Wiring an amo to stock radio! - JeepForum.com
post #1 of 8 Old 06-13-2013, 06:49 PM Thread Starter
MattBillyTayloe
I've wired plenty of Amps and subs to aftermarket radios, it's no big deal at all, but today I went to work on a dudes cherokee, and i ran into a problem with where to connect the Rem wire, any suggestions, need help ASAP!
MattBillyTayloe is offline
post #2 of 8 Old 06-13-2013, 07:16 PM
gily25
Patch into the remote wire for the head unit. There's a sticky with the color codes of the wires.
iPhone app user; excuse typos...thanx.
gily25 is offline
post #3 of 8 Old 06-13-2013, 07:19 PM Thread Starter
MattBillyTayloe
Thanks man! Didn't know there was a sticky for that, and I didn't want to make any guesses!
post #4 of 8 Old 06-13-2013, 07:26 PM Thread Starter
MattBillyTayloe
imageuploadedbyag-free1371173191.101354.jpgwould it be the second one? Red\white
Sent from AutoGuide.com Free App
post #5 of 8 Old 06-13-2013, 07:29 PM
rubibluejay
The remote wire is the trigger for an amplifier.
If there is a factory amp, you will need to find out which wire is the amp's trigger. On my '04 Wrangler, it is a 20 gauge wire and the FSM calls it "Radio 12V Output". If he has an aftermarket amp, you would connect it to the amp's 12V + (usually labeled remote or REM +) trigger input terminal, next to the 12V + power input.
If there is no amp, you don't use the wire. Before buttoning everything up, make sure it works & that there is no exposed wire (cut clean & tape off) to cause a short.
Jay
rubibluejay is offline
post #6 of 8 Old 06-13-2013, 07:32 PM
rubibluejay
I must be a slow typer today... Three replies before I hit the post quick reply button. I was sidetracked by my phone going off though.
Jay
post #7 of 8 Old 06-13-2013, 07:37 PM Thread Starter
MattBillyTayloe
Jay
Hahah, your fine man, so I was right about using the 12v switched wire or whatever that second one is?
post #8 of 8 Old 06-13-2013, 09:13 PM
rubibluejay
Does the Cherokee have a 2 plug (grey & black) 7 wire (each plug) connection? If so, it looks like you can use the antenna (black plug, position G) trigger wire.
http://www.installdr.com/Harnesses/DCP-Wiring.pdf
Jay
