Wiring harness - JeepForum.com
post #1 of 10 Old 06-11-2013, 05:36 AM Thread Starter
stuartcoryvet
1975 CJ5
Wiring harness
So, I need a little help. I got me a killer deal on a CJ 5 75' few weeks ago. Need to install wiring harness which I have. Maybe someone can explain to me where to even start??
stuartcoryvet is offline
post #2 of 10 Old 06-11-2013, 07:12 PM
MyKeyB
That's something that's going to be difficult if not impossible to explain on a forum. Myself, I would start by tearing out the old wiring and replacing with new. If your not real comfortable with wiring or if you've never done anything like this it's going to be a project for sure. Good luck!
Rust never sleeps...
MyKeyB is offline
post #3 of 10 Old 06-12-2013, 08:49 PM
laybackman
Bikini Bridge Inspector
laybackman's Avatar
2010 JK Wrangler
I will assume that the old harness is not there.... This is a CJ so the wiring is fairly old school which means simpler than the newer Wranglers.
You did not mention which harness (engine? tub? dash?) In any event the length of the wiring usually tells you where the ends go. They don' make the wires longer than needed.
Do you know what was good about the good old days? I wasn't good, And I wasn't old!
Senators and Congressman should wear uniforms like NASCAR drivers so we could identify their corporate sponsors....
laybackman is offline
post #4 of 10 Old 06-13-2013, 08:23 AM Thread Starter
stuartcoryvet
1975 CJ5
Yes, the old harness is out and is the harness for the engine. Any know how to which to even began?
post #5 of 10 Old 06-13-2013, 12:15 PM
laybackman
laybackman's Avatar
2010 JK Wrangler
Go into your profile and fill it out please.
http://jeepspace.jeepforum.com/stuartcoryvet
That way we aren't guessing what you have for a jeep.
What engine/tranny? 1975 Is old as far as information online goes but you never know. I'll see what I can dig up but on the older Jeeps I have vey little from that era.
post #6 of 10 Old 06-13-2013, 12:30 PM
laybackman
laybackman's Avatar
2010 JK Wrangler
I have this for a 1978 CJ. They did not change much over those three years. Maybe this will help you;
post #7 of 10 Old 06-13-2013, 04:19 PM
CJ258
1974 CJ5
Get all your ducks in a row. When I did my '74 I rounded up a new ignition switch, did the headlight relay mod, went to a CS130 alternator and H4 headlights. My kit was color coded for Chevy. 14 circuit was too much, probably could have gotten away with 10.
CJ258 is offline
post #8 of 10 Old 06-17-2013, 07:45 AM Thread Starter
stuartcoryvet
1975 CJ5
Greatly appreciated laid back man. Ill upload a pic as soon as I can get to my laptop. My phone isn't allowing me to
post #9 of 10 Old 06-17-2013, 07:55 AM Thread Starter
stuartcoryvet
1975 CJ5
Thanks for the diagram! That's something to get started with. Can't thank you enough!
post #10 of 10 Old 06-17-2013, 01:46 PM
laybackman
laybackman's Avatar
2010 JK Wrangler
No problem!
I figured that the 1975 to 1978 CJ's wiring didn't change very much. Even if it is partially accurate that gets some of the wiring plugged into where it needs to go.
KEEP IN MIND that the wire colors may not be correct.
