Quantcast wiring/relay/power help - JeepForum.com
Go Back JeepForum.com > General Technical Discussions > Electrical, Audio, GPS, & 2-Way Radio > wiring/relay/power help
Old 01-04-2009, 01:10 AM   #1
Vassago
The Bike Guru
Vassago's Avatar
ok here's what i want to do. i'm in the process of an auxiliary reverse light, i would like a switch to turn in on as i please, and be able to just have it come on when i pop it in reverse. but is it possible that i can wire it so it doesn't always coem on in reverse? i would really only like that function off road, the thing is goign to be bright, and i dont want to blind innocent bystanders in the mall parking lots.
my idea was pretty simple, seems like it would work. i plan on doing a lot of wiring this winter, front aux. light, this rear light, rock lights, on board air, sub/amp, underhood work lights. so i was thinking of making a swtich box with a master power switch for my accessories. so i can cut power completely and not have a draining battery. how the heck do i start wiring this? i think i want to do all my wiring at once and hook up lights and accessories as i get them. so i'd be making on hugs after market wiring harness.
"He almost broke the land speed record in 1977, popular opinion amongst his team was that his beard caused to much wind resistance. He would have shaved it… No, no he wouldn’t have."
MY BUILD THREAD: http://www.jeepforum.com/forum/f22/build-thread-year-later-01-xj-643365/
My Photography Paul Lehr's Flickr
Vassago is offline   Reply With Quote
Old 01-04-2009, 01:45 AM   #2
SnowdogMarc
I'd have the main power feed to your panel controlled by a relay connected to the IGN. This way nothing can be left on unless it's running. Make sure you use a relay and wire size big enough to handle the load of all your Acc, or maybe have a relay controlling a solenoid that can handle a much higher load. For your aux backup lights...simply have a relay that is tripped when you shift into reverse and have the output go to a switch then the lights. This way the lights will only come on in reverse but only if the switch is turned on.
We're here for a good time. Not a long time. So have a good time the sun can't shine every day.
l_______
/l ,[_____],
l---L -[]lllllll[]-
()_) ()_)--o-)_)____________VE6-SDG
SnowdogMarc is offline   Reply With Quote
Old 01-04-2009, 02:22 AM   #3
Vassago
The Bike Guru
Vassago's Avatar
what kind of relay should i be looking for? i'm sort of an idiot with this stuff, but i want to learn. and i want to be able to turn on the reverse light not only in reverse, like if i'm parked at a campsite and need some major light
MY BUILD THREAD: http://www.jeepforum.com/forum/showthread.php?t=643365
Old 01-04-2009, 10:47 AM   #4
Slithering_Joe
Originally Posted by BMXxXJ View Post
ok here's what i want to do. i'm in the process of an auxiliary reverse light, i would like a switch to turn in on as i please, and be able to just have it come on when i pop it in reverse. but is it possible that i can wire it so it doesn't always coem on in reverse? i would really only like that function off road, the thing is goign to be bright, and i dont want to blind innocent bystanders in the mall parking lots...
This circuit will enable your reverse lights to operate under the following conditions:
Switch Position a: Aux-Reverse lights on when gear selector shifted in reverse
Switch Position b: Aux-Reverse lights disabled completely
Switch Position c: Aux-Reverse lights on manually, independent of ignition key, independent of gear in reverse
(Double Pole Double Throw (DPDT) ON-OFF-ON illuminated Contura switch used above.)
You can also use a Single Pole Double Throw (SPDT) ON-OFF-ON switch.
Switch types below:
ISO/"Bosch" Relays:
Do a search as I have written about this for other people in the past.
4.0L TJ 5.7L CTS 3.7L KJ
Slithering_Joe is offline   Reply With Quote
Old 01-04-2009, 11:12 AM   #5
Vassago
The Bike Guru
Vassago's Avatar
thanks slithering joe! thats just what i needed! i tried a search but i did find anything useful, thanks for posting again!
Old 01-04-2009, 11:14 AM   #6
bentbars
1978 CJ5
thats what I was thinking. or just master switch the reverse light only. so if you want to use it, a toggle or whatever on the dash or wherever must be flipped before the reverse action lights it up.
bentbars is offline   Reply With Quote
Old 01-04-2009, 11:26 AM   #7
Slithering_Joe
You can wire it this way but it won't perform all the functions specified by BMXxXJ .
Old 01-04-2009, 12:53 PM   #8
Vassago
The Bike Guru
Vassago's Avatar
where's the bext place to get this stuff? radio shack?
Old 01-05-2009, 04:51 PM   #9
Slithering_Joe
I've purchased from RallyLights.com in PA and OTRATTW.com in CA. Many others here have mentioned other good venders too.
Old 01-05-2009, 06:22 PM   #10
Vassago
The Bike Guru
Vassago's Avatar
thanks again joe! where in north jersey are ya? i'm central, manasquan to be exact
Old 01-06-2009, 11:50 AM   #11
Slithering_Joe
PM sent.
Glock Forum
