Will this setup work for my 2000 TJ? - Page 2 - JeepForum.com
post #16 of 21 Old 07-31-2012, 09:25 PM Thread Starter
kwiatkowski9346
I decided to go with 2 10" subs in the box i linked to above, seemed like a better setup. And from what I found from some research that amp running at 2 ohms will provide 500w, so that if I wire the subs in a parallel circuit than I will have the proper power correct?
Here's a link to the amp and info...
http://www.techronics.com/index.cfm?...oduct_ID=10648
kwiatkowski9346 is offline
post #17 of 21 Old 07-31-2012, 09:27 PM Thread Starter
kwiatkowski9346
post #18 of 21 Old 07-31-2012, 09:39 PM
sjones26573
Ah 1000w is the max power. In reality that is a 500w (RMS) amp. Yep, that should work.
The Offroad Club @ NC State; Founder
The Yellowtail Build
Jeep-Owner.com
sjones26573 is offline
post #19 of 21 Old 07-31-2012, 09:40 PM Thread Starter
kwiatkowski9346
I decided to go with 2 10" 4 ohm Pioneer subs instead of the box that came ready made and mount them in the box i linked to above. Somewhere else on the internet (i know not the most trustworthy source) specified that if I wired the two 250w amps in parallel, an amp with an RMS of 500 watts would suffice.
Heres a link to the subs and amp
http://www.techronics.com/index.cfm?...oduct_ID=15107
post #20 of 21 Old 07-31-2012, 09:41 PM Thread Starter
kwiatkowski9346
ok so what gauge wiring and amp kit should I get?
post #21 of 21 Old 07-31-2012, 11:49 PM
ajones8230
Check out amazon. Just a medium gauge kit will work for what you're doing. Costs around 15-20 on amazon.
ajones8230 is offline
radio , sound , sound system , speaker replacements , subwoofer
Remote doesn't work on my 2000 XJ NYSLC93 Audio, CB & Ham Radios, GPS, & Electrical 1 10-14-2009 01:23 PM
I need to know if this setup will work kevincctx Tires & Wheels 8 08-10-2008 11:12 PM
Will this setup work? OUrunner Tires & Wheels 5 03-31-2008 05:07 PM
How would this amp work with my setup? Michele Audio, CB & Ham Radios, GPS, & Electrical 4 04-06-2004 07:34 AM
ok, will this setup work? shookwell Tires & Wheels 1 12-22-2003 10:32 AM
