Go Back JeepForum.com > Reviews > Recovery > Winches > Hi-Lift Jack Hi-Lift Jack
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineGR8TOPS Introduces the Exogate HD Tire Carrier4.25" 97-06 Jeep TJ Wrangler Lift Kit - NO SYE Needed
Hi-Lift Jack Hi-Lift Jack Reviews, Ratings, Specs & Prices
Review Categories
Armor
  Bumpers
  Differential Guards
  Rocker Guards
  Roll Cages
  Skid Plates
Audio, CB, & Electrical
  Audio Players
  Batteries
  CB & HAM Radios
  GPS
  Speakers
Axles
  Axle Shafts
  Brakes
  Gears
  Hubs
  Lockers
  Steering
Body
  Body Lifts
  Consoles, Security & Storage
  Exterior Accessories
  Fender Flares
  Lighting, Lenses & Bulbs
  Roof Racks & Cargo Areas
  Tops
Engine
  Alternators
  Carburetors
  Chips
  Exhaust
  Headers
  Induction
  Internal Parts
  Motor Mounts
  Starters
  Throttle Body
Interior
  Gauges
  Misc
  Seats
Recovery
  Winch Cable and Hooks
  Winches
Suspension
  Complete Lift Kits
  Control Arms
  Shocks
  Springs
  Steering Stabilizers
  Track Bars
Tires & Wheels
  Tires
  Wheels
Transfer Case
  SYE Kits
  Transfer Cases
Transmissions
  Transmissions
Previous Product Winches Next Product
Rating:
Product Information
MSRP: $159.00
Average Price: $67.24
Manufacturer: Hi-Lift Jack
Recommended?
Yes: 54 / No: 0
The Hi-Lift Jack is a rugged, highly versatile jack that puts you in command of situations requiring lifting, pushing, pulling, winching, and clamping. Although light in weight and easy to maneuver, the Hi-Lift Jack offers a rated lifting capacity of 2 1/3 tons (2114.74kg).
Page 1 of 3 1 2 3 > Last »
Gajeepxj
Gajeepxj's Reviews
02-05-2012, 04:05 PM
Price: $120.00
Pros: awesome
Cons: no place to store it, rusts
Recommended? Yes
Comments: buy a neoprene boot too.
HitowerInc
HitowerInc's Reviews
09-10-2011, 09:34 AM
Price: $49.95
Pros: Decent price. Well built.
Cons: Large size. Finding mounting points.
Recommended? Yes
Comments: High lift jack from tool outlet here in Pigeon Forge. Seems ok. Mounted it inside between the roll bars.
Stryker777
Stryker777's Reviews
04-06-2011, 11:18 AM
Price: $67.00
Pros: Gets me out of the holes and works great for stretching fence. I put the jackmate attachment on it and it really makes this tool better.
Cons: Drops quick if you don't have enough weight on it. Hard to find a good place to mount.
Recommended? Yes
Comments: This jack is built tough. With the right attachments, it is the perfect tool for recovery and rescue work. I added the Jackmate to it for extra functionality. It is heavy and large so find a good place to mount it before you pick the size you want. I am using fence bands and mounting it to my roll cage.
dirtydan69
dirtydan69's Reviews
03-28-2011, 02:20 PM
Price: $60.00
Pros: best thing to buy when starting out! use this more than any other jeep item i own.
Cons: kind of hard to find a good place for it.
Recommended? Yes
Comments: best thing to buy when starting out! use this more than any other jeep item i own.
ubengineer
ubengineer's Reviews
03-24-2011, 08:38 AM
Price: $50.00
Pros: ...
Cons: ...
Recommended? Yes
Comments: ...
Lyonsa80
Junior Member
Lyonsa80's Reviews
01-02-2011, 08:34 PM
Price: $65.00
Pros: Tough and reliable. Multi-use functions. Durable (takes a licking). Reasonably priced.
Cons: Heavy as all get out. (But worth it.)
Recommended? Yes
Comments: Good all around tool for the trail. Tough, reliable, proven durable. Have one mounted on my XJ. Easy to maintain. Heavy duty, but heavy as can be. Be strategic of where you mount it on your rig. It can both help and hurt you.
Most of all...learn how to use it correctly!!!
Would recommend to anyone that cannot afford a winch. It can be used as one if properly rigged! Read up on it and watch some you-tube videos!
Zakman
A locked & armored Sport
Zakman's Reviews
12-05-2010, 08:25 AM
Price: $60.00
Pros: Brick simple design, USA built.
Cons: Not to be used for off trial. Heavy.
Recommended? Yes
Comments: May not always need a Hi-Lift, but when you do, you'll wish you had one. Pay attention to when using it, it can't kick you in the pants.
markxj2k
markxj2k's Reviews
10-03-2010, 09:47 PM
Price: $70.00
Pros: It's a hi-lift jack.
Cons: It rusts
Recommended? Yes
Comments: What can you say about a Hi-Lift Jack? I use mine more in the driveway than I do on the trails, but when you need a jack on the trails I'd only use a Hi-Lift.
If you keep it on your rig all the time like I do, you have to sand-off the rust and repaint it about once a year.
Spikex
Gas on it!
Spikex's Reviews
09-13-2010, 04:33 PM
Price: $75.00
Pros: Awesome.
Cons: It fell over once.
Recommended? Yes
Comments: Awesome jack.
greenglazier
greenglazier's Reviews
09-10-2010, 04:33 PM
Price: $65.00
Pros: must have
Cons: none
Recommended? Yes
Comments: excelent quality
cbossio
cbossio's Reviews
08-09-2010, 04:25 AM
Price: $75.00
Pros: Made in the USA
Cons: Causes headaches if handle is not locked
Recommended? Yes
Comments: Every jeep needs this. Classic trail tool with a million uses. Avoid buying cheep Chinese knockoffs. There are many. Some of which are under familiar names. Stick with a classic High-lift made in Indiana.
jebnmikki
jebnmikki's Reviews
07-27-2010, 04:49 AM
Price: $40.00
Pros: nice for a lifted rig
Cons: hard to work with sometimes after sitting. knuckle buster.
Recommended? Yes
Comments: a nice tool to have on the trail
trlblznjeeper33
trlblznjeeper33's Reviews
07-17-2010, 10:06 PM
Price: $60.00
Pros: great lifting power, very user friendly
Cons: Keep an eye on the nuts that hold it together, and make sure to lube it
Recommended? Yes
Comments: I started out using my hi-lift and a come-along before i invested in my winch, and still use it in conjunction with my winch whenever i have to pull in 2 directions. If you don't keep an eye on the nuts that hold it together they will loosen up and "disappear" on you, making it next to impossible to know whats going to happen when jacking. Also make sure to keep a can of white lithium grease or silicone spray in the jeep to lube the lifting mechinisim one end or the other on the ground. And don't try to jack the entire front end or rear end, it gets a little tippy if you only have If those are the only three downsides, why not get it.
DaFuzz80
DaFuzz80's Reviews
07-16-2010, 04:31 PM
Price: $69.99
Pros: Lifts, winches, clamps, breaks beads, well built
Cons: Heavy
Recommended? Yes
Comments: This jack is great, not really to be used as a jack much. Lifts, winches, clamps, breaks beads, very well built! Great all purpose jack to be used as a multi tool.
luckychris
luckychris's Reviews
06-24-2010, 04:57 PM
Price: $75.00
Pros: It's great!
Cons: none
Recommended? Yes
Comments: So the thing about the Hi-Lift jack is, it's not just for liftin' yer Jeep! I have used it for just about eveything. I cannot think of a single reason to not own a Hi-Lift jack, case closed.
tater_kamik
tater_kamik's Reviews
06-22-2010, 02:50 PM
Price: $80.00
Pros: useful
Cons: sometimes does not want to switch back to raise
Recommended? Yes
Comments: It lifts, it pulls, its tall, its sturdy. If you wheel, you need one. Just dont be stupid using it (as with any jack).
ROADDOG516
ROADDOG516's Reviews
06-18-2010, 12:34 AM
Price: $84.00
Pros: heavy duty
Cons: expensive
Recommended? Yes
Comments: what can i say got one cause they are top notch
BubbaArmy
BubbaArmy's Reviews
04-25-2010, 09:00 AM
Price: $79.99
Pros: Easy to use, must have
Cons: Placement
Recommended? Yes
Comments: Does the job and more.
submrnman
submrnman's Reviews
03-15-2010, 06:25 AM
Price: $79.99
Pros: It's 7,000 lbs of pull and lift for $79.99.
Cons: Hard to find a good looking and convenient place to mount it.
Recommended? Yes
Comments:
There is not much to say here. It's a Hi-Lift...
JerseyWJ
JerseyWJ's Reviews
03-07-2010, 08:25 AM
Price: $48.00
Pros: Great tool
Cons: Storage in vehicle
Recommended? Yes
Comments: Can be used for a jack, lift, winch, whatever. Excellent tool.
ThreadForumRepliesLast Post
Hi Lift Extreme 48" Winches 14 02-26-2011 01:59 AM
Hi-Lift 60" All - Cast Jack Winches 7 07-08-2009 06:49 PM
Glock Forum
