Go Back JeepForum.com > Reviews > Recovery > Winches > Gorilla 10,0000 LB RTecovery Winch
TJ 5.25" Speaker Adapters - NalinMFGTruck-Lite's New LED Headlamp Series4.25" 97-06 Jeep TJ Wrangler Lift Kit - NO SYE Needed
Gorilla 10,0000 LB RTecovery Winch Reviews, Ratings, Specs & Prices
Review Categories
Armor
  Bumpers
  Differential Guards
  Rocker Guards
  Roll Cages
  Skid Plates
Audio, CB, & Electrical
  Audio Players
  Batteries
  CB & HAM Radios
  GPS
  Speakers
Axles
  Axle Shafts
  Brakes
  Gears
  Hubs
  Lockers
  Steering
Body
  Body Lifts
  Consoles, Security & Storage
  Exterior Accessories
  Fender Flares
  Lighting, Lenses & Bulbs
  Roof Racks & Cargo Areas
  Tops
Engine
  Alternators
  Carburetors
  Chips
  Exhaust
  Headers
  Induction
  Internal Parts
  Motor Mounts
  Starters
  Throttle Body
Interior
  Gauges
  Misc
  Seats
Recovery
  Winch Cable and Hooks
  Winches
Suspension
  Complete Lift Kits
  Control Arms
  Shocks
  Springs
  Steering Stabilizers
  Track Bars
Tires & Wheels
  Tires
  Wheels
Transfer Case
  SYE Kits
  Transfer Cases
Transmissions
  Transmissions
Previous Product Winches Next Product
Rating:
Product Information
MSRP: $359.98
Average Price: $316.20
Manufacturer: Gorilla
Recommended?
Yes: 5 / No: 0
LD10000
Performance 12VDC
Single line rated pull 10000lb(4532kg)
Motor 5.8hp/4.0kw,Series Wound
Control Remote switch,12ft(3.7m)lead
Gear train 3 Stage Planetary
Gear reduction ratio 265.2:1
Clutch Sliding Ring Gear
Braking Action Automatic In-The-Drum
Drum size Drum size Diameter2.52"(63.5mm) Length 8.82"(224mm)
Cable 87ft of 9/25" diameter
Fairlead 4-Way Roller Fairlead
Wireless Remote Control Included
Battery Recommended:650CCA minimum for winching
Battery Leads 2 gauge,72"(1.83m)
Weight N.W.88lbs(41kg) G.W. 95lbs(45.5kg)
Overall dimentions (L×W×H)21.3"×6.3"×8.6"(552×160×218mm)
Mounting Bolt Pattern 10.00±0.015"×4.50±0.010"(254×114.3mm)
Pull, Speed, Amperes, Volts (First Layer)
Line Pull (lbs./ kg) Line Speed FPM Motor (Amps)
2000 14.9 120
4000 11.1 180
6000 8.8 250
8000 7 310
10000 5.9 380
Line Pull And Rope Capacity In Layer
Layer Rated Line Pull (lbs./kgs) Total Rope On Drum (ft/m )
1 10000 16
2 7964 42
3 6591 72
4 5632 87
Shipping Carton Information: 95lbs
TCL2002TJ
TCL2002TJ's Reviews
11-15-2010, 03:49 PM
Price: $469.00
Pros: water proof, and has a built in wireless remote.
Cons: made some noise once pulling myself out but still works without any problems
Recommended? Yes
Comments: The line speed on this winch is just better than glacial but it pulls strong. It made a noise once pulling myself out of some mud but it continues to perform as expected and the built in wireless has worked flawlessly. For a third of the price of a Warn, it's hard to argue with. The company that sells them now is ProMark.
NickJr44
NickJr44's Reviews
09-16-2009, 04:33 PM
Price: $499.00
Pros: waterproof model, silver, looks good, functions well, strong, takes a beating no problem
Cons: kinda loud for a winch, but that can be overlooked when it's pulling you out of a mud pit
Recommended? Yes
Comments: I had to do some custom work to make this fit inside of my ARB bullbar, but it working great anyways. This winch is relatively slow, and has a somewhat louder tone than most other winches. What it really comes down to is, when this thing is pulling your Jeep out of a mud pit, and the winch is underwater and continues to keep on pulling, and you spend about half the money on this winch as others out there, you say to yourself... this was worth it.
kieth
kieth's Reviews
07-31-2008, 10:53 AM
Price: $3.00
Recommended? Yes
Comments: test test test test test test test test test test test test test test test test test test test test test test test test test test test test test test test test test test test test test test test test test test test test test test test test test test test test test test test test test test test test test test test test test test test test test test test test test test test test test test test test
Russ_93YJ
Russ_93YJ's Reviews
07-21-2008, 11:16 PM
Price: $359.98
Recommended? Yes
Comments: Price is right and hasn't faided me yet! Easy to install and came simple instructions. I wish it had a more room for the spool but nothing a synthetic line can't fix.
ThreadForumRepliesLast Post
SmittyBilt XRC 8 Winch Winches 209 11-12-2011 06:01 PM
Gorilla 12,000lb Winch Winches 3 01-19-2010 08:02 AM
Gorilla Winch 12,000lb Winches 5 05-16-2009 12:29 PM
Gorilla 20,000 Winches 0 01-22-2009 11:27 PM
Bulldog Winch 12k Winches 1 04-12-2008 12:39 PM
Glock Forum
