Yj ignition coil - JeepForum.com
post #1 of 2 Old 07-29-2013, 05:26 PM Thread Starter
1990yjoffroad
Yj ignition coil
My 1990 wrangler 4.2L 6 cyl is having a problem with the ignition coil. Even when the car is off there is still power to the ignition coil. and when I start the jeep it wont shut off. I just replace the ignition switch in it. The only way to stop the power to it is to disconnect the battery. Any ideas of what it is.
1990yjoffroad is offline
post #2 of 2 Old 08-01-2013, 08:52 AM
crazymon01
crazymon01's Avatar
Sound like a short... trace your hot wire back towards the ignition best you can and see if you can find burn marks...that's first thing I would check
4.0
I6
ARB snorkle
307 -> 411 gear swap
lock rite locker on the dana 35
33 x 12.50 Mickey Thompson radial MTZ
4.5" Rubicon Express heavy duty Suspension Lift
currie boomerang shackles
8,000 lbs. Winch
bikini top
tonneau cover
pictures??
crazymon01 is offline
