Winch will not work... - JeepForum.com
post #1 of 10 Old 09-01-2012, 07:29 PM Thread Starter
ChitwnGrnJP
Hey guys, I just bought a warn mx8000 and I'm installing it on my TJ. However, I can't get the motor to turn. I mounted the solenoid pack under the hood and got it to click (took some time to realize it needed to be grounded though). So now I am to the point that I am getting 12v to the F-2 lug and the A lug on the winch. it still won't turn though.
I'm not getting any power to the F-1 lug. is that the problem? or does it sound like my solenoids aren't wired correctly?
Please don't bash me for not searching...I only have access to the site via my phone and when I searched, I only got one thread about an mx8000 wiring schematic. and the link didn't take me anywhere.
Any thoughts would be great! thanks!
| 3.5" RE Lift | 315/75R16 BFG KM2's | Dana 30 w/ Lockrite | Dana 44 | Metalcloak Front Bumper | Smittybilt Rocker Armor | Knockoff Warn Tire Carrier | Rokmen Shorty Corners |
ChitwnGrnJP is offline
post #2 of 10 Old 09-03-2012, 09:08 AM Thread Starter
ChitwnGrnJP
bump
post #3 of 10 Old 09-04-2012, 02:40 PM Thread Starter
ChitwnGrnJP
one more bump...
post #4 of 10 Old 09-09-2012, 04:32 PM
wardo
2011 JK Wrangler
Have you figured it out?
I'd guess a dead battery bc those warn winches will put a strain on battery for sure.
2011 Flame Red 2dr Wrangler Rubicon, Poison Spyder Evap Skid, Extended Breatherlines, 4' Firefly Antenna, Uniden Pro520xl, Rock Krawler 2.5 Stock Mod Lift, Bilstein 5100's, Rugged Ridge XHD Front Bumper, Warn M8000, Rugged Ridge XHD Snorkel
wardo is offline
post #5 of 10 Old 09-09-2012, 04:39 PM Thread Starter
ChitwnGrnJP
no, haven't looked at it anymore yet. I was hoping for some pointers before I played around with it anymore
post #6 of 10 Old 09-09-2012, 04:48 PM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
Not that much, if his engine can be started the battery is good enough to power the winch for a test.
Where is the winch's main black power cable connected? Chassis? Battery?
There is also a small 16-18 gauge or so black wire leading from the solenoid pack that needs to be well grounded. Is it?
Getting
Jerry Bransford is online now
post #7 of 10 Old 09-09-2012, 05:34 PM Thread Starter
ChitwnGrnJP
The ground from the motor is run back to the battery. I grounded the solenoid pack to the battery as well.
I was thinkin about running the motors cables directly to the battery and see if it spins...Does that sound like a good idea?
post #8 of 10 Old 09-12-2012, 02:09 PM
Indy
Indy's Avatar
Using a pair of cables is the quickest way I know to test the motor. + to the battery and then connect the other side to one of the lugs. Assuming the winch is properly grounded the motor should spin. 1 lug does in, the other out. If it works and you have a good connectio between the battery and pack, the problem lies between the solenoid connection and winch connection.
I'm the only gay eskimo.
Indy is offline
post #9 of 10 Old 09-12-2012, 02:17 PM
Billy
Billy's Avatar
When my winch stopped working I had to get a ohms meter and go solonoid by solonoid and see if they are all working properly. ended up replacing one. Simply disconnect each solonoid and check for resistance. The one that measures resistance is your problem child and should be replaced. (if thats the problem at all. Just saying, thats what worked in my case.)
Everyone IS out to get you, if you just believe in yourself and try hard enough!
Billy is offline
post #10 of 10 Old 09-14-2012, 11:38 AM Thread Starter
ChitwnGrnJP
Thanks everyone! I'm going to look at it more this weekend. I'm going to test the motor and then work on the solenoid pack and keep narrowing down the problem. I'm honestly just afraid the motor is burnt up.
Billy...I hadn't thought of this yet so I'll try this too! thanks!
