Harbor Frieght 10,000 winch
Rating: |
Product Information
| MSRP: |
$429.00 |
| Average Price: |
$308.86 |
| Manufacturer: |
Harbor Frieght |
| Recommended? |
Ring611's Reviews
Price: $450.00 Pros: great strength great price Cons: slow Recommended? Yes
Comments: Winch works great. 10k lbs winch for under 500$ is a great buy. it is a little slow but if your stuck speed is not a nesecity. love the winch would def. buy more for other rigs
noise_maker's Reviews
10-21-2011, 10:41 PM |
Price: $25.00 Pros: Strong, low amp draw and durable Cons: slow and needs to be covered to keep the clutch working well Recommended? Yes
Comments: Very durable winch with lots of power and is easy on the electrical system because of its low amp draw. Got mine used from ebay for 25+75 Shipping. Works great just need a bit more patients then the guys with $800 warns and optima batteries.
A good quality, cheep winch that will get the self recovery job done well.
xwildman138x's Reviews
Price: $499.99 Pros: Very strong Cons: None yet, can't beat the price Recommended? Yes
Comments: I've used this winch to straighten a frame on a f150, and extract a very stuck Libby. The winch never hesitates, or heats up. When I bought the winch I waited for it to go on sale and found a 20 percent off coupon. Wait for the sales at harbor freight, totally worth the wait. Only thing I did not use that came with the winch was the rolling fairlead. My friend made me a fairlead that I incorporated into my bumper build. Excellent product.
lopezzi's Reviews
Price: $250.00 Pros: Great price for a 10k lbs winch. It also included a roller fairlead which the lower capacity's don't. Cons: None yet. Recommended? Yes
Comments: I bought this winch because I got a great deal on it. Harbor Freight was running a special on it, plus I had the 20% off coupon which brought the price down under $300. I couldn't pass that up on a 10,000 lbs winch. Plus as I stated, this winch comes with a roller fairlead which the lower capacity HF winches don't. So for all that for under $300 it was a no brainer. I wanted a Warn winch, but since I don't do any really heavy off-roading I figured I could save some money and still have a higher rated lbs winch. I've read reviews on the harbor freight winches and people seem to like them and they get the job done. For an average off-roader like me, it fit the bill.
AWheeler's Reviews
Price: $300.00 Pros: Great product Cons: Could be faster Recommended? Yes
Comments: Great winch.
deadbiker's Reviews
10-18-2010, 11:22 AM |
Price: $299.00 Pros: cheap, easy to install, simple to use Cons: plastic engage lever Recommended? Yes
Comments: Slow but works well.If it gets you out once, its worth the $.Great for the occasional off roader...
skinton's Reviews
Price: $239.99 Pros: price Cons: none yet Recommended? Yes
Comments: Only had it on a month. I used it twice on my last trip. One long double pull though a mud hole with deep ruts. I had all 4 tires in the air at one point (high centered on a mount in the middle of the pit). The other was winching a CJ-7 down a hill climb after he stalled out near the top. Worth the $$$
DaFuzz80's Reviews
Price: $245.00 Pros: Heavy duty and well built Cons: Slow, plastic engage lever Recommended? Yes
Comments: This winch is great, it pulled me out of a deep bog last night, mud to my door handles. It woulda been 300-400 for a wrecker to come save me at midnight so the winch paid for itself the first time i used it. Awesome winch other than that it's a little slow. Who cares when you're really stuck though, speed means nothing when you're miles from the closest road and you have no communications working.
xkuzme1's Reviews
Price: $325.00 Pros: I like it, it looks good, works good, and keeps me out of trouble. Cons: It is made in china. But, most stuff is. Recommended? Yes
Comments: I have not put it through a true test yet, but it appears to be a stout machine with plenty of torque and well built.
11-28-2009, 05:51 PM |
Price: $100.00 Pros: Works great. It stays cool an pulls hard - even on long pulls. Low amp draw Cons: the plastic engager can get stuck in the engaged position if you don't take measures (winch cover) to keep the mud and sand out of it. Recommended? Yes
Comments: I bought my used from ebay ($100 shipped) This thing has saved my bacon more times then I can count and got several others free as well.
With any decent 1000 amp battery the winch won't kill it even on long pulls as long as the jeep is running.
Some say its slow but I don't think it is - you gotta figure by the time your winching your not going anywhere with out it so it dosn't seem bad.
The only thing that I have had get weird on me is the plastic engager. It got stuck once - when I had covered the front with mud and I couldn't get it to free spool. A couple squirts of silicon spray and I was back in business. I bough a canvas cover and the problem has not re-occurred.
k2krazy's Reviews
Price: $400.00 Pros: havent broke it yet Cons: plastic engager Recommended? Yes
Comments: my friend uses it on his car trailer he goes to auction and uses it atleaast once or twice a week and its always outside so
ClimbStuff's Reviews
Price: $343.00 Pros: 10k lbs, includes remote, 100' 3/8" cable, roller fairlead and mount plate. Very nicely packaged. 8.8 hardware. Cons: Noisy, mount plate needs modification to fit, slow line speed, fairlead bolt heads very thin Recommended? Yes
Comments: The worst thing about this winch is mounting the plate. Your two best friends are a set of Ridged Drill bits, and a round bastard file. After that its a breeze. You do need to mount the winch on the plate BEFORE you mount it to the bumper. The rear winch mounting bolts are not accessible once the plate is fixed to the chassis. The instructions threw me off a bit when it stated, "Connect the Solenoid Output Power Lines (short-black)(17s,24s) to either terminal of the Electric Winch." If you hook the front cable to the rear post, and vice versa, pushing up on the remote will wind it up, pushing down will unspool it.
There is a sticker on the remote saying "Do not operate for more than 1 minute at a time. Allow 3 minutes of cooling time for each minute of pulling.
When I let out all the cable and re spooled it under a light load, I pulled all 95' in one pull and it was only warm to the touch.
repeej2002's Reviews
Price: $350.00 Pros: ultra reliable Cons: slow line speed Recommended? Yes
Comments: I've had this winch for a while now and have pulled just about everything from fullsized trucks to trees and even a johndeere 5410 that was stuck in the mud this thing may be slow but it doesnt quit and the amp draw is low enough that i dont worry so much about killing my battery. Im not gonna say if your on a budget buy this winch because i've had a replacement for over two years and for some reason my "better" winch is still sitting in the garage
bob6987's Reviews
Price: $400.00 Pros: works great Cons: slow...but i am stuck so i am not going any where Recommended? Yes
Comments: I got the winch and a 2 year warranty for 400...cant beat the price and it has worked grat for me.
bigman7878's Reviews
03-27-2009, 11:31 PM |
Price: $50.00 Recommended? Yes
Comments: Great winch. Will get you out when you need it to with no problem. Only problem is its painfully slow.............................................. .....
justooln2's Reviews
03-10-2009, 06:08 PM |
Price: $350.00 Recommended? No
Comments: Dont waste your time with this Winch, unless you dont mind working on it regularly. It has gotten me out of a bad mess 6 out of 6 times though.
oldskoolgouv's Reviews
12-07-2008, 11:09 AM |
Price: $400.00 Recommended? Yes
Comments: not a bad winch for the money and occasional user just be careful of the cable thats the only problem ive had with mine
TJ-n-triumph's Reviews
11-17-2008, 11:16 PM |
Pros: goin and goin and goin Cons: slow slow slow Recommended? Yes
Comments: pulled out some full size burbans and some zuks, never let me down
Max_Power's Reviews
08-20-2008, 02:57 PM |
Price: $429.00 Recommended? Yes
Comments: slow as hell, but has never faied. Used it 30 - 40 times by now.
And 2 year unconditional guarantee.
NalinMFG's Reviews
07-02-2008, 03:16 PM |
Comments: Never had a problem with it. Ive had to use it quite a few times. Would recomend it, however next time i would like to get a nicer winch just to be on the safe side.
