Wiring fog lights through factory wiring - JeepForum.com
post #1 of 17 Old 07-21-2013, 06:19 PM Thread Starter
Alexf7019
2010 JK Wrangler
I am getting rampage driving lights tomorrow and my plan is to cut the wire right behind the factory wiring harrness and just rewire the positive and negative into my new light but I'm wondering if I can do this any help is good
Alexf7019 is offline
post #2 of 17 Old 07-21-2013, 06:37 PM
grnd93
Yes
grnd93 is offline
post #3 of 17 Old 07-23-2013, 11:54 PM
mattman998
That's exactly what I did, no problems at all. If you want it a little cleaner you can cut it on the lights side of the harness and leave the connector in place.
mattman998 is offline
post #4 of 17 Old 07-30-2013, 10:31 PM
jpdriver1
1989 MJ Comanche
I ran a separate harness for the fogs and light bar, but used the factory wiring to trigger the relays -- that way they only come on when the headlights are on and turn off when the high beams are activated
1989 metric tonne comanche, 4.0L, 5 sp trans, reciever hitch, double tube light bar, d30 front, d44 rear, alloy wheels, goodyear wranglers -- his name is snydley (as in whiplash)
1990 metric tonne comanche, 4.0L jeep speed motor, 5 sp trans, 2 in lift, d44 rear, d30 front -- her name is jenny
jpdriver1 is offline
post #5 of 17 Old 07-31-2013, 03:56 PM
LA-Sahara
Depends what wattage they are. If 55w, I'd say go for it. I used a relay just incase.
LA-Sahara is offline
post #6 of 17 Old 07-31-2013, 11:54 PM
Zdrisko
And if they're 100w?
Zdrisko is offline
post #7 of 17 Old 08-01-2013, 03:02 AM
grnd93
100w fog lights?
grnd93 is offline
post #8 of 17 Old 08-01-2013, 06:23 AM
Zdrisko
Originally Posted by grnd93 View Post
100w fog lights?
Hella 4000
Zdrisko is offline
post #9 of 17 Old 08-01-2013, 08:56 AM
LA-Sahara
Well stock were 55w, and the wires were even small for that. 100w would be too much power for the wires and switches to handle. I would just run a relay and trigger it with the stock fog wire. (Actually, that's what I did )
post #10 of 17 Old 08-01-2013, 10:03 AM
Zdrisko
That's what I figured.
Now.. build my own or buy Hellas $70 harness? :banghead:
Zdrisko is offline
post #11 of 17 Old 08-01-2013, 10:11 AM
LA-Sahara
If you know what you are doing, building a harness is easy and could possibly be done for only $20.
post #12 of 17 Old 08-01-2013, 03:37 PM
grnd93
Hella 4000
Are not fog lights.
You would be hard pressed to find a fog light over 55w
grnd93 is offline
post #13 of 17 Old 08-01-2013, 04:37 PM
Zdrisko
Are not fog lights.
Oooooook? Fogs, driving. .. how about AUXILIARY lights ..
True fogs have yellow lenses.
Zdrisko is offline
post #14 of 17 Old 08-01-2013, 04:45 PM
Zdrisko
After more research, a mechanic told me today that factory automobile wiring must withstand twice it's rated capacity. Normally I would have thrown the b.s. flag but he seemed quite positive with his statements. Afterwards we checked the numbers against factory bulb sizes for '02 Sport and found they're H1 55W and H1 100W. Confirming what he had said.
Though I'm not discounting anyone's information here, I believe I'll green light the factory wiring and switch while holding my breath. Thanks LA Sahara!
Zdrisko is offline
post #15 of 17 Old 08-01-2013, 05:45 PM
LA-Sahara
Good luck with it. I've always seen the electrical geniuses on here say that the stock wiring is barely enough for factory fogs.
