Where to send RB1 for repair? - JeepForum.com
post #1 of 28 Old 02-23-2011, 10:12 PM Thread Starter
Sarge_
It seems I my RB1 needs to be repaired - where do people send them to be fixed (other than the dealer)? Anyone know?
'06 Unlimited Rubicon, Midnight Blue, 6M
Previous Jeeps
'00 TJ Sport 4.0
'00 GC Laredo 4x4 V8
'95 YJ 2.5L
Sarge_ is offline
post #2 of 28 Old 02-25-2011, 09:12 AM Thread Starter
Sarge_
No ideas?
Previous Jeeps
'00 TJ Sport 4.0
'95 YJ 2.5L
Sarge_ is offline
post #3 of 28 Old 02-25-2011, 05:02 PM
mylt1
mylt1's Avatar
it would be cheaper to buy a used one that works than have a shop diagnose and repair the problem.
mylt1 is offline
post #4 of 28 Old 02-26-2011, 07:01 AM Thread Starter
Sarge_
Given how high the failure rate seems to be, and the cost of RB1's, that's not the answer I'm hoping for... This one's only two years old, but was only warranteed for 12 months. Easily the most unreliable piece of electronics ever...
The only reason I didn't go aftermarket was to minimize theft temptation. Turns out the thief is Chrysler.
Previous Jeeps
'00 TJ Sport 4.0
'95 YJ 2.5L
Sarge_ is offline
post #5 of 28 Old 02-26-2011, 07:52 AM
commodore_dude
commodore_dude's Avatar
Yeah, I'm just going to enjoy mine until it dies completely, then put the original 6-disc changer radio back in and use my cellphone for GPS. I like the RB1, but it's so much less useful than modern in-dash units that I just don't think it's worth doing much with.
2006 Rubicon Unlimited
1998 Buick LeSabre Custom
commodore_dude is offline
post #6 of 28 Old 02-26-2011, 04:48 PM
mylt1
mylt1's Avatar
this defense is always used but the fact is its no excuse to not upgrade your deck. if car brake ins that frequent in your town its time to move. if you replace the deck and notify your insurance co then if the radio is stolen then they will replace it. you ins co will tell you what info they need so it is covered under your policy. you will be much happier with a good aftermarket deck that probably cost less than the RB1.
mylt1 is offline
post #7 of 28 Old 02-26-2011, 06:14 PM Thread Starter
Sarge_
That's a nice contrite response, but I like leaving my Jeep at a trailhead to go into the backcountry for days, and having it look electronically stock. It avoids blatantly tipping would-be thieves off to the other thousands of dollars of amps, speakers and so forth. It also has a nice appearance, since the cutout is an odd shape.
Previous Jeeps
'00 TJ Sport 4.0
'95 YJ 2.5L
Sarge_ is offline
post #8 of 28 Old 02-26-2011, 10:22 PM
mylt1
mylt1's Avatar
detachable faces are your friend.
mylt1 is offline
post #9 of 28 Old 02-27-2011, 08:25 AM Thread Starter
Sarge_
Again, that's a 'tip off' to thousands of dollars in speakers, amps, ipod, sirius and other electronics that are otherwise invisible. Even more than the cost of theft replacement and insurance claims (claims cost money too, in the form of rate hikes), it's the many, many hours of work that go into building the system all over again, as well as the ancillary damage reckless thieves do as they rip your car apart.
In a vehicle that's easier to break into and disassemble than any other on the planet, save for a motorcycle, it's better to stay below the radar. It just is.
Previous Jeeps
'00 TJ Sport 4.0
'95 YJ 2.5L
Sarge_ is offline
post #10 of 28 Old 02-27-2011, 06:11 PM
mylt1
mylt1's Avatar
ok, i give up, you are full of it and no answer is going to suit you. hundreds of thousands of people install aftermarket radios every year and none of them use the excuses you do. a better deck does NOT mean there are thousands of dollars of radio equipment in a car. do you really think someone is going to waist the time to remove equipment that is bolted down? thieves steal decks because they are a simple rip and run. they are not going to take the time to remove door panels to take the speakers, tilt the seats to remove the bolts and take the amps, or open the rear hatch and remove the securing straps to hold the subs down(which you should be using). if you think they are you are delusional, and if theft is that prevalent in your town MOVE. of course i think your full of it to start with since no one with half a brain would install thousands of dollars of audio equipment in a jeep with a stock radio unless you have no clue what a good system sounds like. factory radios send a crap signal so the old saying "crap in crap out" holds true. in done with this thread. you chose not to listen thats your problem, not mine.
mylt1 is offline
post #11 of 28 Old 02-27-2011, 08:18 PM Thread Starter
Sarge_
ok, i give up,
You should have stopped there.
Does anyone (who isn't an a$$hat) have a factual answer as to where to send an RB1 for repair?
Otherwise, I guess I'm going to have to relocate my family!
Previous Jeeps
'00 TJ Sport 4.0
'95 YJ 2.5L
Sarge_ is offline
post #12 of 28 Old 02-27-2011, 08:42 PM
psouza1943
Radio repair
Have tolerance, Sarge. Some folks opinions trump common sense, don'tcha know.
Years ago, privately owned radio shops contracted with the various local car dealers, with the backing of the respective factories. Those days are long gone, along with radios that CAN be repaired.
Modern construction practices require very specialized equipment and experience to affect a repair. No one will pay the price, so consider the radio, or other electronics a throw away item. The dealer may be a viable way, since both my local dealers can offer attractive prices on many items AS THEY BECOME AVAILABLE. Not a reliable source but some times one can get lucky.
Some links that may be of use, and there may be others out there,
http://www.replacementradios.com/
http://www.wjjeeps.com/nav.htm#PARTS
good luck
Phil
psouza1943 is offline
post #13 of 28 Old 02-28-2011, 10:05 PM Thread Starter
Sarge_
good luck
Phil
A two year old, $1,300 unrepairable OEM radio is patently unacceptable. It's... fraud. Really. I will keep looking. Thanks for the constructive reply
Previous Jeeps
'00 TJ Sport 4.0
'95 YJ 2.5L
Sarge_ is offline
post #14 of 28 Old 08-05-2011, 10:18 AM
twagner4287
RB1 Display
Sarge,
Did you ever fix your RB1? I am looking for a new display for my RB1 - did you fix yours and/or do you know a good repair company?
Thanks
Tom (former Army E5)
twagner4287 is offline
post #15 of 28 Old 04-21-2012, 05:57 AM
joelbridgman
Rb1 nav
United Radio in New York repairs RB1 radios last I checked, which was about 6 months ago. The last price quote I got was $380. The unit can't have external damage or the cost will be higher, meaning the screen can't be cracked. I opted to buy a RBK radio off Craigslist for $20. It does not sound as good.
mylt1, you suck.
joelbridgman is offline
Beyond repair? The Von General Jeep & Off-Road Equipment 1 03-29-2008 02:02 PM
Was all set to press send for Super Swamper SSR but then timekpr Tires & Wheels 11 09-07-2006 09:04 PM
CJ7 tub repair? rob5059MOD General Jeep & Off-Road Equipment 5 07-01-2006 09:54 PM
BRC ACTION ALERT - Send Email to FS on National OHV Policy ravenoffroad General Jeep & Off-Road Equipment 2 09-13-2004 12:14 PM
