Hi-Lift Jack Hi-Lift Jack Reviews, Ratings, Specs & Prices
Review Categories
Armor
  Bumpers
  Differential Guards
  Rocker Guards
  Roll Cages
  Skid Plates
Audio, CB, & Electrical
  Audio Players
  Batteries
  CB & Ham Radios
  GPS
  Speakers
Axles
  Axle Shafts
  Brakes
  Gears
  Hubs
  Lockers
  Steering
Body
  Body Lifts
  Consoles, Security & Storage
  Exterior Accessories
  Fender Flares
  Lighting, Lenses & Bulbs
  Roof Racks & Cargo Areas
  Tops
Engine
  Alternators
  Carburetors
  Chips
  Exhaust
  Headers
  Induction
  Internal Parts
  Motor Mounts
  Starters
  Throttle Body
Interior
  Gauges
  Misc
  Seats
Recovery
  Winch Cable and Hooks
  Winches
Suspension
  Complete Lift Kits
  Control Arms
  Shocks
  Springs
  Steering Stabilizers
  Track Bars
Tires & Wheels
  Tires
  Wheels
Transfer Case
  SYE Kits
  Transfer Cases
Transmissions
  Transmissions
Previous Product Winches Next Product
Rating:
Product Information
MSRP: $159.00
Average Price: $68.06
Manufacturer: Hi-Lift Jack
Recommended?
Yes: 62 / No: 0
The Hi-Lift Jack is a rugged, highly versatile jack that puts you in command of situations requiring lifting, pushing, pulling, winching, and clamping. Although light in weight and easy to maneuver, the Hi-Lift Jack offers a rated lifting capacity of 2 1/3 tons (2114.74kg).
None
Page 2 of 4 1 2 3 4 > Last
trlblznjeeper33
trlblznjeeper33's Reviews
07-17-2010, 11:06 PM
Price: $60.00
Pros: great lifting power, very user friendly
Cons: Keep an eye on the nuts that hold it together, and make sure to lube it
Recommended? Yes
Comments: I started out using my hi-lift and a come-along before i invested in my winch, and still use it in conjunction with my winch whenever i have to pull in 2 directions. If you don't keep an eye on the nuts that hold it together they will loosen up and "disappear" on you, making it next to impossible to know whats going to happen when jacking. Also make sure to keep a can of white lithium grease or silicone spray in the jeep to lube the lifting mechinisim one end or the other on the ground. And don't try to jack the entire front end or rear end, it gets a little tippy if you only have If those are the only three downsides, why not get it.
DaFuzz80
DaFuzz80's Reviews
07-16-2010, 05:31 PM
Price: $69.99
Pros: Lifts, winches, clamps, breaks beads, well built
Cons: Heavy
Recommended? Yes
Comments: This jack is great, not really to be used as a jack much. Lifts, winches, clamps, breaks beads, very well built! Great all purpose jack to be used as a multi tool.
luckychris
luckychris's Reviews
06-24-2010, 05:57 PM
Price: $75.00
Pros: It's great!
Cons: none
Recommended? Yes
Comments: So the thing about the Hi-Lift jack is, it's not just for liftin' yer Jeep! I have used it for just about eveything. I cannot think of a single reason to not own a Hi-Lift jack, case closed.
tater_kamik
tater_kamik's Reviews
06-22-2010, 03:50 PM
Price: $80.00
Pros: useful
Cons: sometimes does not want to switch back to raise
Recommended? Yes
Comments: It lifts, it pulls, its tall, its sturdy. If you wheel, you need one. Just dont be stupid using it (as with any jack).
ROADDOG516
ROADDOG516's Reviews
06-18-2010, 01:34 AM
Price: $84.00
Pros: heavy duty
Cons: expensive
Recommended? Yes
Comments: what can i say got one cause they are top notch
BubbaArmy
BubbaArmy's Reviews
04-25-2010, 10:00 AM
Price: $79.99
Pros: Easy to use, must have
Cons: Placement
Recommended? Yes
Comments: Does the job and more.
submrnman
submrnman's Reviews
03-15-2010, 07:25 AM
Price: $79.99
Pros: It's 7,000 lbs of pull and lift for $79.99.
Cons: Hard to find a good looking and convenient place to mount it.
Recommended? Yes
Comments:
There is not much to say here. It's a Hi-Lift...
JerseyWJ
JerseyWJ's Reviews
03-07-2010, 09:25 AM
Price: $48.00
Pros: Great tool
Cons: Storage in vehicle
Recommended? Yes
Comments: Can be used for a jack, lift, winch, whatever. Excellent tool.
iceman123187
iceman123187's Reviews
03-06-2010, 02:31 PM
Price: $100.00
Pros: good for anything
Cons: limited places to mount
Recommended? Yes
Comments: Comes in handy
jsullivan878
jsullivan878's Reviews
02-28-2010, 11:22 PM
Price: $50.00
Pros: great for changing tires and getting out of a sticky situation
Cons: can only move 3 feet or so then have to rehook
Recommended? Yes
Comments: Great jack, absolute must if you do not have winch
racenkiwi
racenkiwi's Reviews
01-10-2010, 01:34 PM
Price: $50.00
Pros: great multi use tool.
Cons: can be trouble when its dirty
Recommended? Yes
Comments: I've use my hi-lift jack more times than i would like. It's helped me change flats on the road. Used it as a winch a few times. Can be used in alot more ways too. Seen it used to keep a tire in place when the axleshaft of a d35 c-clip broke. Used the help bend components back into place.
bbjsw10
bbjsw10's Reviews
11-22-2009, 01:30 PM
Price: $50.00
Pros: Ease of use Multi Purpose Versatile
Cons: None really as long as you grease it
Recommended? Yes
Comments: Must have for anyone. Can use for almost anything, winch, jack, clamp, etc. Love mine.
weldonfoto
weldonfoto's Reviews
11-15-2009, 09:30 PM
Price: $60.00
Pros: Looks like it'll work if you need it
Cons: You hope you'll never need it.
Recommended? Yes
Comments: I bought the 48 inch cast/steel model which looks like it will be more than adequate for my needs. I didn't like the all cast model because it was red and the extreme version is too pricey. This one is just right!
justin816
justin816's Reviews
11-11-2009, 01:44 AM
Price: $60.00
Pros: never fails, no battery, always ready
Cons: is there any? except maybe I have to work the handle.
Recommended? Yes
Comments: Always a good back up. Never have to worry about electrical. Can always count on.
The best invention since the Jeep!!
CrawlorClimb
CrawlorClimb's Reviews
10-10-2009, 12:12 PM
Price: $99.99
Pros: Nice fit and finish
Cons: Really heavy
Recommended? Yes
Comments: I went with the X-treme version of the jack for the clamping feature. Haven't had a chance to use it other than to raise my jeep onto the jack stands(this didn't seem safe, get the wheel hook attachment
r_unda
r_unda's Reviews
10-08-2009, 11:25 PM
Price: $80.00
Pros: Very reliable
Cons: None
Recommended? Yes
Comments: Cant beat the quality of Hi-Lift, dont buy those cheap farm jacks
rocknjeep
rocknjeep's Reviews
08-02-2009, 02:50 AM
Price: $1.00
Pros: does it's job of jacking. solid as all hell
Cons: none
Recommended? Yes
Comments: got mine for free with the jeep. it's nice and solid. does it's job of jacking. dunno what else to say about it.
ejlaychock
ejlaychock's Reviews
07-30-2009, 11:29 AM
Price: $100.00
Pros: nice easy to use product looks badass on the hood on my jeep
Cons: pain in the ass to take off the hood of the jeep - but worth it being there for how badass it looks
Recommended? Yes
Comments: review above
grymsr
Vintage Member
grymsr's Reviews
07-09-2009, 10:48 PM
Price: $49.00
Pros: a real do-all tool
Cons: heavy, awkward, possibly dangerous
Recommended? Yes
Comments: I bought my hi-lift before knowing what exactly I planned to do with it. Since then I have found all kinds of thing to use it for including as a threatening weapon. Yet even after using it a bunch of times, it still scares me sometimes when it does something unexpected, like bumping out of the climbing position before I am ready to start lowering.
DJDarkGift
DJDarkGift's Reviews
04-04-2009, 09:18 PM
Price: $79.99
Recommended? Yes
Comments: Haven't had to use it yet, as I'm sure I will in the future. It's nice to see how well this thing is made and how solid it is. Make me feel safe knowing I have it for when I need it.
ThreadForumRepliesLast Post
Hi-Lift 60" All - Cast Jack Winches 11 11-13-2015 04:33 PM
Hi Lift Extreme 48" Winches 16 02-26-2011 12:59 AM
