Go Back JeepForum.com > Reviews > Recovery > Winches > Harbor Freight 8000 LB Winch
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineSALE PRICING, Specials, Huge Savings Alloy USA and Posi-LoGR8TOPS Introduces the Exogate HD Tire Carrier
Harbor Freight 8000 LB Winch Reviews, Ratings, Specs & Prices
Review Categories
Armor
  Bumpers
  Differential Guards
  Rocker Guards
  Roll Cages
  Skid Plates
Audio, CB, & Electrical
  Audio Players
  Batteries
  CB & HAM Radios
  GPS
  Speakers
Axles
  Axle Shafts
  Brakes
  Gears
  Hubs
  Lockers
  Steering
Body
  Body Lifts
  Consoles, Security & Storage
  Exterior Accessories
  Fender Flares
  Lighting, Lenses & Bulbs
  Roof Racks & Cargo Areas
  Tops
Engine
  Alternators
  Carburetors
  Chips
  Exhaust
  Headers
  Induction
  Internal Parts
  Motor Mounts
  Starters
  Throttle Body
Interior
  Gauges
  Misc
  Seats
Recovery
  Winch Cable and Hooks
  Winches
Suspension
  Complete Lift Kits
  Control Arms
  Shocks
  Springs
  Steering Stabilizers
  Track Bars
Tires & Wheels
  Tires
  Wheels
Transfer Case
  SYE Kits
  Transfer Cases
Transmissions
  Transmissions
Previous Product Winches Next Product
Rating:
Product Information
MSRP: $650.00
Average Price: $275.21
Manufacturer: Harbor Freight
Recommended?
Yes: 49 / No: 1
Chicago Electric Tools (ITEM 40764-3VGA)
8000 LB. ELECTRIC WINCH WITH AUTOMATIC BRAKE
1.8 HORSEPOWER
Planetary gearing for fast line speed and sure hold. Freespooling. Three-stage system with automatic load-holding brake.
*Power in, power out
*Remote hand control switch with 12 ft. cord
*Fairlead: 11-3/4''L x 3-5/16''W x 1'' deep
*Line speed (in feet per minute): 13 (no load), 11 (2000 lbs.), 6 (6000 lbs.), 4.5 (8000 lbs.)
12 volts, 1.8 HP, 37.5 amp draw; Drum diameter: 2.5''; Gear ratio: 210:1; Cable: 5/16’’ x 95 ft.; Overall dimensions: 20-11/16''L x 3-1/8''W x 6-15/16''H; Bolt pattern: 10’’ x 4.5’’; Shipping weight: 106 lbs.
WINCH MOUNT FOR JEEP (ITEM 3444-0VGA)
Page 1 of 3 1 2 3 > Last »
tjthorson
tjthorson's Reviews
01-16-2012, 07:14 PM
Price: $249.00
Pros: Works great, never let me down, lasts about 5 years, relatively low current drain
Cons: after 5 years magnets eventually crumble around motor, slow compared to the big boys.
Recommended? Yes
Comments: While a warn may last longer - with my winches exposed to chicago heat and winter salt, 5 years out of a sub $250 winch is good enough for me. Even when my last one gave up the ghost, it still worked well enough on the last pull, but I heard it making noise as the magnets crumbled and stuck to the armature. I promptly went out and bought another! Its slow - but it always works.
timmyjx209
Junior Member
timmyjx209's Reviews
10-10-2011, 04:17 PM
Price: $80.00
Pros: will pull the TJ out of any situation
Cons: winch is slow @ pulling
Recommended? Yes
Comments: bought used off ebay very good product will pull the TJ out of anything the only complaint i have about it is it is very very slow when pulling the jeep but powerful enough to get it out of anything i would recommend this for a powerful winch on a budget
neelaviat
neelaviat's Reviews
05-17-2011, 05:15 AM
Price: $289.00
Pros: Excellent boat anchor. Very good cardboard box it was packed in, reusable for something.
Cons: both winches brought about $12.00 at the scrap yard.
Recommended? No
Comments: Worked once, and failed when I needed it so desperately. The electric solenoids in the control box shorted.
I also had a second one of the same brand mounted on my equipment trailer. Used about 4 times, when the gearbox inside came apart, under no load. Bought a Warn, used it 6 times in one day, still works fine. Check out overstock.com, or ebay and see how many of these used winches are for sale. Make note of the cable hand wrapped around the winch, indicating it quit.
These China made winches are rated at pulling "rolling" capacity, not actual dead weight. if you're serious about having equipment you can depend on, then by a Warn or Ramsey.
jcook793
Hi Mom
jcook793's Reviews
02-05-2011, 10:49 PM
Price: $250.00
Pros: Cheap
Cons: It'll burn up one day
Recommended? Yes
Comments: I had a 9.5K Harbor Freight winch that lasted several years (8 I think). I burned it up pulling shrubs out of the landscaping . Was gonna get a Warn this time around but they had a sale for $250 and I'm a sucker for a cheap price.
xlTravislx
Beep Beep Im In a Jeep
xlTravislx's Reviews
12-09-2010, 08:01 AM
Price: $50.00
Pros: everything
Cons: nothing
Recommended? Yes
Comments: its small but gets the job done.
93ZJ_5.2_ca
93ZJ_5.2_ca's Reviews
11-23-2010, 05:00 PM
Price: $100.00
Pros: Great for what it does
Cons: None
Recommended? Yes
Comments: Great winch for the price, parts are available and cheap if needed. I could rebuild this this 3 times and still save money over a brand name winch.
kittyhawk
kittyhawk's Reviews
08-30-2010, 04:38 PM
Price: $240.00
Pros: Great Price Great Warrenty
Cons: Slow
Recommended? Yes
Comments: Got the 8000# one a month after I got the Jeep, have used the Snot out of it and had Zero problems.
akordboy
Junior Member
akordboy's Reviews
05-07-2010, 10:45 AM
Price: $1.00
Pros:
Cons:
Recommended? Yes
Comments:
crazymon01
crazymon01's Reviews
01-14-2009, 08:32 PM
Price: $299.00
Recommended? Yes
Comments: it works great. it has gotten me out all times except one when i somehow exploded the gear box in it... ops
justinsalv
justinsalv's Reviews
01-04-2009, 01:09 AM
Price: $300.00
Recommended? Yes
Comments: this winch is probley the best price winch out there the only bad thing about it is it kind of slow
scottman
scottman's Reviews
12-13-2008, 09:01 AM
Price: $300.00
Recommended? Yes
Comments: Have had it for a few years, pulls every time I need it. Great buy for the price, and included shipping.
87yj_jeep
87yj_jeep's Reviews
10-07-2008, 01:07 PM
Price: $260.00
Recommended? Yes
Comments: Works Great, Haven't used it a lot but works good everytime I need it. Would definately recommend for the price i paid.
CJ5_Fan
CJ5_Fan's Reviews
08-04-2008, 10:34 AM
Price: $299.00
Recommended? Yes
Comments: Has worked for me every time I needed it to..... For the price, it was a good option for a light duty need
jpapa
Junior Member
jpapa's Reviews
06-24-2008, 07:32 AM
Price: $299.00
Recommended? Yes
Comments: It is an import, it is ugly, it is slow, but it works. It also acts as a cheap bumper reinforcement - saved me front end damage and did a number on a Liberty liftgate.
Alabamaranger
Alabamaranger's Reviews
06-16-2008, 02:04 PM
Price: $130.00
Recommended? Yes
Comments: Better than nothing. Bought it used for $130.00 and I would buy another one.
Mut
Mut's Reviews
06-15-2008, 11:12 AM
Price: $307.00
Recommended? Yes
Comments: Slow but very reliable.. Looks good for the price I would reccomend to everyone..
cracker1868
cracker1868's Reviews
06-09-2008, 07:46 PM
Price: $270.00
Recommended? Yes
Comments: Brand new, still haven't had a chance to use it.Brand new, still haven't had a chance to use it.Brand new, still haven't had a chance to use it.
Fryguy
Fryguy's Reviews
05-17-2008, 09:36 AM
Price: $500.00
Recommended? Yes
Comments: it alright but it could have a faster line retrieval......................................... .................................................. ............
Cannon
Cannon's Reviews
05-14-2008, 12:19 PM
Price: $249.00
Recommended? Yes
Comments: Works well. First civillian winch owned. Use to gripe trees with a block to fall in right direction when felling. Haven't had to use yet out on the shoreline.
Bought the HF aftermarket plate, works to attach to stock bumper, but an aftermarket bumper may need some fab-work to ensure on safe.
Low price since had a 2006 $50 off coupon. HF does from time to time.
JeepnAZ
JeepnAZ's Reviews
04-29-2008, 10:47 PM
Price: $250.00
Recommended? Yes
Comments: I have the 9,000 lb and bought it on Craig's List new still in the box. I have used it to recover a friends jeep and it worked fine.
ThreadForumRepliesLast Post
Harbor Frieght 10,000 winch Winches 15 10-18-2010 11:22 AM
Warn M-8000 Winches 14 02-05-2010 01:04 AM
Harbor Freight 9000lb Winch Winches 7 10-17-2009 03:36 PM
Vortex 8000 Winches 2 07-31-2009 10:10 PM
Harbor Freight 9000lb Winches 3 07-29-2009 09:21 AM
Glock Forum
