YJ Front Speaker Replacement - 5.25"??? - JeepForum.com
post #1 of 6 Old 04-28-2008, 10:02 AM Thread Starter
BrooklynBridger
Yj YJ Front Speaker Replacement - 5.25"???
I am replacing my blown front factory 4x6 with 5.25". However, it seems there are the mounting bolts behind the dash are too close together to get the 5.25" speaker behind there. Yet, many posts have indicated it is possible. Did they have to cut the bolts or something? Does anyone have bolt diagram so I can figure out how to bolt this speaker in there? (Maybe I'll need to make a bracket or something...)
Thanks.
Mark
BrooklynBridger is offline
post #2 of 6 Old 04-28-2008, 10:12 AM
rustywrangler
Got my eye on you.....
rustywrangler's Avatar
You need a set of speekers that have the built in bracket or multi mount fins.
Congenital Heart Disease is a reality for me, BOTH of my children have it. Please read up and become aware for future generations
Lydia Ann-Acquired 08/05/05 Open Heart surgery 08/10/05
Jacob Patrick-Acquired 01/17/08 Open Heart surgery 02/15/08
rustywrangler is offline
post #3 of 6 Old 04-28-2008, 10:21 AM
SirGCal
SirGCal's Avatar
In a TJ, yes this is possible. In a YJ it also is but the installation is far more complex. Every YJ I've done i've pulled the dash and done a full custom setup for them. Not as simple as the drop-in bracket swap for a TJ.
My MS/Life blog, Audio and Electronic write-ups, project how-tos, pictures, stories, and more.
Originally Posted by SirGCal
If you can't take a nano-second to press shift/period/etc. and make proper sentences and paragraphs, I don't know if I can take a few minutes to respond to your topics... It doesn't have to be perfect by any means, but a little effort goes a long way.
SirGCal is offline
post #4 of 6 Old 04-28-2008, 11:19 AM Thread Starter
BrooklynBridger
I also have a decent set of 4" rounds. Will those fit in easier? Is there a straightup bracket for those?
Mark
post #5 of 6 Old 04-28-2008, 02:54 PM
gily25
Try to find one of these cheap; had one in my YJ and it was like nite and day over the dash locations:
http://www.quadratec.com/products/14136_03.htm
gily25 is offline
post #6 of 6 Old 04-28-2008, 03:09 PM
SirGCal
SirGCal's Avatar
The center option is one of the worst positions for good sound. Far more beneficial if you are going to use a non-stock location, and a mod I do a lot for YJ fronts, are the kick panels. A little more stealthy also actually cause the tub hides them slightly unlike the center which is right where every thief's eyes are going first. But even around here, never had a problem with them getting ripped out. Plus you'll have proper sound coming from the proper side. I never recommend the center lower or upper pod systems.
http://www.quadratec.com/products/14136_01.htm
SirGCal is offline
7 speaker package front speaker replacement J03_TJ Audio, CB & Ham Radios, GPS, & Electrical 12 05-08-2014 07:59 PM
Front YJ Speaker replacement bluebellyday Audio, CB & Ham Radios, GPS, & Electrical 24 12-23-2012 08:14 AM
5.25" front speaker conversion and very bad bass response NorthernRebel Audio, CB & Ham Radios, GPS, & Electrical 18 03-01-2009 04:01 PM
Front speaker replacement jeepguy2005 Audio, CB & Ham Radios, GPS, & Electrical 9 04-06-2005 07:43 AM
4"x6" Speaker Replacement MCanavan Audio, CB & Ham Radios, GPS, & Electrical 44 03-26-2005 06:06 PM
