Wiring Question - Foglights - JeepForum.com
post #1 of 16 Old 12-22-2008, 05:49 PM Thread Starter
Motorcharge
Right now my XJs got 2 wally world foglights mounted on the roof rack.
I bought 2 more today, could I mount the 2 new ones and wire them to the existing wiring or would I have to just wire the new ones to a 2nd switch and everything?
Top is current wiring, bottom is what I'm thinking:
|SOLD|
| June 2015 COTM |
Motorcharge is offline
post #2 of 16 Old 12-22-2008, 06:24 PM
CJ7-Tim
Real Jeeps have dents
CJ7-Tim's Avatar
Use a relay and a fuse unless you have a really fast local fire department. See the link below. You can use 2 relays, one per pair of lights. If you can find a big enough relay and fuse, one might be enough.
http://www.classictruckshop.com/club...h/foglites.htm
CJ7-Tim is offline
post #3 of 16 Old 12-22-2008, 07:43 PM
C2U5H
C2U5H's Avatar
just make sure you're using 12ga wire and a good relay
should be fine
2012 Crush JK Rubicon on 2.5" and 37s
- see sidebar
C2U5H is offline
post #4 of 16 Old 12-22-2008, 09:24 PM
chris87xj
JF Admin
chris87xj's Avatar
1987 XJ Cherokee
RVA, there's a pretty good write-up with a nice pic here: http://www.jeepforum.com/forum/f20/wire-fuse-size-relay-explanations-378268/
To give you an idea how much current you're going to be dealing with, a 55 watt lamp draws 4.6 amps and a 100 watter needs 8.3, so 4 - 55's need almost 20A and 4 -100's need close to 35A.
***Chris***
chris87xj is online now
post #5 of 16 Old 12-23-2008, 07:25 AM
Scrambler82
Scrambler82's Avatar
1982 CJ8
As chris87xj stated find out the wattage of the Lights and you can determine the full current needed to operate them safely. Once you know the total current you can buy the correct relays, the correct wire size and fuses.
Always use a fuse next to the battery, always oversize the wire for safety reasons and as I like to do always run your ground wires back to the battery.
Two lights per relay is standard practice, you can operate the two relays with one switch if you want and you can get a large enough relay you can hook up al of the lights together; but when on the road/trail and the relay fails you lose all of your lights...
Find out the Wattage of the existing lamps and the new ones you want to hook up, then you can determine the correct size of all of the components.
Ltr,
Merry Christmas
Scrambler82
Do it right the first time !
Scrambler82 is offline
post #6 of 16 Old 12-23-2008, 08:20 AM
chris87xj
JF Admin
chris87xj's Avatar
1987 XJ Cherokee
Ltr,
Merry Christmas
fixed it for ya
***Chris***
post #7 of 16 Old 12-23-2008, 08:51 AM
rustywrangler
Got my eye on you.....
rustywrangler's Avatar
Those are the walmart special baja offroad lights. 55W each.
Congenital Heart Disease is a reality for me, BOTH of my children have it. Please read up and become aware for future generations
Lydia Ann-Acquired 08/05/05 Open Heart surgery 08/10/05
Jacob Patrick-Acquired 01/17/08 Open Heart surgery 02/15/08
rustywrangler is offline
post #8 of 16 Old 12-23-2008, 08:52 AM
rustywrangler
Originally Posted by chris87xj View Post
fixed it for ya
So did I
post #9 of 16 Old 12-23-2008, 08:57 AM
chris87xj
JF Admin
chris87xj's Avatar
1987 XJ Cherokee
Originally Posted by rustywrangler View Post
So did I
Hey no problem, it was kind of confusing there for a minute.
Question though while I've got your attention, what's with all the green highlighted advertisement links that appeared in the posts above? Is this something I've just not noticed before or did somebody get creative?
***Chris***
post #10 of 16 Old 12-23-2008, 09:17 AM
1993redjeepyj
just run two switchs, make your life easy. remember fuses! if you wanna i know my local advanced sells a little fuse lock. you run a 10 gadge wire to it, and it gives you six terrminals each with a 30 amp fuse, they make life very easy. i have 2 on my jeep for all my doo dads
1993redjeepyj is offline
post #11 of 16 Old 12-23-2008, 09:18 AM
rustywrangler
Very easy way to burn your jeep down man.
for that many lights, even at 55watts, he really should have relays.
post #12 of 16 Old 12-23-2008, 09:19 AM
rustywrangler
Send me a PM with a screen shot. I do not see the advertisements as a mod.
post #13 of 16 Old 12-23-2008, 10:15 AM
SirGCal
RIP
SirGCal's Avatar
Yup, just use a relay...
My MS/Life blog, Audio and Electronic write-ups, project how-tos, pictures, stories, and more.
Originally Posted by SirGCal
If you can't take a nano-second to press shift/period/etc. and make proper sentences and paragraphs, I don't know if I can take a few minutes to respond to your topics... It doesn't have to be perfect by any means, but a little effort goes a long way.
SirGCal is offline
post #14 of 16 Old 12-23-2008, 12:36 PM Thread Starter
Motorcharge
Yeah, they're the 55w walmart bajas.
Also, on the 2 I have hooked up there is a fuse on the red line, just forgot to stick it on the diagram.
|SOLD|
| June 2015 COTM |
post #15 of 16 Old 12-23-2008, 12:43 PM
rustywrangler
Did you use the wiring that came with the kit??? IF so, DO NOT add two more lights to that. Some of that wiring is only 16 gauge going to the lights The situation your in, regardless of what you have it wired with now is your going to overload the lines running all 4.
Wiring Gurus - A/C wiring question Giviner Audio, CB & Ham Radios, GPS, & Electrical 4 11-30-2009 08:08 PM
24v Foglights on 12v system D3f4ult Audio, CB & Ham Radios, GPS, & Electrical 4 08-22-2009 04:50 PM
new foglights REDPILL Audio, CB & Ham Radios, GPS, & Electrical 4 01-30-2007 08:18 PM
Anyone run rectangular foglights? got some ?'s for you. LoneJeeper General Jeep & Off-Road Equipment 13 03-26-2005 06:52 PM
foglights switch wiring wile_e_mopar Audio, CB & Ham Radios, GPS, & Electrical 4 05-25-2004 08:44 AM
