CJMN's Reviews
02-28-2009, 12:51 PM |
Price: $700.00 Recommended? Yes
Comments: Fantastic. Runs all day and keeps on going! 2-speed is a good option for rewinding and lite pulls.
BIGET's Reviews
10-11-2008, 05:10 PM |
Recommended? Yes
Comments: Slow recovery speed, but tuff as hell. Compaired to my buddies Warn 9500Ti it pulls lot slower under no load but loaded the same and I dont overheat...
NC2001TJ's Reviews
08-20-2008, 03:27 PM |
Price: $850.00 Recommended? Yes
Comments: Great winch. 100% duty cycle. No need for extra battery. Replaced cable with rope. Easy install to factory popwer steering pump.
Con: engine must be running
rich5166's Reviews
07-02-2008, 12:57 AM |
Price: $1,500.00 Recommended? Yes
Comments: This is a very good winch. The only drawback is to get full potential you must upgrade your power steering pump.
jdarg's Reviews
06-27-2008, 04:13 PM |
Price: $750.00 Recommended? No
Comments: I've managed to stall it and it's REALLY slow...but it usually does the job.
44 NSB's Reviews
05-14-2008, 08:30 PM |
Price: $1,000.00 Recommended? Yes
Comments: It worked as advertised. Takes a while to learn the controls. Two speeds, one for faster take up.
Creases's Reviews
05-14-2008, 01:13 PM |
Price: $950.00 Recommended? Yes
Comments: Winch itself is great. Electronics’ not good connector and controller went out after second use. Replaced with std. 4 wire trailer conectors and new water proof controller. Works fine now.
stellan's Reviews
05-03-2008, 01:29 PM |
Price: $1,200.00 Recommended? Yes
Comments: Great pulling power but way to slow on the power steering pump!
Planing to install an extra hydraulic pump.
dugn8r's Reviews
04-18-2008, 11:12 AM |
Price: $500.00 Recommended? Yes
Comments: This thing just pulls and pulls... and has the reliability that will never fail.
Saubaer's Reviews
04-11-2008, 03:57 AM |
Recommended? Yes
Comments: Excellent Product
