Will this setup work for my 2000 TJ? - JeepForum.com
post #1 of 21 Old 07-31-2012, 11:33 AM Thread Starter
kwiatkowski9346
I recently purchased my first Jeep, a 2000 Wrangler TJ and am looking to upgrade the sound. I am a college student so I am on a tight budget, and frankly know NOTHING about wiring something like this.
The components I was looking to install were:
Pioneer DEH-4400HD CD Receiver with Dot Matrix LCD Display & HD Radio
Pioneer TS-SWX310 Shallow Series Preloaded 12" Sub Enclosure with 1 TS-SW301 Subwoofer
or
Pioneer TS-SWX251 Shallow Series Preloaded 10” Sub Enclosure with TS-SWX251 Subwoofer
Pioneer GM-6500F 760W Max, 4-Channel GM Series Car Amplifier – however, I do not know if this amp is sufficient.
Pioneer TS-A4674R 4" x 6" 3-Way A-Series Coaxial Car Speakers
Pioneer TS-A1374R 600W, 5-1/4" 3-Way A-Series Coaxial Car Audio Speakers
Could anyone assist me with how I would wire this and if this amp will work? I don’t understand how to wire all of the different components to the amp. What do ohms have to do with the equation? If not adequate, what would be the correct amp for a comparable price?
Also could you advise on what other things I would need such as a wiring kit or other accessories, again I have no idea what I am doing, but I would like to do it myself to be cost efficient.
kwiatkowski9346 is offline
post #2 of 21 Old 07-31-2012, 12:41 PM
kingcat400
looks good but i would put 5-1/4's in the dash and 6's in the sound bar. other than that it looks good
you will need a harness and dash kit also along with an amp kit for the sub.
personally i would look at kicker for the speakers sub and amp but that's just me
kingcat400 is offline
post #3 of 21 Old 07-31-2012, 12:52 PM Thread Starter
kwiatkowski9346
Does kicker have a better reputation? I found a good deal on the pioneer ones. Do the coaxial speakers get hooked to the amp as well? and is a 4 channel amp enough?
Sorry for all the questions, again I'm new at this. but how do I know what watt amp I need if I am hooking both sets of speakers and the sub to it?
post #4 of 21 Old 07-31-2012, 01:13 PM Thread Starter
kwiatkowski9346
Or would I need two separate amps, one for my sub and one for my speakers
post #5 of 21 Old 07-31-2012, 01:17 PM
sjones26573
You will want a Monoblock amp for the sub and a 4 channel amp for the speakers. But I run my 5 1/4" Kicker dash speakers and stock pod speakers straight off the head unit as loud as the hu will go with almost no distortion. And I mean loud.
The Offroad Club @ NC State; Founder
The Yellowtail Build
Jeep-Owner.com
sjones26573 is offline
post #6 of 21 Old 07-31-2012, 01:19 PM Thread Starter
kwiatkowski9346
So would the head unit i posted above have enough power to run the pioneer dash and soundbar speakers if I wired them directly?
post #7 of 21 Old 07-31-2012, 01:23 PM
sjones26573
Most likely yes. But an amp would be a nice upgrade in clarity and loudness. But mine has done well enough I haven't seen the need to add an amp yet.
Jeep-Owner.com
post #8 of 21 Old 07-31-2012, 01:25 PM Thread Starter
kwiatkowski9346
And would the stock wiring be good enough for the speakers or would I want to rerun wire? Again, I'm sorry if these are stupid questions
post #9 of 21 Old 07-31-2012, 01:26 PM
sjones26573
Since you aren't amplifying, the stock wire is fine.
Jeep-Owner.com
post #10 of 21 Old 07-31-2012, 01:31 PM
ajones8230
I changed the stock speakers out with Sony explode's from Walmart of all places. Very inexpensive and they sound great. Then I added a clarion head unit and two 10" subs with kicker amp. I bought the head unit install kit and wiring harness from amazon both for the amp and to connect the stereo to the factory harness. The sound is awesome and it didn't cost too much. You can always spend more, but I figured I'm in a jeep with a soft top how much do I want to spend. The wiring was easy following directions.
ajones8230 is offline
post #11 of 21 Old 07-31-2012, 01:35 PM
sjones26573
I would run Pioneer before Sony any day. I consider Sony car audio bottom of the barrell. I got my Kickers on sale pretty cheap from Sonic electronics. My subs and amp are the costly part of my setup. 2 JL Audio 10-W3V3-4 subs and a JL Audio XD600/1 monoblock amp.
Jeep-Owner.com
post #12 of 21 Old 07-31-2012, 03:55 PM
CrutchfieldMark
No real problems with that setup. You can use the link below to do more research if you wish.
What fits your Jeep?? Find out below!!
CrutchfieldMark is offline
post #13 of 21 Old 07-31-2012, 05:02 PM
sjones26573
And just to reiterate (sp?), go 5 1/4" in the dash with a pair of Nalin Mfg adapter plates. Way better sound quality than ovals.
Jeep-Owner.com
post #14 of 21 Old 07-31-2012, 09:05 PM Thread Starter
kwiatkowski9346
Final question, I decided to go with this box
http://www.hifisoundconnection.com/S...id/0/SFV/30046
using two Pioneer TS-W254R 10" Single 4 ohm subs wired in parallel on a Kenwood KAC-8105D 1-Channel 1000 watts Class D Monoblock amp. What amp kit will I need to wire all of this. As in what gauge. Could someone recommend one?
post #15 of 21 Old 07-31-2012, 09:16 PM
sjones26573
1000w amp?! You don't need that much power to run a single sub. I have 1 600w amp powering 2 10" subs.
Jeep-Owner.com
radio , sound , sound system , speaker replacements , subwoofer
Remote doesn't work on my 2000 XJ NYSLC93 Audio, CB & Ham Radios, GPS, & Electrical 1 10-14-2009 01:23 PM
I need to know if this setup will work kevincctx Tires & Wheels 8 08-10-2008 11:12 PM
Will this setup work? OUrunner Tires & Wheels 5 03-31-2008 05:07 PM
How would this amp work with my setup? Michele Audio, CB & Ham Radios, GPS, & Electrical 4 04-06-2004 07:34 AM
ok, will this setup work? shookwell Tires & Wheels 1 12-22-2003 10:32 AM
